Pinecil
Revision as of 22:14, 28 October 2020 by Fxc (talk | contribs) (https)
PAGE UNDER CONSTRUCTION, INFO SUBJECT TO CHANGE
  • Pinecil Renders:
  • Pinecil Prototype:
Specifications
  • Memory:
    • 128KB Flash
    • 32KB SRAM
  • DC in (only one of the following at a time):
    • 12V- 24V DC5525 Barrel Jack
    • USB-C 12-20V PD
    • QC3.0
Pinecil board information, schematics and certifications
  • Pinecil Mainboard and breakout board: Pinecilmainboardandbreakbout.jpg
  • Pinecil certifications:
Pinecil tips
  • Default tip model TS-B2 accompany with Pinecil
  • Tip set 1 (left) & 2 (right): PinecilTipSets.jpg
  • Uses TS-100 compatible tips
Development efforts
Project Homepage Project Source Implementations
Ralimtek https://ralimtek.com https://www.gitmemory.com/Ralim
