Pinecil
Revision as of 23:35, 5 September 2022 by River (talk | contribs) (→‎Overview)
Pinecil Version 2
The Pinecil is a portable, temperature controlled soldering iron. It also has the intended use of being a Risc-V development device using a breakout board.
Authenticity
The Pinecil's main features are:
  • Portability
  • Settable temperature
  • Soldering tips:
    • Replaceable
    • Many styles available. Currently sold as 2 separate sets of 4, one fine set, the other larger.
    • Compatible with TS100
  • Flexible power sources:
    • DC 5525 Barrel jack
    • USB Type C power delivery
    • Battery: 3S/4S/5S LiPo batteries or 18V-21V Lithium-ion tool batteries
  • Pinecil V2 has a BL706 chip, see batch changes below.
    • Board schematics are open. Software is open. Create your own!
    • Pinecil breakout boardlets you use JTAG, GPIO, A2D, SPI, and more.
There are additional features that include (Useful for devkit use):
  • A Programmable Risc-V BL706 embedded processor
  • 0.67" Monochrome Display that can render text or graphics
  • Support for Idle detection, for automatic power down of tip
  • Programmable with tools from Gigadevice, HomeBrew or Linux RISC-V.
There are no PINE64 Pinecils sold on AliExpress. They are not made by PINE64. There are no authorized resellers on AliExpress. Some manfacturer has copied the PINE64 company name, trademark and Pinecone logo and is selling a product made to look like Pinecil through many store fronts, but it is not an authentic. They use a different type of box, i.e., a blue or red box. They are all fake copies and do not go through the same QC as Pine64. It is unclear what type of chips or poor quality cloned chips are used in them. They are not recommended. Genuine Pine64 Pinecil only comes in a black color with a silicone thumb grip (sky blue V1, teal green V2). The original V1 always came in a black box. This model was discontinued and has not been sold by PINE64 or authorized resellers since July 2022.
The current official Pinecil (a.k.a. V2) only comes in a white box (see Pictures), it has a black color handle with a teal green silicone thumb grip. If you receive anything that has the PINE64 brand name and Pinecone and does not look like described, it is a fake copy that was not made or authorized by PINE64 or the Pine Store Ltd (see Authenticity Checker below, all real PINE64 Pinecils purchased after Aug. 2, 2022 should pass the checker if they are a genuine PINE64 Pinecil).
Pinecil V2, released Aug. 2, 2022, uses a different chipset from V1. Each V2 comes with a unique internal ID/Serial number. If you want to check if your Pinecil V2 is Authentic, go here:
Where to buy a Pinecil
PINE64 Official Stores
PINE64 EU
Official affiliates
Other sites selling real Pinecil
In July 2022, PINE64 and all authorized resellers above sold out of all Pinecil V1 models with the GD32VF103 MCU. All production of this model also stopped. There are zero new authentic Pinecil V1 sold in the world after July 2022. Pinecil V1 was made in a black color with a sky blue finger grip. PINE64 never made an all blue pinecil, and never used blue or red color boxes (those are fake copies with fake PINE64 logos and Pinecone).
Starting Aug. 2, 2022, only the new Pinecil V2 model with the new BL706 BLE bluetooth MCU are made and sold. They are black with a green finger grip (see photos in the Picture section). The new model has anti-counterfeiting features. Authentic Pinecil V2 using the newest official Github IronOS, will successfully pass the Authenticiy Checker website.
Usage
Overview
Clean new tips with isopropyl alcohol IPA to remove factory residue before installing (to avoid strange behavior from poor contact).
Do not try to bend the two internal contacts, they are made of a stiff spring metal and could break (not soft copper), but you could wipe them with IPA (including the small PCB pad below the contacts).
  1. Install the Tip: pinecil comes with a separate heating element, the tip, which needs to be installed.
    1. Remove the screw from the front top-side of handle. Then, gently instert the tip and push it all the way back until the wide collar/guard is touching the front of the plastic (see photo).
    2. Gently tighten/loosen this one screw to install or swap the tip. (careful, tiny screws break easy, if tip does not fall out, it's tight enough)
    3. The bottom front screw should not touch the tip, it only holds the handle together.
  2. Supply Power: the USB-C port, connected to any supply, is enough power to show the display screen, but not necessarily enough to heat the tip.
    1. USB2 port at 5 volts (i.e., laptop) shows DC Low, this is enough for firmware updates and to view the menu, but not to run the soldering iron.
    2. See Power section for details on power for Pinecil. QC 12V phone chargers will not work, too weak
  3. Heat the Tip: plug Pinecil into an appropriate power supply.
    2. The detailed display option shows power draw, current temperature, supply voltage, and estimated time to reach target temperature.
  4. Using the Settings Menu:
    1. To check the firmware version, hold down the [-] button. It will display something like "v2.14.2425902 17-01-21"
      1. This is the firmware number and release date, the date is Jan. 17, 2021 in the example.
    2. Clicking [-] when heat is off steps through main categories menus to control a variety of settings, see Getting Started section.
    4. Click [-] to scroll to the the main menu section desired (i.e., User Interface). Then Click [+] button to change various internal settings. Then click [-] again to go to the next item in the sub-menu.
  5. Important notes:
    2. For Safety, unplug the soldering Iron when not in use or left unattended.
    3. To heat up the tip, we need a power supply that can provide at least 12V 3A to run. This is the bare minimum. Pinecil will heat slowly at only 12V/3A. To maximize performance, higher Volts/Amps/Watts is recommended (see Power Supply section).
      1. Option 1: a USB-C supply that can negotiate up to such a voltage. For maximum performance and good soldering experience, a USB-C PD65W, 20V, 3+ A charger is recommended (suitable for most users).
      2. Option 2: a supply with a standard DC 5525 barrel connector (+ pos center, - neg outside) that supplies anywhere from 12V to 21V (V1 Pinecil) or 12V-24V (V2 Pinecil).
      3. Option 2: use a battery, i.e., an 18V-21V tool Battery with a Power Wheels adaptor, and a cable to plug into the Pinecil DC5525 barrel jack.
      4. You may have a suitable supply already that could be used, (see Power Supply section below).
      5. See warnings about using random DC barrel chargers, not all of them have the correct polarity or DC 5525 style plug and some may be too high of voltage which could damage the Pinecil.
      6. While 12V-3A will work, it will not heat the tip as quickly and efficiently as a PD65W-20V Usb-C charger or a higher rated DC barrel charger.
Getting Started
  • Main Settings Menu: updated list is found in the firmware repository IronOS Settings Menu
    • Advanced settings: assorted catchall for settings that don't fit elsewhere or settings that require some thought before use. Restore factory settings is here. It will not change the firmware version, but rather resets the menu back to IronOS defaults. This is good to do after a major firmware update as settings may have been altered and need to be re-selected/customized again to work as expected.
Community links
  • Want to hang out with other PINE64 Pinecil owners or the PINE64 open source community?
  • Need troubleshooting advice on pinecil?
Join one of the Community Chat links
Discord Telegram Matrix
Specifications
Pinecil V2
  • Chipset: Bouffalo BL-706
  • Memory:
    • 192KB Internal Flash
    • 132KB SRAM System
Pinecil V1
  • Memory:
    • 128KB Flash
    • 32KB SRAM
Manuals
Firmware
The official firmware that comes with the Pinecil is open source IronOS. It's a good idea to check for updates regularly as development is very active and there may be enhancements or new bug fixes available.
  • To explore documentation on Menu or settings, submit a feature request, or help Ralim enhance the code, see GitHub Ralim/IronOS
  • One advantage of Pinecil (V1/V2) over other irons (i.e., Miniware) is you can not really brick them since Pinecil's bootloader is in rom. If there is a problem, just flash the firmware again or a different version. This empowers people to experiment and do forks of the main IronOS firmware.
Development efforts
Author Project Homepage Description
Ben Brown (ralimtek) Github Ralim/IronOS Official Pinecil firmware
Alvin Wong alvinhochun/gd32vf103-pinecil-demo-rs Rust code demos for Pinecil
Checklist
Clean new tips with Isopropyl alcohol to remove factory residue before installing.
  1. the display turns on when 5-24V is supplied (5-21V for older V1 models).
    • via USB type C or DC 5525 center positive barrel (check polarity)
    • caution: do not plug in both USB-C and DC5525 at the same time. This will destroy devices, posibly your laptop/pc.
    • The two ports are intended to be used indenpendently and not at the same time.
    • note that 5v shows DC low and is not high enough to run Pinecil. 5V is only enough for firmware update and to see the menu.
  2. it gets 20V from a 20V capable USB-C PD charger
    • check both orientations of the type C cable (try to flip it)
  3. Check Update mode (see Ralim/IronOS for details on flashing)
    • requires a data capable USB cable connected to a laptop or some appropriate device.
    • to enter update mode, hold down [-] (button near back/ground screw) while plugging in USB cable.
    • screen is black/blank if you are correctly in update mode. This can be tested even if you are not updating the firmware.
    • note: only plug in USB-C cable when doing Update mode, there should be no DC barrel connected at the same time.
  4. both buttons work
    • - to enter menu or decrease temperature, long press to get software version info or to turn off heating
    • + to turn on heating or select a menu item
  5. the displayed text rotates according to gravity when orientation is set to Automatic
  6. all 3 external screws are present
    1. one near the back near the screen (ground screw)
    2. one at the front on top (to hold the tip in)
    3. one at the front on the bottom (to hold the case together)
  7. the tip is clean (uniformly silver at the front, with no pitting or texture)
  8. it heats up an installed tip, and stops increasing when it reaches the set point
    • this may draw up to ~3A, make sure the power supply can provide that
    • minor overshoot may occur, but, disconnect power if the temperature keeps going up
  9. the reported temperature is correct
    • if no direct measurement is possible, set it to ~230°C and see if it melts SAC (lead-free) solder (~190°C for leaded)
  10. if there are multiple tips, check all of them
Potential Watts of different Power Supplies
*V2 models tentatively support 28V-140W EPR chargers with certified EPR cables. PINE64 officially states V2 up to 24V-88W.
  • Ralim's IronOS firmware supports EPR 28V-140W on Pinecil V2 models.
  • EPR is new to the market in 2022; they are expensive and require special EPR cables.
  • EPR is backwards compatible for all USB-C devices, so EPR chargers/cables can be used for everything else Usb-C as well.
QC is not recommended as Pinecil V2 requires a minimum of 3 Amps or more to work properly (see Pine Store Official rating on power ports). Most QC 12V phone chargers are only 1.5 Amps, this will lead to [Thermal Runaway] messages because of weak power.
Disassembly steps
Video of Alternate Method for opening Pinecil here.
  2. Remove the Tip.
  3. Let tip cool down.
  4. Loosen the top tip screw (PH1) (top is display screen side).
  5. Gently pull the tip out and set aside.
  6. Slide rubber thumb grip off towards the tip side.
  7. Remove the bottom screw (at the tip, between the feet) (PH1).
  8. Remove the ground screw (longer screw on the top side near the (-) button) (PH1).
  9. Slightly pull the two halves of the case apart at the tip front end, enough to get a fingernail or guitar pick between the halves.
  10. Move the pick down the length of the split to loosen the bottom half's clips from the top half of the case.
  11. Once loose, remove the bottom half by moving it forward (it is retained by the top half at the port side).
  12. Remove the screws retaining the copper tip contacts (PH000, M1.4 x 5), and note the direction.
  13. Remove the copper tip contacts.
  14. Flip the Pinecil over and the PCB should fall out, or it could be lifted gently up from the DC barrel end.
  15. The two small buttons are now loose, carefully set aside the top half, or remove the buttons so they do not get lost.
Assembly steps
  1. Place the key caps into their recesses in the top half of the case.
  2. Place the PCB assembly into the top half of the case ports first.
    1. Lower the rest of the board into the case and move the PCB assembly towards the port side of the case (the DC barrel connector may be a firm place to gently push).
  3. Install the copper tip contacts.
  4. Place the bottom half of the case into the top half by sliding the lip on the port side (side without the feet) of the bottom half under the arch of the port side of the top half.
  5. Gently close the case by bringing the two halves together, paying attention to each clip's alignment and ensuring the case edges align.
  6. Install the short PH1 screw at the bottom of the tip side of the case.
  7. Install the longer PH1 screw at the ground connection point at the top side of the case (between the display and the ports).
  8. Slide the rubber sleeve on (larger ridge first).
  9. Gently insert tip.
  10. Gently tighten the top PH1 screw to retain the tip.
Pictures
Pre-release:
Production:
PCB:
Pinecil tips
Sold at the Pine Store
  • Fine Tip set 1 (left) & Gross (large) set 2 (right):
  • Both sets are 8 ohm tips and are the standard length like other TS100 style tips
  • Pine64 Short tip is only 6.2 ohm for higher performance, 86mm length
  • Recommend PD65W-20V or better PSU when using short tips).
Common resistance for tips, from top to bottom:
  • Pine64 short tip 6.2 ohm, new
  • no brand long tip 7.9 ohm, new
  • Miniware long tip 8.0 ohm, new
  • no brand long tip 8.3 ohm, lightly used
The shorter tip is designed for higher performance but requires more power (minimum usb-C PD65W-20V charger recommended). For example with a PD65W-20V charger, the max watt with an 8ohm tip is 50W, and the max watt with a 6.2 ohm tip is ~64 watts (watts/volts calculator).
Caring for a soldering iron & guides
Guides to Soldering
Solder Tip Maintenance
What type of Solder and Flux Should I Get?
Cases and 3D Models
Batch changes
V2
  • On Aug. 2, 2022, Pinecil V2 was released with improved hardware & accesories. It retains the same ergonomics and design as the original Pinecil, and will work with any accessories you already have including existing cases and tips. It comes with a teal color silicone grip versus the sky blue finger grip from Pinecil V1. It also includes one of Pine64's newly designed shorter 6.2 ohm tips. By reducing the tip resistance from 8 to 6.2 ohms, it allows greater performance and and faster heating (64W @ 20V compared to 8ohm tips which allowed a max of 50W to Pinecil). Pinecil V2 is rated for 12V-24V.
  • Key changes in V2: new processor (BL706), higher maximum input voltage (24V), tentative support for USB-PD EPR (28V), support for measuring tip resistance, allows automatic detection of 6.2 vs 8 ohm tips. A notable improvement is the new BL706 RISC-V processor from Bouffalo. It is similar to the BL602 in the Pinenut. The BL706 features Bluetooth Low Energy (BLE / Zigbee); so future IronOS firmware releases will work to expose features over BLE. This is not trivial work, but as people contribute to the opensource code of Github/IronOS, the BLE will be expanded.
  • Things staying the same in V2: V2 still uses a RISC-V processor, but adds noticeable upgrades to the hardware. GPIO is broken out on USB-C for creating your own projects, same pinout as Pinecil V1, same great feel, including the rubber grip, works with all existing tips, same DC input + USB-C input connections, same case as V1 and compatibility with the clear/black/red cases.
  • In V2 labeling, the 88W figure comes from a 6.5ohm tip calculation. The reason for using 6.5ohm instead of 6.2ohm for the new short tips is due to tolerance during manufacturing, and leaving a margin of error. V2 set max voltage is listed as 24V because this was the value used during design and component selection.
V1
  • For the first manufacture batch (October 2020, order number 158xxx) of the Pinecil, the copper ring connecting the earth screw to the tip was omitted as the engineering team found the TS100 design lacking. For the second round onwards, an improved design copper ring has been included as standard, and is also included with the replacement clear and black handles. For normal operation of the iron, omission of the ring does not impact it's operation. If you are working with ESD components, you will need it in order to ground the iron tip via the earth screw at the back of the iron.
  • The first batch of Pinecil's were rated 12-24v @ 65W. After some heated discussion on the discussion group, it was decided that it would be downgraded to 12-21V @ 60W, due to concern over the connection of the DC jack to the USB-PD chip, which has a recommended maximum of 21v, and absolute maximum of 28v.
Pinecil board information, schematics and certifications
Pinecil V2
Pinecil V1
Power Supply Compatibility
  • Pinecil can either work with:
    • any USB-C power supply that supports PD (Power Delivery) specification (PD65W-20V recommended, but PD45W will work on V1).
    • DC barrel 12-21V battery or power supply using a DC 5525 (5.5mm outer diameter, 2.5mm post) center-positive jack
    • V2 can do DC barrel supply up to 24V without modyfying the PCB (check polarity, must have center-positive jack).
    • QC2, QC3: not recommended because too weak, need 3 Amp or better charger, and most QC have low amps. QC2 and most QC3 power supplies are only be able to provide at most 12V 1.5amp, limiting Pinecil to about 17W of thermal capability which is weak and slow and may get "Thermal Runaway" message (weak power).
  • USB-C PD type power supply / power bank that is 20V+/65W, allows the Pinecil to deliver the full 60W of heat to soldering tip.
    • USB PD type power supplies with at least 20V+/65W+/3amp+ is highly recommended (higher V/W/A will work too as long as it's PD type).
    • Magnetic tip USB-C cables are not recommended, and not USB compliant
  • Troubleshooting QC chargers: some QC power adapters only allow a limited time for QC negotiation, otherwise voltage will fall back to 5V.
    • To address this, starting from firmware v2.16+, there is a PD timeout setting (in 100ms steps) which allows QC negotiation to start earlier. Change this only if you are having issues with your QC charger. (Power Settings > PD timeout)
    • This enables some QC adapters to work (i.e., some Baseus QC chargers). Alternately, lowering the number may result in problems with PD negotiation on some PD type adapters that are slower to negotiate. If you switch between QC & PD adaptors, you may have to change this setting.
    • For certain QC adapters, lowering the PD timeout value to 15 could help, and most PD adapters will also still work using 15. If a PD charger does not work at 15, then increase the timeout (PD defaut is 20 = 20x 100ms = 2 seconds). Note that some QC chargers simply will not work, are too weak, or cheaply made.
Always check polarity of DC Barrel jack before plugging in a random charger or it could break the Pinecil.
Small sample of working PD/QC/Barrel power adapters / power banks:
Power adapter:
Adapters:
  • Elecjet AnyWatt SQ, USB-C to Lenovo Square Slim-Tip Adapter 45W or 65W, used with a 65W Lenovo Supply (PD@20V, Pinecil shows 64W)
  • Nintendo Switch AC Adapter (USB-C wall-wart) (PD@15V)
Power bank:
Limited usability:
  • Notebook Docking Station HP Thunderbolt Dock 230W G2 (PD@20V)
    • (had problems with lower firmware versions, but works fine Pinecil firmware: 2.15 and DockingStation firmware: 1.0.69.1)
  • Smartphone Charger Samsung EP-TA20EWE (QC2@9V)
  • Smartphone Charger Google Pixel G1000-US (PD@9V)
  • Notebook AC Adapter Delta Electronics ADP-65JH BB (DC@19V) and ADP-90CD DB (1.7x 4.8mm need adaptor, tip is not DC5525)
  • Notebook AC Adapter LITEON PA-1700-02 (DC@18.5V, 65W) (tip is 1.7mmx5.5mm would need adaptor for DC5525)
  • Nillkin 63W USB Car Charger Quick Charge 3.0 PD (Pinecil Firmware: 2.14.2425902)
    • QC3@9V/12V and PD@15V work, PD@20V doesn't
    • PD@20V works fine when using PDC004-20V or ZY12PDN on dc jack (DC@20V, limit: 45W)
Not compatible:
  • Smartphone Charger RAVpower 30W Dual USB Turbo Wall Charger (Should provide QC3@9V/12V, but only provides 5 V on both ports)
  • Sabrent HB-B7C3 USB3 hub, 7 data ports, 3 charge ports, 60W supply -- does not negotiate higher voltages.
