Pinebook Software Releases
Revision as of 05:29, 13 November 2017 by Pineadmin (talk | contribs)
Linux Image Releases
Special thanks to Sunxi community, ayufan, and longsleep for their contributions.
Xenial Mate eMMC
Xenial Mate Community Build Image [0.6.2-77] [MicroSD to eMMC] by ayufan
  • This is the default OS comes with Pinebook
  • Special thanks to ayufan, Icenowy, lennyraposo, longsleep, lukasz, tkaiser, Xalius and PINE64 community contributors.
  • ayufan Linux Build GitHub
  • This is SDCard install to eMMC version. Please follow bootup screen to complete eMMC installation process
  • Included Mate Desktop, Firebox Browser, and LibreOffice Suite.
  • Not yet optimize for Graphic and Video HW acceleration.
  • DD image (for 8GB micoSD card and above):
  • Login with
    • username: pine64
    • password: pine64
Xenial Mate
Xenial Mate Community Build Image [MicroSD Boot] by ayufan
Xenial Minimal Image
Xenial Minimal Community Build Image [MicroSD Boot] by ayufan
  • This is the latest Xenial 16.04 image provided by ayufan based on longsleep base image. NB. This is a base image and doesn't come with a DE.
  • ayufan Latest Linux Build GitHub
  • Login with
    • username: pine64
    • password: pine64
  • Execute sudo /usr/local/sbin/resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card.
  • To update to the newest uboot, kernel and fixes use scripts found in /usr/local/sbin/
  • Install Mate DE using: sudo /usr/local/sbin/install_desktop.sh
Armbian
Armbian Community Build Image [MicroSD Boot]
  • Armbian provides a build system and images for Debian/Xenial with BSP kernel and mainline kernel (beta).
  • Login with
    • username: root
    • password: 1234
  • To find out more about Armbian and available options please visit their site.
Q4OS
Q4OS Community Build Image [MicroSD Boot]
i3
i3 Community Build Image [MicroSD Boot]
Android Image Releases
Android 7.x
Android 7.1 Community Build Image [v0.3.10-r66]
  • ayufan Android 7.1 GitHub
  • Please use good random IO access performance microSD card such as Samsung EVO when try out Android 7.1.
  • DD images (advise 4GB microSD card and above):
  • Please allows some time (around 5 minutes) for the initialization process on 1st boot.
Android 6.x eMMC
Stock Android 6.0.1 (Pinebook SDcard Boot) [20170605]
  • Rootable build, online update (OTA) only work when the build still not root.
  • LCD resolution is 1366 x 768
  • Rooted DD images:
Bliss OS
Bliss OS [20170919]
  • An Open-Source OS, based on Android, for phones, tablets & PCs.
  • Multi-Windows Android Build
  • You can visit the Bliss OS website here.
  • This version build suitable for Pinebook.
  • DD images:
  • Use the Taskbar launcher for Desktop mode UI.
Linux BSP SDK
Linux BSP [3.0]
Android SDK
Android Nougat [v7.0]
Android Marshmallow [v6.0]
Mali-400 64-bit Driver
Mali-400 64-bit Driver [20160622]
Other Tools
Checking microSD Card Performance and whether it is Counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not.
