Pinecil Hardware Debugging
Jump to navigation
Jump to search
Debugging different problems
- Pinecil doesn't power on at all
- Check your PSU - it might be faulty - Check cable - Use different kind of PSU (if you're using a barrel jack one, try a Type-C one, and vice-versa)
- Pinecil shuts down when connected to a Type-C PSU and trying to request a higher voltage (needs a bit more clarification)
- Update firmware - factory firmware has quite a few USB-PD problems, which the newer firmwares fix
- Pinecil randomly resets when touching solder
- Using PinePower or some other grounded PSU? - This is likely to be a grounding problem.
- Doesn't power on after applying 24V
- The FUSB302 might have gotten damaged and shorted an internal power rail (has verifiably happened before) - Fix is to use a hot air gun to remove the FUSB from the board. You can leave the iron without the FUSB302 IC, or you can find and buy a replacement. - Without the FUSB IC present, you will lose USB-PD compatibility - the Type-C jack will not power your Pinecil with a C-to-C cable, or from a PD-capable PSU with attached type-C cable (laptop PSUs)
- Pinecil tip heats up too much, starts to glow and [REDACTED]
- [REDACTED]
