Pinebook Software Releases
Revision as of 08:05, 21 February 2018 by Joe (talk | contribs) (→‎NetBSD)
Linux Image Releases
Special thanks to Sunxi community, ayufan, and longsleep for their contributions
Xenial Mate eMMC
Xenial Mate Community Build Image [microSD to eMMC] [0.6.2-77] by ayufan
  • This is the default OS comes with Pinebook
  • This is microSD install to eMMC version. Please follow bootup screen to complete eMMC installation process
  • Included Mate Desktop, Firebox Browser, and LibreOffice Suite
  • Not yet optimize for Graphic and Video HW acceleration
  • DD image (for 8GB micoSD card and above):
  • Login with
    • username: pine64
    • password: pine64
Xenial Mate
Xenial Mate Community Build Image [microSD Boot] by ayufan
Xenial Minimal Image
Xenial Minimal Community Build Image [microSD Boot] by ayufan
  • This is the latest Xenial 16.04 image provided by ayufan based on longsleep base image. NB. This is a base image and doesn't come with a DE.
  • Login with
    • username: pine64
    • password: pine64
  • Execute sudo /usr/local/sbin/resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
  • To update to the newest uboot, kernel and fixes use scripts found in /usr/local/sbin/
  • Install Mate DE using: sudo /usr/local/sbin/install_desktop.sh
Armbian
Armbian Community Build Image [microSD Boot]
  • Armbian provides a build system and images for Debian/Xenial with BSP kernel and mainline kernel (beta)
  • Login with
    • username: root
    • password: 1234
  • To find out more about Armbian and available options please visit their site.
Arch Linux mainline XFCE
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
Q4OS
Q4OS Community Build Image [microSD Boot]
i3
i3 Community Build Image [microSD Boot] by ayufan
NetBSD
http://www.invisible.ca/arm/
  • PINE64/PINE64+ images are available with daily builds on the link above.
  • Default connection is over HDMI cable and USB keyboard.
  • Default username is "root" without password. Ssh remote login is not enabled by default.
Android Image Releases
Android 7.x
Android 7.1 Community Build Image [microSD Boot] by ayufan
Android 6.x eMMC
Android 6.0.1 Stock Image [microSD to eMMC] [20170605]
  • Rootable build, online update (OTA) only work when the build still not root
  • LCD resolution is 1366 x 768
  • Rooted DD image (advise 4GB microSD card and above):
Bliss OS
Bliss OS [20170919] [microSD Boot]
  • An Open-Source OS, based on Android, for phones, tablets & PCs.
  • Multi-Windows Android Build
  • You can visit the Bliss OS website here
  • DD image:
  • Use the Taskbar launcher for Desktop mode UI
Linux BSP SDK
Linux BSP [3.0]
Android SDK
Android Nougat [v7.0]
Android Marshmallow [v6.0]
Mali-400 64-bit Driver
Mali-400 64-bit Driver [20160622]
Other Tools
Checking microSD Card Performance and whether it is Counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not
