Pinecil Guides to Soldering
Revision as of 14:31, 1 March 2023 by Fxc (talk | contribs) (→‎Using the Conical tip: Wiki style)
This article contains guides regarding soldering with the Pinecil.
Guides for Soldering & Maintenance
General soldering guides
Does solder type and flux matter?
How to keep the tip clean?
What temperature should I use?
1. General Formula: add 120°C to the melting point listed on the solder label, and adjust up/down as needed for different tasks.
  • Example: the solder says 220°C melt point, then 220 + 120 = 340 °C
  • One could also try these common working temperatures below, start lower and increment by 5 °C until you get a comfortable working temperature (thicker wires & situations dictate more or less).
Common working temperatures:
- For Lead solder: 300°C - 320°C
- For No-lead solder: 350°C - 365°C
2. If there is no listed melting point on the solder label, refer to google or a chart like below for your specific type of solder alloy:
3. Adding a small amount of solder to your tip before starting increases the thermal mass of the tip and could help. See the soldering guides above for demonstrations of this.
How do I use the conical tip that comes default with Pinecil to get enough heat transfer?
Conical tip, hold it to the side of the item and not vertically like a pen. See https://cdn.sparkfun.com/assets/learn_tutorials/5/8/4/SolderingAdvice_1edit.png
Correct amount of solder and solder flow. See https://cdn.sparkfun.com/assets/learn_tutorials/5/8/4/SolderingAdvice_2.png
Go back to Pinecil article
Go back to Pinecil article.
