Pinecil: Test, Repair, Issues
This article explains how to repair the Pinecil.
Cautions
Warning: While opening your Pinecil will not necessarily void your warranty, all self-repairs are done at your own risk. Read everything in this section and related or linked articles to get a good idea of the procedure, and go to the Pinecil community chat if you desire advice/support from experienced volunteers. Self-repairs or mods will void your warranty so proceed if this is not a concern. This information is for educational purposes only.
Pinecil V1 and V2 have slightly different schematics and have different MCU chips. Doing repairs often requires referencing the correct schematics or photos. The datasheets are also important to get information about the chips, and to order replacement parts. The schematics and known datasheets are all at the bottom of this article and linked in the contents table at the top. Chatting with other owners of Pinecil is encouraged as they have experience - already broke things so you don't have to (see Pinecil volunteer chat link here).
Note: This is a new work in progress (WIP) started Feb. 18, 2023 which may be updated over time as volunteers have time to write up information. For sections that are missing, try asking in the live chat as a volunteer may have some clues to get you headed in the right path.
Tools you need
  1. All schematics, datasheets for known common parts, and links to where to buy some replacement parts are all in the main Pinecil article under Schematics and board data.
    • Refer to the correct section for V1 or V2 parts.
    • Which model do I have? The older V1 model has an all black handle with a blue silicone grip and was discontinued in July 2022. The new V2 model has a black handle with a green thumb grip and is the only model PINE64 and authorized resellers started selling after August 1, 2022.
  2. Reference photos of the PCB boards here. Photos will help to chat with volunteers in the live Pinecil chat channel.
  3. Digital multimeter
  4. Optional, better probe Leads: nice for electronic work and needle size makes things easier.
  5. Possibly another soldering iron to do the repair, some flux, solder, and isopropyl alcohol (IPA) for cleaning the PCB.
  6. Philips screwdriver for small screws.
  7. Magnifying lamp or jeweler's glasses with led light and good room light.
  8. Optional but helpful: mobile phone to take macro photos or video to share on the live Pinecil chat during troubleshooting. A macro lens to take phone photos is helpful; there are cheap ones that simply clip on.
  9. An oscilloscope is sometimes helpful but not needed for most repairs.
PCB
Comparison of screen side: V2 on top, V1 below
Comparison of pinecone side, V2 on top, V1 below
Disassembly steps
Easy trick to open the Pinecil
See this video: https://www.youtube.com/watch?v=aK01V5DrrVk
  13. Remove the round copper ring contact from under the PCB, near the tip end of the handle (this is installed first before the PCB because it provides ground contact from the front of the Pinecil to the rear ground screw).
  14. Remove the two small round buttons so they do not get lost.
Assembly steps
  1. Place the two round buttons into the two holes in the top half of the case.
  2. Install the round copper ground contact at the tip end before installing the PCB.
  3. Place the PCB board into handle at an angle, DC barrel end goes in first.
  10. Gently insert tip.
Diagnosis & Testing
Common Fixes
  1. Sometimes, just updating to the newest firmware fixes issues as Ralim and team are very active in adding features and bug fixes enhancements (see Firmware).
  2. Some Troubleshooting information is also on GitHub Ralim's IronOS (which is the firmware that is on the Pinecil). There are several hidden Debug tools in the firmware that also help with diagnosis.
  3. If you can't find the information here or it hasn't been written yet; simply join the volunteer run live Pinecil chat channel. Sometimes you can get a clue to the right path.
FAQ
Common Questions
  1. How do I install the optional Hall Effect Sensor? See the Hall Effect Sensor article for installation; location is U14 on the PCB & in the Schematics. Reference schematics section here also.
  1. Help, I think I bricked Pinecil doing an update: no worries, it's very hard to brick a Pinecil because of the way the firmware is loaded in ROM. Usually just flashing again with a newer or different version brings it back to life (see Firmware). This can be done even if you can't see your screen anymore.
  2. My Pinecil keeps rebooting: change to a different charger or add a ground wire to your Pinecil ground screw (search for ts100 ground wire on a search engine). Also see the Power Supplies article. This could happen because of the way 2-prong no-ground chargers are made with no ground path for small current leakage. Also try to plug the charger into a surge protector strip (type that have 3-prong ground and plug the surge protector into a 3-prong grounded wall outlet). Try a different cable or flipping the cable over also.
  3. Tip is glowing red hot. Unplug immediately, you have most likely a blown MOSFET, see the MOSFET section.
  4. Temperature is flickering wildly: see Poor contact repair.
  5. HAN C reading is way out of spec (very low/high) and my temperature is way off: see IronOS Troubleshooting here, esp. about CHan and Temperature sensor. If reflowing/resoldering the Temperature sensor does not work, replacement might be needed.
  6. Screen shows X symbol (no tip installed) and I have a tip installed. Remove the Tip screw, seat the tip all the way back, reinstalled the screw. See Tip Problems and Poor Contact repair.
  7. I see Thermal Runaway or Undervoltage messages on the screen. This is often caused by using a weak power supply that does not have a minimum of 12V-3amps and is not rated to work with Pinecil. Pinecil will stop heat to the tip and display Thermal Runaway.
    • TL;DR get a USB-C charger 20V 3.25 amps, PD 65W (best bang for the buck for good Pinecil performance) many available between $15-$25.
    • Detailed information on chargers can be found under Pinecil Power Supplies.
  8. I plugged in the wrong kind of DC barrel charger, it was a not Center-positive pin and now the Pinecil won't turn on: see Reverse polarity damage. Usually requires replacing the MOSFET (U13) and Buck Converter/Step-down (U8). See the datasheets for links to parts.
  9. I hear a sizzling/crackle sound from my new Pinecil: this is usually fine and may disappear after a few days of use, see Hissing Crackle Sound.
  10. Screen is black and won't come on: Check out the IronOS troubleshooting guide here for possible OLED display issues. If your OLED display has failed, see the Datacomponents section here at the bottom of this article for links to replacement parts. Repair method would be similar to ts100 screens of which there are many guides like this video.
  1. The sizzle sound will usually go away after a few days of use and heating up the iron. After wiping the tip contacts with IPA, heat it up a few times to 350 °C.
  2. Ralim said, "there is usually a bit of noise when you first use it, and a slight hiss/pop noise from the handle and that is normal. depends a bit on exactly what batch of caps are in your unit. The Tip drive signal is AC coupled through a capacitor for safety, downside is that it means the firmware is hitting that cap with a square wave the whole time the tip is on. Once you have heated up the duty cycle, it drops off so it's not as noticeable."
  3. Some members reported that after they opened their new Pinecil, wiped the PCB and tips gently with IPA, let it dry, all the sizzling noise went away. They also did a break-in of the new tips, bringing the temperature to 350 C a few times.
  4. Video of similar crackle sound on the ts100 iron (don't have example of Pinecil, but it's similar sound).
Pinecil requires a Center-positive DC power supply which most are, but some are reverse polarity and will destroy the electronics if used. If you plugged in a "center-negative" DC power supply, most likely the MOSFET and the Buck converter are broken. This usually requires replacing the MOSFET (U13) and Buck Converter/Step-down (U8). See the datasheets for links to replacement parts which is at the bottom of this article here.
Check the polarity of the DC Barrel plug before plugging in a random charger. Incorrect polarity will break the Pinecil.
Video here shows how to check.
Reference the article on DC barrel chargers here, (i.e., laptop bricks) for appropriate USB-C and DC chargers that will work with the Pinecil.
Tip Problems
  1. Wipe tips clean, details in Poor Contact section
  2. Using a multimeter, switch it to ohms to measure resistance. Measure the two silver band at the white or rear end of the Tip.
  3. If it measures OL or infinity, or extremely out of the spec range below, it is bad. It should measure close to the specs.
    • Normal ts100 style tips should measure ~7.8 ohms - 8.3 ohms.
    • PINE64 brand Short tips should measure ~6.1-6.5 ohms.
    • See the Pinecil Tips.
Poor Contact repair
  1. Poor contact could happen if the tips are not clean or brand new with factory residue or not making good contact with the internal clips inside the Pinecil. The two contacts inside might need to also be removed, wiped and reinstalled with the two screws (ensure the small metal tab on the clip sits into the small hole in the PCB).
  2. Most likely the tip is not making good contact. Usually this issue goes away after a few days of use as the tip rubs against the contacts more. New tips could have factory residue on them from handling.
  3. To fix this issue quicker, wipe all new tips or old tips with a dry towel or 90-99% IPA (isopropyl alcohol) especially the two silver contacts at the white plastic end (do not use water to wipe it which could get into the seam line on the white end).
  4. With the Pinecil unplugged, remove and reinsert the tip a couple times and spin it a little inside against the contacts. Then plug it in and heat it up to 350C a few times for a couple minutes.
  5. Always unplug Pinecil before swapping tips. Hot swapping is not a good idea, and for the V2 this could cause strange behavior as the V2 auto-detects tip resistance only on power-up or reboot.
  6. Sometimes just disassembling and reassembling all parts back correctly and installing the 2 internal contacts with screws correctly also helps.
Schematics and Board Data
Pinecil V2 mainboard schematic
Pinecil V1 mainboard schematic
V1 was only sold until July 2022, and then discontinued for newer V2 model.
Datasheets for Components
Pinecil V2 datasheets
USB-C PD Controller data:
Power Regulators:
Sensor data:
Power MOSFET Switch:
Operational Amplifier:
Display Screen OLED:
MCU: Bouffalo Labs, BL-706_QFN48, RISC-V + 2.4 GHz RF SoC Information:
USB-C port:
Pinecil V1 datasheets
GigaDevice RISC-V SoC data:
Sensor data:
Display Module data:
USB Type-C PD Controller data:
Power Regulator data:
Power MOSFET Switch data:
OP Amp information:
Capacitors:
LowPowerSemi LP6498B6F 1.2A Switching Power Regulator Datasheet - on breakout board
USB-C port:
Pinecil V1, 24V Mod
Warning: Do this at your own risk, read everything in this section and related/linked articles, and go to the Pinecil community chat if you desire advice. An incorrect cut of the trace could render the Pinecil non-working.
  1. This modification is not for the V2 as the newer V2 already has 24V DC capability.
  2. If you have an older V1 model, then first upgrade to the newest firmware here before starting this modification. The PD debug menu was added to the firmware in 2.17 and other important fixes came later. Access to the hidden PD debug menu is necessary to assist with this mod.
  3. See Ralim's IronOS for how to use the hidden PD Debug here and check if your version of Pinecil V1 could benefit from the modification.
  4. If PD-Debug menu says "No VBUS", then stop here, you do not need the modification or any cut of the trace line, it will not benefit you because there is no connection to the VBUS already. If it says "w. Vbus" then continue. If you don't have a PD-Debug menu, then upgrade to the newest firmware first, see instructions above.
  5. Some models of V1 came with the PCB already capable of 24V as the Pine Store made modifications to the PCB (not all batches of V1 were the same). Do the PD debug test first to see if the mod is not required.
  6. See the February 2022 Community update. The Photo is incorrect in the article. It is not a before and after photo.
    • There are two separate photos of two different V1 Pinecils which have a slightly different PCB and therefore, the trace is cut in a slightly different location.
    • One PCB came with 2 via holes and is harder to modify and cut in the correct location to avoid damaging the via holes. This is called the "whalecil" in community chat (look at the photo to see why it's called whalecil).
    • the other pcb is much easier to cut the trace. You need to cut all the way across the trace (cut is between the 2 arrows in the photo, connect the cut from arrow to arrow).
  7. Don't plug in 24V until you first check with a lower power supply that PD DeBug says "No VBUS" which means you are done. If not, then try cleaning out the copper dust in the cut with IPA, dry it, and check again. If it's still not working, then cut a little deeper and clean the cut.
  8. If you want another set of eyes on it before you cut, post a macro photo of your PCB (near the Pinecone) on the Pine64 > live Pinecil chat channel. Ask for a volunteer who has completed the 24V Mod on an actual Pinecil V1 before. Keep in mind that not all chat people own a pinecil even if they are in the pinecil channel.
Go back to Pinecil article
Go back to Pinecil article.
