Pinecil
Revision as of 16:39, 16 February 2023 by Fxc (talk | contribs) (→‎Live Community Chat: Discord still not the source of truth)
Pinecil is a portable soldering iron with computer controlled temperature, sleep modes, motion detection, and allows many options for power from AC supplies (USB-C, DC Barrel) to external tool/lipo batteries. You may already have a power supply that works. It also has the intended use of being a RISC-V development device using a breakout board. The Pinecil has evolved over the years from a 60W device into the latest rendition, the V2, which supports 24V/88W and includes the new Pine64 designed shorter tip.
Note: Other irons only care if they can solder. The Pinecil is held to an additional standard; how well can it meet the needs of the open source community as a RISC-V development tool. It includes hardware features not found on other soldering irons in order to support FOSS community feature requests for both fun and science.
Pinecil V2, side view
Pinecil Soldering Iron: main features
  • Soldering tips:
  1. Replaceable and low cost
  2. Many styles: Currently sold as 2 separate sets of 4, one fine set, the other larger.
  • Multiple power sources will work for more flexibility:
Authenticity
There are no PINE64 Pinecils sold on AliExpress. They are not made by PINE64. There are no authorized resellers on AliExpress. Some manufacturer has copied the PINE64 company name, trademark and Pinecone logo and is selling a product made to look like Pinecil through many store fronts, but it is not an authentic. They use a different type of box, i.e., a blue or red box. They are fake copies and do not go through the same quality control as Pine64. It is unclear what type of chips or poor quality cloned chips are used in them. They are not recommended. Genuine Pine64 Pinecil only comes only in a black handle color with a silicone thumb grip. The original V1 always came in a black box. This model was discontinued and has not been made or sold by PINE64 or authorized resellers since July 2022.
Pinecil V2 comes with a unique internal ID/Serial number. Check if your Pinecil is Authentic here:
Where to buy a Pinecil
PINE64 Official Stores
PINE64 EU
Affiliates
In July 2022, all final stock sold out of PINE64 Pinecil V1 (with GD32VF103 MCU) at the Pine Store & all resellers. There are zero new authentic Pinecil V1 sold in the world after July 2022. Pinecil V1 was made in a black color with a sky blue finger grip. PINE64 never made an all-blue Pinecil, and never used blue or red color boxes (those are fake copies with fake PINE64 logos and Pinecone).
Starting Aug. 2, 2022, only the new Pinecil V2 model with the new BL706 BLE bluetooth MCU are made by PINE64 and sold at all authentic resellers. They are black with a green finger grip (see photos in the Picture section). The new model has anti-counterfeiting features. Authentic Pinecil using the newest official Github IronOS firmware, will successfully pass the Authenticiy Checker website. If a new Pinecil does not have a BL706 chip, then it is a fake counterfeit. If the AliExpress seller tries to show "CE certification" documents as some type of proof, those are all copied public info from this Wiki page in the Certifications section. PINE64 publishes those as they are the CE/FCC certifications for the stamps on the Pinecil. They are not proof of purchase from the Pine Store Ltd.
Shipping & Tracking
The information regarding shipping and tracking can be found in the article Shipping and Tracking. The article includes the following topics:
  1. How does it work?
  2. Courier options
  3. Tracking
Usage
Overview
  1. Install the Tip: The Pinecil comes with a separate heating element, the tip.
    1. Remove the screw from the front top-side of handle. Then, gently push the tip all the way back until the wide collar/guard is touching the front of the plastic (see the photo).
    2. Gently tighten/loosen this screw to install or swap the tip. (careful, tiny screws break easy, if tip does not fall out, it's tight enough)
    3. The bottom front screw should not touch the tip, it only holds the handle together (see fasteners).
  2. Supply Power: the USB-C port, connected to any supply, is enough power to show the display screen, but not necessarily enough to heat the tip.
  3. Heat the Tip: plug Pinecil into an appropriate power supply.
    2. The detailed display option shows power draw, current temperature, supply voltage, and estimated time to reach target temperature.
  4. Using the Settings Menu:
    1. To check the firmware version, hold down the [-] button. It will display something like "v2.19.A3BBABC 13-07-22"
      1. This is the firmware number and release date, the date is July 13, 2022 in the example.
    2. Clicking [-] when heat is off steps through main categories menus to control a variety of settings, see Getting Started section.
    4. Click [-] to scroll to the the main menu section desired (i.e., User Interface). Then Click [+] button to change various internal settings. Then click [-] again to go to the next item in the sub-menu.
  5. Important notes:
    2. Calibration of the Tip temperature is usually not necessary and should only be done if the tip is off by +/- 5 °C or temperature is behaving oddly. See instructions to calibrate the tip in the firmware on Github IronOS.
    4. To heat up the tip, we need a power supply that can provide at least 12V 3A to run. This is the bare minimum. Pinecil will heat slowly at only 12V/3A. To maximize performance, higher Volts/Amps/Watts is recommended (see Pinecil Power Supplies).
      1. Option 1: a USB-C supply that can negotiate up to such a voltage. For maximum performance and good soldering experience, a USB-C PD65W, 20V, 3+ A charger is recommended (suitable for most users).
      3. Option 3: use a battery, i.e., an 18V-21V tool Battery with a Power Wheels adapter, and a cable to plug into the Pinecil DC5525 barrel jack.
      4. You may have a suitable supply already that could be used, (see Pinecil Power Supplies).
      5. While 12V-3A will work, it will not heat the tip as quickly and efficiently as a PD65W-20V Usb-C charger or a higher rated DC barrel charger.
Getting Started with the Menu
  • Main Settings Menu: updated list is found in the firmware repository Settings Menu
Community Advanced Modifications
Live Community Chat
  • Need troubleshooting advice for the Pine64 Pinecil soldering iron?
  • Join one of the Community Chat links below
Pine64 live chat is bridged to Discord, Telegram, Matrix and IRC. Those bridges will not have all the features available within all platforms, but the chat is relayed between all four.
Live chat has volunteer members that are not paid PINE64 employees, but occasionally get official information.
Firmware
The firmware that comes with the Pinecil is open source Ralim's IronOS. It's a good idea to check for updates regularly as development is very active and there may be enhancements or new bug fixes available.
  • Long hold down [-] to see the version
Update Pinecil V2
The V1 and V2 use different Flasher software & firmware files because they have different MCU and features. However both connect to the PC/laptop and enter the Flash mode in the same way, by holding down the (-) button:
  1. Long hold the [-] button **before** plugging the usb-c cable into the back of the Pinecil. Keep holding down the [-] for ~15 seconds after plugging in the cable, then release the button.
  2. Screen should be black/empty which means you are in Flashing Mode. If you have issues, try again, do not plug the usb-C cable into Pinecil until you first press & hold the [-] button. Flip the cable over or try another port if you still have issues.
  3. Pinecil is designed to use only 1 port at a time. Only the USB-C cable should be plugged in during Updates. Never attempt to use both rear ports at the same time or your PC and Pinecil will be damaged.
  4. Use the different flashers below to write new firmware to your Pinecil ([[#How_to_Update_Pinecil_V1|older V1 instructions are lower down here]).
V2 Windows
  1. For V2, download the CLI Windows Blisp Flasher here.
  2. Extract the blisp zip. Run windows powershell as administrator, cd to the blisp folder.
  3. Download the latest stable Pinecilv2.zip Releases here. Scoll down to the Assets to get the zip files (works for EPR 140W chargers).
  4. Grab and Put Pinecilv2_EN.bin (English) file or language chosen into the blisp folder (same place as the blisp executable).
    • If you have the Pinecil Zip, the rest could be deleted, only the single BIN file is needed. Select the appropriate 2-letter code for your language.
  5. Connect the V2 to the PC (see Connecting above). If you are curious, it will connect as a Serial COM device in device manager.
  6. cd to the blisp folder, and Execute this line. (replace the EN file with any language bin filename you choose).
  7. .\blisp.exe write -c bl70x --reset .\Pinecilv2_EN.bin
  8. Hold down [-] for 3 seconds to see the version.
Note: To test the new beta BLE bluetooth website, get BLE firmware here (also works with EPR 140w chargers). Instructions here
See Troubleshooting down below if it does not flash
V2 Linux
  1. For V2, download the CLI [[File:Blisp_Linux_x86.tar.gz|Linux Blisp Flasher here (x86)].
  2. Extract the Blisp and cd to the blisp folder.
  5. Connect the V2 to the PC (see Connecting above). It will connect as a serial ttyACM USB ACM type device.
  6. cd to the blisp folder and execute:
  7. sudo ./blisp write -c bl70x --reset Pinecilv2_EN.bin
Troubleshooting V2 Flashing
  1. Often times, issues are related to the USB cable, try flipping the cable over, or try other ports on the PC. Don't use a hub, connect directly to a port, ports on the back of a PC may be better as they are directly connected to the motherboard. USB-C to C cables sometimes works better than USB-A to C cables (your cable may be power-only and not able to do firmware data transfers). Try using a USB-C to C cable on a C port and not a USB-A to C cable.
  2. Try holding down the [-] the whole time (don't release) - if you had to do this, let Gamiee know in the GitHub Blisp Issues ticket here.
  3. Blisp flashers are from Gamiee's open source Blisp code here. It is only an updater for the BL706 MCU on Pinecil V2 (means it "writes" to the V2 chip). It is separate from the firmware files needed which are in located in Github Ralim's IronOS.
  4. If there is a problem with the flasher, or you have a different Linux architecture like ARM, you could also build it from code, see directions at GitHub Blisp.
  5. If you have issues completing the update, join the bridged Pinecil community channel.
  6. If the blisp flasher is not working, open a ticket here: <https://github.com/pine64/blisp/issues>
  7. If you are running Windows VM emulator, & it fails, make sure you have MS "Visual C++ 2015-2022" installed.
  8. All firmware releases and betas are located in the GitHub Ralim's IronOS here. If you would like to add enhancements/features to the IronOS that runs the Pinecil or have issue with it, please look at the Github link or submit an issue ticket. It is recommended to read through all the Github IronOS documents first as they may have the answers. The screen menus and troubleshooting is documented as well.
Update Pinecil V1
Connecting a V1 or a V2 to a laptop or PC for Flashing/Updating is the same method, but the Flasher used is different because they have a different MCU and capabilities.
  1. Long hold the [-] button before plugging the USB-C cable in. Keep holding down the [-] for ~15 seconds after plugging in the cable, then release the button.
  2. Screen should be black/empty which means you are in Flashing Mode. If you have issues, try again, do not plug the USB-C cable into Pinecil until you first press & hold the [-] button. Flip the cable over or try another port if you have issues.
  3. Pinecil is designed to use only 1 port at a time. Only the USB-C cable should be plugged in during Updates. Never attempt to use both rear ports at the same time or your PC and/or Pinecil could be damaged.
  4. See the version installed by holding down [-] for 3 seconds.
  • V1 Windowsor Mac
  1. For V1, follow these instructions on GitHub and download the Pine64 Easy Gui Updater
  • V1 Linux
  1. For V1, download Pineflash GUI for Linux or Mac
  2. Or could use a command line DFU per IronOS instructions
General Firmware Details
  • One advantage of Pinecil (V1/V2) over other irons (i.e., Miniware) is you can not really brick them since Pinecil's bootloader is in rom. If there is a problem, just flash the firmware again or a different version. This empowers people to experiment and do forks of the main IronOS firmware.
Development Projects
Author Project Homepage Description
Ben Brown (ralimtek) Ralim's IronOS Official Pinecil firmware
Marek Kraus (gamiee) Pinecil V2 Flasher Windows/Linux/Mac CLI Updater for BL70x
Marek Kraus (gamiee) Pinecil V1 Flasher Windows & Mac GUI Updater
Arkaitz Goni Hedger (spagett) PineFlash V1 Flasher Linux & Mac GUI Updater
Joric (iamjoric) BLE API for V2 Github dev page
Robert (builder555) BLE Settings for V2 BLE script to change Pinecil settings
Bouffalo Lab Official Bouffalo B-Lab Dev Cube generic GUI for Dev/flashing BL706
Alvin Wong gd32vf103-pinecil-demo-rs Rust code demos for Pinecil
Checklist
1. Clean new tips with isopropyl alcohol to remove factory residue before installing (avoid strange behavior from poor contact). If you have none, try to wipe it down with dry clean towel especially the 2 contacts at the back (do not use water, it could get into the small white seam line).
2. Don't bend the tiny internal contacts, they are thin spring metal and may break.
3. Only use one port, USB-C or the DC barrel, but Never both at the same time. Damage will occur to PC/ Laptop/ Pinecil !
    • Caution: do not plug in both USB-C and DC5525 at the same time. This will destroy devices, posibly your laptop/pc.
  2. It gets full power.
    • Check both orientations of the type C cable (try to flip it if one way doesn't work)
  3. Check Update mode (see Ralim/IronOS for details on flashing updates)
    • Note: do not connect the DC barrel at the same time as a USB-C cable. Pinecil was designed to only have one cable plugged in a a time. You could damage devices doing this.
    • V2 needs a different type of Updater/flasher which will be announced on Github/Ironos when a new release is available.
      • V2 owners with EPR 28V chargers are advised to join the Community chat linked in the wiki & use Beta 2.20 firmware until stable is released.
      • If you have issues with V2 firmware, create a new Github Issues ticket
    • V1 can use Pine64 Easy Updater here (Windows/MAC)
    • Requires a data capable USB cable connected to a laptop or some appropriate device.
    • To enter update mode, hold down [-] (button near back/ground screw) while plugging in USB cable.
    • Screen is black/blank if you are correctly in update mode. This can be tested even if you are not updating the firmware.
  4. Both buttons work
    • - to enter menu or decrease temperature, long press to get software version info or to turn off heating
    • + to turn on heating or select a menu item
  6. All 3 external screws are present
    1. One near the back near the screen (ground screw)
    3. One at the front on the bottom (to hold the case together)
  7. The tip is clean (uniformly silver at the front, with no pitting or texture)
    • most tips come with pre-dipped in solder for protection. heat them up, clean with brass or solder sponge and inspect.
    • See #Caring for a soldering iron for maintenance and soldering tips
  8. It heats up an installed tip, and stops increasing when it reaches the set point
    • This may draw up to ~3A, make sure the power supply can provide that
    • Minor overshoot may occur, but, disconnect power if the temperature keeps going up
  9. The reported temperature is correct
    • If no direct measurement is possible, set it to ~230°C and see if it just about melts SAC (lead-free) solder (~190°C for leaded)
  10. If there are multiple tips, clean all of them with IPA and check all of them.
  11. If the tip moves a little while using it, try to hold Pinecil with the screen sideways or screen downwards. Members found that if the screen is up and the screw loosens during use, then the tip wobbles a little. Changing holding angles helps the tip press against the solid barrel.
Power Supplies and Watts
Generally, higher watts = better, up to how much you can afford.
* PINE64 officially states V2 up to 24V-88W. Tentatively, V2 supports 28V-140W EPR/PD3.1 chargers with certified EPR 240W usb-C cables.
  • Ralim's IronOS firmware supports EPR 28V-140W on Pinecil V2 models.
  • EPR Usb-C is new to the market in 2022; they are expensive and require EPR PD 3.1, 240W cables.
  • EPR is backwards compatible for all USB-C devices. EPR chargers/cables can be used for everything else Usb-C as well.
  • Ralimtek: "Please understand wattages [detailed screen] are wild estimates and are at best +-10%. Use external metering for any comparisons." Pinecil is not a USB-C tester, the watts shown on detailed screen mode is a big picture number for convenience of debugging various chargers used. It is not going to be as accurate as an external tester. External testers also cause a small reduction in watts.
Quick Charge or QC3 is not recommended as Pinecil V2 requires a minimum of 3 Amps or more to work properly (see Pine Store Official rating on power ports). Most QC 12V phone chargers are only 1.5 Amps, this will lead to Thermal Runaway or Undervoltage messages because of weak power (QC2 does not work at all as it is not supported in the firmware).
Click here for compatible power supplies and cables
Specifications
Pinecil V2
  • Chipset: Bouffalo BL-706
  • Memory:
    • 192KB Internal Flash
    • 132KB SRAM System
Pinecil V1
  • Memory:
    • 128KB Flash
    • 32KB SRAM
Fasteners/Screws
  • Originals screws are Phillips (source): two M2x3mm at the front, and one M2x4mm is the ground screw near the [-] minus button.
Thumb Screws
  • Thumbs screws are popular upgrades: an M2 x 4mm thumb screw could replace both the screen-side Tip holder screw and the rear end ground screw.
Manuals
Disassembly steps
Video of Alternate Method for opening Pinecil here.
  13. Remove the round copper contact under the PCB, near the tip end of the handle (this is installed first before the PCB).
  14. Remove the two small buttons so they do not get lost.
Assembly steps
  1. Place the key caps into their recesses in the top half of the case.
  2. Install the round copper ground contact at the tip end before installing the PCB.
  3. Place the PCB assembly into handle at an angle, DC barrel end goes in first.
  10. Gently insert tip.
Pictures
Pre-release:
Production:
PCB:
Accessories:
Pinecil Tips
Information regarding the Pinecil Tips can be found in the Pinecil Tips article.
  1. What kind of tips work?
  2. How to increase tip life?
  3. How does the tip work/science?
  4. Pine64 Short Tips
  5. Pine64 Normal Tips
Pay attention to the length! Pine Store sells two different lengths.
Guides to Soldering & Maintenance
The guides regarding soldering and maintenance can be found in the Pinecil Guides to Soldering article. The article includes the following topics:
  1. General Soldering Guides
  2. Does Solder type and Flux matter?
  3. How to keep the Tip Clean?
  4. What Temperature should I use?
Cases, Stands, 3D Models, Supplies
The main article about cases, stands, 3D-models and supplies can be found under Pinecil Cases Stands Supplies.
  1. Cases/Bags
  2. Holder/Stands
  3. 3D Printable Models
  4. Soldering Supplies
Batch changes
V2
  • On Aug. 2, 2022, Pinecil V2 was released with improved hardware & accessories. It retains the same ergonomics and design as the original Pinecil, and will work with any accessories you already have including existing cases and tips. It comes with a green color silicone grip versus the light blue finger grip from Pinecil V1. It also includes one of Pine64's newly designed shorter 6.2 ohm tips. By reducing the tip resistance from 8 to 6.2 ohms, it allows greater performance and and faster heating (64W @ 20V compared to 8ohm tips which allowed a max of 50W to Pinecil). Pinecil V2 is rated for 12V-24V.
  • Key changes in V2: new processor (BL706), higher maximum input voltage (24V), tentative support for USB-PD3.1 EPR (28V), support for measuring tip resistance, allows automatic detection of 6.2 vs 8 ohm tips. A notable improvement is the new BL706 RISC-V processor from Bouffalo. It is similar to the BL602 in the Pinenut. The BL706 features Bluetooth Low Energy (BLE / Zigbee); future IronOS firmware releases will work to expose features over BLE. This is not trivial work, but as people contribute to the opensource code of Github/IronOS, the BLE will be expanded.
V1
  • For the first manufacture batch (October 2020, order number 158xxx) of the Pinecil, the copper ring connecting the earth screw to the tip was omitted as the engineering team found the TS100 design lacking. For the second round onward, an improved design copper ring has been included as standard, and is also included with the replacement clear and black handles. For normal operation of the iron, omission of the ring does not impact it's operation. If you are working with ESD components, you will need it in order to ground the iron tip via the earth screw at the back of the iron.
  • The first batch of Pinecils were rated 12-24v @ 65W. After some heated discussion on the discussion group, it was decided that it would be downgraded to 12-21V @ 60W, due to concern over the connection of the DC jack to the USB-PD chip, which has a recommended maximum of 21v, and absolute maximum of 28v.
Schematics, Board Data, Certifications
Pinecil V2 mainboard schematic
Pinecil V2 Certifications:
Pinecil V1 mainboard schematic
V1 was only sold until July 2022, and then discontinued for newer V2 model.
Pinecil V1 Certifications:
Pinecil Breakout board
Get the Breakout Board here
Photos:
Pinecil V2
USB-C PD Controller data:
Power Regulators:
Sensor data:
Power MOSFET Switch:
Operational Amplifier:
Display Screen OLED:
MCU: Bouffalo Labs, BL-706_QFN48, RISC-V + 2.4 GHz RF SoC Information:
USB-C port, possible part, has not been verified. Replacement here: USB C Port
Pinecil V1
GigaDevice RISC-V SoC data:
Sensor data:
Display Module data:
USB Type-C PD Controller data:
Power Regulator data:
Power MOSFET Switch data:
OP Amp information:
Capacitors:
LowPowerSemi LP6498B6F 1.2A Switching Power Regulator Datasheet - on breakout board
Pinecil in the Media
Humor
Video Reviews
Pinecil V2 Reviews:
Pinecil V1 Reviews:
