Pinebook Pro Software Release
Contents
OS Image Releases
Debian Desktop
Debian Desktop Community Build Image [microSD to eMMC] by mrfixit2001
  • This is the default OS comes with Pinebook Pro
  • Included Desktop, Firefox Browser, and LibreOffice Suite
  • DD image (for 8GB microSD card / 16GB eMMC module and above):
  • Login with
    • username: rock
    • password: rock
Focal MATE / GNOME
Focal MATE and GNOME Community Builds [microSD/ eMMC Boot] by ayufan
Bionic LXDE
Bionic LXDE Community Build Image by ayufan [microSD and eMMC Boot]
Bionic Mate
Bionic Mate Community Build Image [microSD Boot] by ayufan
  • Included Mate Desktop, Firefox Browser, and LibreOffice Suite
  • DD image (for 8GB micoSD card /16GB eMMC module and above):
  • Login with
    • username: rock64
    • password: rock64
Arch Linux ARM
  • A minimal Arch Linux ARM image, it is set up as a single ext4 partition and only has the minimum packages needed to boot the Pinebook Pro and connect to Wi-Fi. The image could either be used as-is, or written to an SD card to use to set up an Arch system yourself on the eMMC.
  • The Pinebook Pro-specific packages are taken from Brian Salcedo's repository.
  • DD image:
Manjaro ARM
  • The Manjaro project offers a mainline kernel with patches and modules to support PBPro hardware in two flavors. Both provide DD images and installer images (DD to SD card which will then install to eMMC when booted).
  • To learn more about Manjaro please visit Manjaro Forum
  • Pitfall: When using the EMMC installer from SD card, you may get stuck on the bootsplash animation forever. But that's just the image masking the TUI (text mode user interface) installer. Just press escape after like some seconds or so, and you will have an easy-to-follow installer. See foum post: manjaro-arm-installer to eMMC
Manjaro ARM with KDE (Plasma) desktop [microSD / eMMC Boot]
Manjaro ARM with GTK (XFCE) desktop [microSD / eMMC Boot]
Manjaro ARM with i3 tiling window manager [microSD / eMMC Boot]
Manjaro ARM Test Build Image with GTK (Gnome) desktop [microSD Boot]
Q4OS
Q4OS Test Build Image [microSD / eMMC Boot]
OpenSUSE XFCE OS Image [microSD / eMMC Boot]
OpenSUSE GNOME 3 OS Image [microSD / eMMC Boot]
Fedora
Fedora GNOME3 OS Image [microSD / eMMC Boot]
Armbian
Armbian [microSD / eMMC Boot]
NetBSD
NetBSD [microSD /eMMC Boot]
    • username: root
    • password: [none]
OpenBSD
OpenBSD
Chromium
Chromium Community Build Image by ayufan [microSD and eMMC Boot]
openSUSE Tumbleweed [microSD /eMMC Boot]
  • Included Xfce Desktop, Firefox Browser, and LibreOffice Suite
    • DD image (for 32GB microSD card /32GB eMMC module and above):
https://github.com/smithmcgriff/openSUSE-on-pinebookpro
Fedora Workstation with Gnome Desktop [microSD /eMMC Boot]
  • Included Gnome Desktop, Firefox Browser, and LibreOffice Suite
https://github.com/smithmcgriff/Fedora-on-pinebookpro
Android Image Releases
Android 7.1 microSD
Stock Android for DD method [micro SD Boot] [20190918]
Stock for RK Flash tool [SD Boot] [20190427]
Android 7.1 eMMC
Stock Android for DD method [eMMC Boot] [20190807]
  • Production floor testing image
  • Please allows some time (around 5 minutes) for the initialization process on 1st boot
  • DD image for 64GB eMMC Module
  • DD image for 128GB eMMC Module
Stock for RK Flash tool [eMMC Boot] [20190807]
Linux Installer Releases
Debian Installer
Debian Installer for Pinebook Pro
  • This is an image creator and Debian installer that runs from an existing Linux OS and installs Debian Bullseye
    • Installer can configure an encrypted rootfs and provides a choice of desktops, including the default Debian desktop based on Gnome 3
    • Strict adoption of upstream Debian packages (with exception of kernel and bootloaders) in order to provide a clean upgrade path as Bullseye matures
  • Download at: https://github.com/daniel-thompson/pinebook-pro-debian-installer/
  • Pull requests welcome but for discussion and support please use the forum topic.
For more information, see the Pinebook_Pro_Debian_Installer wiki page
Gentoo Script
Gentoo Script for Pinebook Pro
  • This is a script that prepares a Gentoo arm64 stage 3 tarball for the Pinebook Pro
    • The script takes care of device specifics like an optimized make.conf, an overlay that provides Kernel and Firmware amongst others, and other miscellaneous fixes
  • The usual tarball setup as per Gentoo Handbook is left to the user.
  • Forum thread with instructions at https://forum.pine64.org/showthread.php?tid=8765
Kali Script
Kali Linux for Pinebook Pro
