Pinecil: Test, Repair, Issues
Cautions
Warning: while opening your pinecil will not necessarily void your warranty, all self-repairs are done at your own risk. Read everything in this section and related or linked articles to get a good idea of the procedure, and go to the pinecil community chat if you desire advice/support from experienced volunteers. Self-repairs or mods will void your warranty so proceed if this is not a concern. This information is for educational purposes only.
Pinecil V1 and V2 have slightly different schematics and have different MCU chips. Doing repairs often requires referencing the correct schematics or photos. The datasheets are also important to get information about the chips, and to order replacement parts. Chatting with other owners of Pinecil is encouraged as they have experience - already broke things so you don't have to (see pinecil volunteer chat link below).
Note: This is a new work in progress (WIP) started Feb. 18, 2023 which may be updated over time as various volunteers have time to write up information. For sections that are missing, try asking in the live chat as a volunteer may have some clues to get you headed in the right path.
Tools you need
  1. All Schematics, Datasheets for known common parts, and links to where to buy some replacement parts are all in the main Pinecil Wiki here.
    • Refer to the correct section for V1 or V2 parts.
    • Which model do I have? The older V1 model has an all black handle with a blue silicone grip and was discontinued in July 2022. The new V2 model has a black handle with a green thumb grib and is the only model PINE64 and authorized resellers started selling after August 1, 2022.
  2. Reference photos of the PCB boards here. Photos will help to chat with volunteers in the live pinecil chat channel.
  3. Digital Multimeter
  4. Optional, better Probe Leads: nice for electronic work and needle size makes things easier, needle size probes kit.
  5. Possibly another soldering iron to do the repair, some flux, solder, and Isopropyl Alcohol (IPA) for cleaning the PCB.
  6. Philips screwdriver for small screws.
  7. Magnyfying lamp or Jeweler's glasses with led light and good room light.
  8. Optional but helpful: mobil phone to take macro photos or video to share on the live pinecil chat during troubleshooting. Sample Macro lens for phone, there are cheaper ones that simply clip onto the phone.
  9. An oscilloscope is sometimes helpful but not needed for most repairs.
Disassembly steps
Easy trick to open the Pinecil, see Video here.
  13. Remove the round copper ring contact from under the PCB, near the tip end of the handle (this is installed first before the PCB because it provides ground contact from the front of the pinecil to the rear ground screw).
  14. Remove the two small round buttons so they do not get lost.
Assembly steps
  1. Place the two round buttons into the two holes in the top half of the case.
  2. Install the round copper ground contact at the tip end before installing the PCB.
  3. Place the PCB board into handle at an angle, DC barrel end goes in first.
  10. Gently insert tip.
Diagnosis & Testing
Common Fixes
  1. Sometimes, just updating to the newest firmware fixes issues as Ralim and team are very active in adding features and bug fixes enhancements (see Firmware).
  2. Some Troubleshooting information is also on Github Ralim's IronOS (which is the firmware that is on the Pinecil). There are several hidden Debug tools in the firmware that also help with diagnosis.
  3. If you can't find information here yet that you would like advice on, simply join the live pinecil chat channel which is volunteer run.
FAQ
  1. Help, I think I bricked Pinecil doing an update: no worries, it's very hard to brick a pinecil because of the way the firmware is loaded. Usually just flashing again with a newer or different version brings it back to life (see Firmware). This can be done even if you can't see your screen anymore.
  2. My Pinecil keeps rebooting: change to a different charger or add a ground wire to your pinecil ground screw (google ts100 ground wire). Also see the Power Supplies article. This happens with some 2-prong no-ground chargers. Also try to plug the charger into a surge protector strip (type that have 3-prong ground and plug into a grounded wall outlet). Try a different cable or flipping the cable over also.
  3. Tip is glowing red hot. Grats! you have a Glowcil. Unplug immediately, you have most likely a blown mosfet, see Mosfet section.
  4. Temperature is flickering wildly: see Poor contact repair.
  5. Screen shows X symbol (no tip installed) and I have a tip installed. Remove the Tip screw, seat the tip all the way back, reinstalled the screw. See Tip Problems and Poor Contact repair.
  6. I am getting Thermal Runaway or Undervoltage messages on the screen. This is often caused by using a weak power supply that does not have a minimum of 12V-3amps not rated to work with Pinecil.
    • TL;DR get a Usb-c charger 20V 3.25 amps, PD 65W (best bang for the buck for good Pinecil performance) many available between $15-$25.
    • Detailed information on [Pinecil_Power_Supplies| Power Supply options here]].
  7. I plugged in the wrong kind of DC barrel charger, it was a not Center-positive pin and now the pinecil won't turn on: see Reverse polarity damage, MOSFET repair, and Buck Converter repair.
  8. I hear a sizzling/crackle sound from my new Pinecil: this is usually ok and may disappear after a few days of use, see Hissing Crackle Sound.
  9. Screen is black and won't turn on:
MOSFET repair
testing and repair. under construction
LDO repair
OLED screen repair
FUSB302 repair
Op-Amp repair
  1. The sizzle sound will usually go away after a few days of use and heating up the iron. After wiping the tip contacts with IPA, heat it up a few times to 350 °C.
  2. Ralim said, "there is usually a bit of noise when you first use it, and a slight hiss/pop noise from the handle and that is normal. depends a bit on exactly what batch of caps are in your unit. The Tip drive signal is AC coupled through a cap[acitor] for safety, downside is that it means the firmware is hitting that cap with a square wave the whole time the tip is on. Once you have heated up the duty cycle, it drops off so it's not as noticeable.
  3. Some members reported that after they opened their new Pinecil, wiped the PCB and tips gently with IPA, let it dry, all the sizzling noise went away. They also did a break-in of the new tips, bringing the temperature to 350 C a few times.
  4. Video of similar crackle sound on the ts100 iron (don't have example of pinecil, but it's similar sound).
Reference the article on DC barrel chargers, i.e., laptop bricks. Needs more blah blah here.....
Tip Problems
  1. Wipe tips clean, details in Poor Contact section
  2. Using a multimeter, switch it to ohms to measure resistance. Measure the two silver band at the white or rear end of the Tip.
  3. If it measures OL or infinity, or extremely out of the spec range below, it is bad. It should measure close to the specs.
    • Normal ts100 style tips should measure ~7.8 ohms - 8.3 ohms.
    • PINE64 brand Short tips should measure ~6.1-6.5 ohms.
    • See the Pinecil Tips Article.
Poor Contact repair
  1. Poor contact could happen if the tips are not clean or brand new with factory residue or not making good contact with the internal clips inside the pinecil. The two contacts inside might need to also be removed, wiped and reinstalled with the two screws (ensure the small metal tab on the clip sits into the small hole in the PCB).
  2. Most likely the tip is not making good contact. Usually this issue goes away after a few days of use as the tip rubs against the contacts more. New tips could have factory residue on them from handling.
  3. To fix this issue quicker, wipe all new tips or old tips with a dry towel or 90-99% IPA (isopropyl alchohol) especially the two silver contacts at the white plastic end (do not use water to wipe it which could get into the seam line on the white end).
  4. With the pinecil unplugged, remove and reinsert the tip a couple times and spin it a little inside against the contacts. Then plug it in and heat it up to 350C a few times for a couple minutes.
  5. Always unplug pinecil before swapping tips. Hot swapping is not a good idea, and for the V2 this could cause strange behavior as the V2 auto-detects tip resistance only on power-up or reboot.
  6. Sometimes just disassembling and reassembling all parts back correctly and installing the 2 internal contacts with screws correctly also helps.
Pinecil V1, 24V Mod
Warning: do this at your own risk, read everything in this section and related/linked articles, and go to the pinecil community chat if you desire advice. An incorrect cut of the trace could render the Pinecil non-working.
  1. This modification is not for the V2 as the newer V2 already has 24V DC capability.
  2. If you have an older V1 model, then first upgrade to the newest Firmware before starting this modification. The PD debug menu was added to the firmware in 2.17 and other important fixes came later. Access to the hidden PD debug menu is necessary to assist with this mod.
  3. See Ralim's IronOS for how to use the hidden PD Debug menu and check if your version of Pinecil V1 could benefit from the modification.
  4. Some models of V1 came with the PCB already capable of 24V. Do the PD Debug test first to see if the mod is not required.
  5. See the February 2022 Community update. The Photo is incorrect in the article. It is not a before and after photo. They are two separate photos of two different V1 pinecils which have slightly different PCB and therefore have the trace cut in a slightly different location. One PCB came with 2 Via holes and is harder to modify and cut in the correct location to avoid damaging the via holes.
Go back to Pinecil article
Go back to the main Pinecil article.
