Project Don't be evil
Revision as of 18:11, 10 March 2019 by Tllim (talk | contribs)
The Project "Don't be evil" - Phase 2 of PINE64 Smartphone "PinePhone" Development Kit
Project Don't be evil is an actual smartphone developer kit for the PINE64 Smartphone dubbed "PinePhone". It is used in the early stages of development as a starting point for affiliated projects. PinePhone development has been broken down into three distinct phases:
  • First phase - Project Anakin
  • Second phase - purpose-built development kit code named "Don't be evil" and introduced at FOSDEM 2019
  • Lastly, the third phase which is the PinePhone itself - scheduled to be prototype released in Q3 2019 and BTO batch released with mobile OS parents in Q4 2019 (pending on software development).
Image: 500 pixels Image: 500 pixels
Project Don't be evil, Baseboard and SOPine Module Information, and Schematics
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
    • Lithium Battery information:
You can also flash an OS image manually; please follow the instructions below.
UBPorts mainline build
  • Not Yet Ready *
KDE Plasma Mobile build
  • Not Yet Ready *
Postmarket OS build
  • Not Yet Ready *
Sailfish OS build
  • Not Yet Ready *
Maemo OS build
  • Not Yet Ready *
Mali-400 64-bit Driver
Quick Links to Build Sources of OS Images
Some these OS images labelled as beta or nightly builds which means they are only fit for testing purposes
These images should be used at your own risk and are not fit for normal use
SoC and Memory Specification
  • Based on Allwinner A64/R18
    • R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
Other Resources
