Pinebook Pro Software Release
Revision as of 18:45, 9 July 2020 by Duckinator (talk | contribs) (→‎Manjaro ARM: Fix some Manjaro download links.)
OS Image Releases
For information on how to install these images onto your device, please see the NOOB Page, which includes information on writing images to the device EMMC or a SDCard.
If Manjaro is installed on the eMMC you may experience issues booting different installations from SD card. List of known affected distros and workaround.
Arch Linux
Arch Linux ARM install image [microSD/USB Boot]
  • archiso image customized for Arch Linux ARM on the Pinebook Pro
  • DD image (for 1GB or larger micoSD card/USB stick):
  • Automatic login as root
  • Make sure to thoroughly read the readme and FAQ, otherwise follow the normal Arch installation guide.
Debian Desktop
Debian Desktop Community Build Image [microSD to eMMC] by mrfixit2001
  • This was previously the default operating system for the Pinebook Pro
  • Includes desktop, Firefox browser, and LibreOffice
  • DD image (for 8GB microSD card / 16GB eMMC module and above):
  • Login with
    • username: rock
    • password: rock
Ubuntu 20.04 Focal Fossa MATE / GNOME
Ubuntu 20.04 Focal Fossa MATE and GNOME Community Builds [microSD/ eMMC Boot] by ayufan
Ubuntu 18.04 Bionic Beaver LXDE
Ubuntu 18.04 Bionic Beaver LXDE Community Build Image by ayufan [microSD and eMMC Boot]
Bionic Mate
Bionic Mate Community Build Image [microSD Boot] by ayufan
  • Included Mate Desktop, Firefox Browser, and LibreOffice Suite
  • DD image (for 8GB micoSD card /16GB eMMC module and above):
  • Login with
    • username: rock64
    • password: rock64
Manjaro ARM
  • The Manjaro project offers a mainline kernel with patches and modules to support PBPro hardware in two flavors. Both provide DD images and installer images (DD to SD card which will then install to eMMC when booted).
  • To learn more about Manjaro please visit Manjaro Forum
  • Pitfall: When using the EMMC installer from SD card, you may get stuck on the bootsplash animation forever. But that's just the image masking the TUI (text mode user interface) installer. Just press escape after like some seconds or so, and you will have an easy-to-follow installer. See forum post: manjaro-arm-installer to eMMC
Manjaro ARM with KDE (Plasma) desktop [microSD / eMMC Boot]
Manjaro ARM with GTK (XFCE) desktop [microSD / eMMC Boot]
Manjaro ARM with i3 tiling window manager [microSD / eMMC Boot]
Manjaro ARM Test Build Image with GTK (Gnome) desktop [microSD Boot]
Manjaro ARM installer
The manjaro-arm-installer script is intended to install Manjaro ARM directly to SD/eMMC cards without the need for images (including LXQT, Mate & CuboCore editions, as well as full disk encryption). Running on a Linux x86 computer, it can install Manjaro ARM directly to an empty eMMC using an eMMC to USB adapter. The script can also be run from SD to install an image to the eMMC.
Kali Linux
Kali Linux prebuilt OS images for Pinebook Pro [SD/eMMC boot]
postmarketOS
Official postmarketOS build [microSD/ eMMC Boot]
  • Official postmarketOS build with the GNOME desktop for the Pinebook Pro.
  • Login with
    • username: demo
    • password: demo OR 147147
Q4OS
Q4OS Test Build Image [microSD / eMMC Boot]
OpenSUSE
OpenSUSE XFCE OS Image [microSD / eMMC Boot]
OpenSUSE GNOME 3 OS Image [microSD / eMMC Boot]
Fedora
Fedora GNOME3 OS Image [microSD / eMMC Boot]
Armbian
Armbian [microSD / eMMC Boot]
NetBSD
NetBSD [microSD /eMMC Boot]
    • username: root
    • password: [none]
OpenBSD
OpenBSD
Chromium
Chromium Community Build Image by ayufan [microSD and eMMC Boot]
Recalbox
Recalbox for Pinebook Pro [SD/eMMC boot]
  • Recalbox is a retrogaming Linux distribution allowing for emulation of all classic videogame systems.
  • SSH Login
    • username: root
    • password: recalboxroot
Android Image Releases
Android 7.1 microSD
Stock Android for DD method [micro SD Boot] [20190918]
Stock for RK Flash tool [SD Boot] [20190427]
Android 7.1 eMMC
Stock Android for DD method [eMMC Boot] [20190807]
  • Production floor testing image
  • Please allows some time (around 5 minutes) for the initialization process on 1st boot
  • DD image for 64GB eMMC Module
  • DD image for 128GB eMMC Module
Stock for RK Flash tool [eMMC Boot] [20190807]
Linux Installer Releases
Debian Installer
Daniel Thompson's Debian Installer for the Pinebook Pro
  • This is an image creator and Debian installer that runs from an existing Linux OS and installs Debian Bullseye
    • Installer can configure an encrypted rootfs and provides a choice of desktops, including the default Debian desktop based on Gnome 3
    • Strict adoption of upstream Debian packages (with exception of kernel and bootloaders) in order to provide a clean upgrade path as Bullseye matures
  • Download at: https://github.com/daniel-thompson/pinebook-pro-debian-installer/
  • Pull requests welcome but for discussion and support please use the forum topic.
For more information, see the Pinebook_Pro_Debian_Installer wiki page
Official Debian Installer Images
  • Uses only the upstream kernel and firmware without special patches
  • No graphical display yet, works only through serial console
  • Requires adding the non-free component to your /etc/apt/sources.list file and installing the "firmware-linux" package for Wi-Fi and Bluetooth support
  • Installer is loaded into RAM, can install onto the same media it's booted off of
  • Supports automatic partitioning and full disk encryption through LVM
  • Installer currently doesn't install the bootloader, leaving the installed system in an unbootable state until it's manually added
The relevant files are built daily here and may sometimes be unavailable if the build system is having issues. The "README.concatenateable_images" file provides instructions on how to combine the partition.img.gz file with the firmware.pinebook-pro.rk3399.img.gz file in order to create a DD-able image.
The official images are not recommended yet until the display begins working and the installer properly installs the bootloader. Most users will want to see Daniel Thompson's Debian Installer instead.
Gentoo Script
Gentoo Script for Pinebook Pro
  • This is a script that prepares a Gentoo arm64 stage 3 tarball for the Pinebook Pro
    • The script takes care of device specifics like an optimized make.conf, an overlay that provides Kernel and Firmware amongst others, and other miscellaneous fixes
  • The usual tarball setup as per Gentoo Handbook is left to the user.
  • Forum thread with instructions at https://forum.pine64.org/showthread.php?tid=8765
Kali Script
Kali Linux for Pinebook Pro
