Project Anakin
The Project "Anakin" - Phase 1 of PINE64 SmartPhone Developer Kit
The Project Anakin is a marsh-up kit for PINE64 SmartPhone "PinePhone" first phase developer kit. PinePhone schedule totally has three phase, second phase code name "Don't be evil" plan to introduce on FOSDEM 2019 and third phase PinePhone itself will be released on Q3 2019 pending on software development. The Anakin kit consists of following components:
  • SoPine Module
  • SoPine Model A baseboard
  • Pine A64 Wifi/BT module
  • 16GB eMMC module
  • 5 Mega Piixel CMOS Camera Sensor
  • 7" Touch Screen LCD Panel
  • Playbox Enclosure
  • Lithium Ion Battery case (note: battery not included, can accommodate 1-3 pieces of 18650 szie Lithium Ion batter. In general, one is good enough)
  • Quectel EC20 R2.1 LTE Module (note: The SIM tray design not distinguish polarity well and all reverse slot in)
You can also flash an OS image manually; please follow the instructions below.
Project Anakin
Under the 'SOPINE Software and OS Image Download Section' you can find a complete list of currently supported Mainline Linux Operating System images that work with the Akakin project as well as other related software. The list includes OS images and descriptions of:
Mali-400 64-bit Driver
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides concerning:
  • Playbox Enclosure
  • Bluetooth and WiFi module
SoC and Memory Specification
  • Based on Allwinner A64/R18
    • R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
Project Anakin, SOPine Module and Baseboard Information, Schematics, and Certifications
Other Resources
