Project Anakin
The Project "Anakin" - Phase 1 of PINE64 Smartphone "PinePhone" Development Kit
Project Anakin is a marsh-up kit for the PINE64 Smartphone dubbed "PinePhone". It is used in the early stages of development as a starting point for affiliated projects. PinePhone development has been broken down into three distinct phases:
  • First phase - Project Anakin
  • Second phase - purpose-built development kit code named "Don't be evil". It will be introduced at FOSDEM 2019
  • Lastly, the third phase which is the PinePhone itself - scheduled to be released in Q3 2019 (pending on software development).
The Anakin kit consists of following components:
  • SoPine Module
  • SoPine Model A baseboard
  • Pine A64 Wifi/BT module
  • 16GB eMMC module
  • 5 Mega Piixel CMOS Camera Sensor
  • 7" Touch Screen LCD Panel
  • Playbox Enclosure
  • Lithium Ion Battery case (note: battery not included, can accommodate 1-3 pieces of 18650 size Lithium Ion batter. In general, one is good enough)
  • Quectel EC20 R2.1 LTE Module (note: The SIM tray design not distinguish polarity well and all reverse slot in)
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides concerning:
  • Playbox Enclosure
  • Bluetooth and WiFi module
SoC and Memory Specification
  • Based on Allwinner A64/R18
  • R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
Project Anakin, SOPine Module and Baseboard Information, Schematics, and Certifications
SOPine Module Schematic:
SOPine Model "A" Baseboard Schematic and PCB Board Resource:
SOPine (together with model "A" baseboard) Certification:
Allwinner A64/R18 SoC information:
X-Powers AXP803 PMU (Power Management Unit) information:
LPDDR3 information:
eMMC information:
SPI NOR Flash information:
Project Anakin module/component related information
5MPixel Rear CMOS Camera module information:
LCD Touch Screen Panel information:
Ethernet PHY information:
Wifi/BT module information:
Enclosure information:
Connector information:
LTE module information:
Other Resources
