Project Anakin
The Project "Anakin" - Phase 1 of PINE64 Smartphone "PinePhone" Development Kit
Project Anakin is a marsh-up kit for the PINE64 Smartphone dubbed "PinePhone". It is used in the early stages of development as a starting point for affiliated projects. PinePhone development has been broken down into three distinct phases:
  • First phase - Project Anakin
  • Second phase - purpose-built development kit code named "Don't be evil". It will be introduced at FOSDEM 2019
  • Lastly, the third phase which is the PinePhone itself - scheduled to be released in Q3 2019 (pending on software development).
The Anakin kit consists of following components:
  • SoPine Module
  • SoPine Model A baseboard
  • Pine A64 Wifi/BT module
  • 16GB eMMC module
  • 5 Mega Piixel CMOS Camera Sensor
  • 7" Touch Screen LCD Panel
  • Playbox Enclosure
  • Lithium Ion Battery case (note: battery not included, can accommodate 1-3 pieces of 18650 size Lithium Ion batter. In general, one is good enough)
  • Quectel EC20 R2.1 LTE Module (note: The SIM tray design not distinguish polarity well and all reverse slot in)
You can also flash an OS image manually; please follow the instructions below.
Arch Linux mainline build by anarsoul
AOSC Community mainline minimum build by icenowy
Mali-400 64-bit Driver
Quick Links to Build Sources of OS Images
Some these OS images labelled as beta or nightly builds which means they are only fit for testing purposes
These images should be used at your own risk and are not fit for normal use
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides concerning:
  • Playbox Enclosure
  • Bluetooth and WiFi module
SoC and Memory Specification
  • Based on Allwinner A64/R18
    • R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
Project Anakin, SOPine Module and Baseboard Information, Schematics, and Certifications
SOPine Module Schematic:
SOPine Model "A" Baseboard Schematic and PCB Board Resource:
SOPine (together with model "A" baseboard) Certification:
Allwinner A64/R18 SoC information:
X-Powers AXP803 PMU (Power Management Unit) information:
LPDDR3 information:
eMMC information:
SPI NOR Flash information:
Project Anakin module/component related information:
Other Resources
