Pinecil: Test, Repair, Issues
This is a WORK in PROGRESS... under construction.
Cautions
Warning: while opening your pinecil will not necessarily void your warranty, all self-repairs are done at your own risk. Read everything in this section and related or linked articles to get a good idea of the procedure, and go to the pinecil community chat if you desire advice/support from experienced volunteers. Self-repairs or mods will void your warranty so proceed if this is not a concern. This information is for educational purposes only.
Pinecil V1 and V2 have slightly different schematics and have different MCU chips. Doing repairs requires referencing the correct schematics. The datasheets are also important to get information about the chips, and to order replacement parts. Chatting with other owners of Pinecil is also encouraged as they have experience - already broken things so you don't have to (see pinecil volunteer chat link below).
Note: This is a new work in progress (WIP) started Feb. 18, 2023 which may be updated over time as various volunteers have time to write up information.
Tools you need
  1. All Schematics, Datasheets for known common parts, and links to where to buy some replacement parts are all in the main Pinecil Wiki here.
    • Refer to the correct section for V1 or V2 parts.
    • Which model do I have? The older V1 model has an all black handle with a blue silicone grip and was discontinued in July 2022. The new V2 model has a black handle with a green thumb grib and is the only model PINE64 and authorized resellers started selling after August 1, 2022.
  2. Reference photos of the PCB boards here. Photos will help to chat with volunteers in the live pinecil chat channel.
  3. Digital Multimeter
  4. Optional better Probe Leads: nice for electronic work and makes tasks easier, Test Leads with needle size probes kit.
  5. Possibly another soldering iron, some flux, solder, and Isopropyl Alcohol (IPA) for cleaning the PCB.
  6. Philips screwdriver for small screws.
  7. Magnyfying lamp or Jeweler's glasses with led light and good room light.
  8. Optional but helpful: mobil phone to take macro photos or video to share on the live chat during troubleshooting. Sample Macro lens for phone, there are cheaper ones that simply clip onto the phone.
  9. An oscilloscope is sometimes helpful but not needed for most repairs.
Disassembly steps
Easy trick to open the Pinecil, see Video here.
  13. Remove the round copper ring contact from under the PCB, near the tip end of the handle (this is installed first before the PCB because it provides ground contact from the front of the pinecil to the rear ground screw).
  14. Remove the two small round buttons so they do not get lost.
Assembly steps
  1. Place the two round buttons into the two holes in the top half of the case.
  2. Install the round copper ground contact at the tip end before installing the PCB.
  3. Place the PCB board into handle at an angle, DC barrel end goes in first.
  10. Gently insert tip.
Diagnosis & Testing
Tips
  • Sometimes, just updating to the newest firmware fixes issues as Ralim and team are very active in adding features and bug fixes enhancements (see Firmware).
  • Some Troubleshooting information is also on Github Ralim's IronOS (which is the same firmware that is on the iron). There are several hidden Debug tools in the firmware that also help with diagnosis.
  • If you can't find information here yet that you would like advice on, simply join the live pinecil chat channel which is volunteer run.
FAQ
  1. Help, I think I bricked Pinecil doing an update: no worries, it's very hard to brick a pinecil because of the way the firmware is loaded. Usually just flashing again with a newer or different version brings it back to life (see Firmware).
  2. My Pinecil keeps rebooting: change to a different charger or add a ground wire to your pinecil ground screw (google ts100 ground wire). Also see the Power Supplies article.
  3. Tip is glowing red hot. Grats! you have a Glowcil. Unplug immediately, you have most likely a blown mosfet, see Mosfet section.
  4. Temperature is flickering wildly: see Poor contact repair.
  5. Screen shows X symbol (no tip installed) and I have a tip installed. Remove the Tip screw, seat the tip all the way back, reinstalled the screw. See Poor Contact repair.
  6. I am getting Thermal Runaway or Undervoltage messages on the screen. This is often caused by using a weak power supply under 12V 3amps not rated to work with Pinecil.
    • TL;DR get a Usb-c charger 20V 3.25 amps, PD 65W (best bang for the buck for good Pinecil performance) many available between $15-$25.
    • Detailed information on [Pinecil_Power_Supplies| Power Supply options here]].
  7. Screen is black and won't turn on
MOSFET: test and repair
Buck Converter: test and repair
LDO: test and repair
OLED screen: test and repair
FUSB302: test and repair
Op-Amp: test and repair
How to test Tips =
  1. Wipe tips clean
  2. Using a multimeter, switch it to ohms to measure resistance. Measure the two silver band at the white or rear end of the Tip.
    • Normal ts100 style tips should measure ~7.8 ohms - 8.3 ohms.
    • PINE64 brand Short tips should measure ~6.2-6.5 ohms.
    • See the Pinecil Tips Article.
Poor Contact test and repair
  1. Poor contact could happen if the tips are not clean or brand new with factory residue or not making good contact with the internal clips inside the pinecil. The two contacts inside might need to also be removed, wiped and reinstalled with the two screws (ensure the small metal tab on the clip sits into the small hole in the PCB).
  2. Most likely the tip is not making good contact. Usually this issue goes away after a few days of use as the tip rubs against the contacts more. New tips could have factory residue on them from handling.
  3. To fix this issue quicker, wipe all new tips or old tips with a dry towel or 90-99% IPA (isopropyl alchohol) especially the two silver contacts at the white plastic end (do not use water to wipe it which could get into the seam line on the white end).
  4. With the pinecil unplugged, remove and reinsert the tip a couple times and spin it a little inside against the contacts. Then plug it in and heat it up to 350C a few times for a couple minutes.
  5. Always unplug pinecil before swapping tips. Hot swapping is not a good idea, and for the V2 this could cause strange behavior as the V2 auto-detects tip resistance only on power-up or reboot.
  6. Sometimes just disassembling and reassembling all parts back correctly and installing the 2 internal contacts with screws correctly also helps.
Pinecil V1, 24V Mod
Warning: do this at your own risk, read everything in this section and related/linked articles, and go to the pinecil community chat if you desire advice. An incorrect cut of the trace could render the Pinecil non-working.
  1. This modification is not for the V2 as the newer V2 already 24V DC capability.
  2. Upgrade to the newest [Pinecil#Firmware_&_Updates Firmware] before starting this modification. The PD debug menu was added to the firmware in 2.17 and other important fixes came later. Access to the hidden PD debug menu is necessary to assist with this mod.
  3. See Ralim's IronOS for how to use the hidden PD Debug menu and check if your version of Pinecil V1 could benefit from the modification.
  4. Some models of V1 came with the PCB already capable of 24V. Do the PD Debug test first to see if the mod is not required.
  5. See the February 2022 Community update. The Photo is incorrect in the article. It is not a before and after photo. They are two separate photos of two different V1 pinecils which have slightly different PCB and therefore have the trace cut in a slightly different location. One PCB came with 2 Via holes and is harder to modify and cut in the correct location to avoid damaging the via holes.
Go back to Pinecil article
Go back to Pinecil article.
