Pinebook Pro Software Release
Revision as of 18:03, 14 May 2021 by Ura2 (talk | contribs) (Removed unsupported Distros, meaning no release in > 6 months)
Linux OS Image Releases
For information on how to install these images onto your device, please see the NOOB Page, which includes information on writing images to the device eMMC or an SD card
Kali Linux
Kali Linux prebuilt OS images for Pinebook Pro [SD/eMMC boot]
Arch Linux
Arch Linux ARM install image [microSD/USB Boot]
  • archiso image customized for Arch Linux ARM on the Pinebook Pro
  • DD image (for 1GB or larger microSD card/USB stick):
  • Automatic login as root
  • Make sure to thoroughly read the readme and FAQ, otherwise follow the normal Arch installation guide.
Manjaro ARM
  • The Manjaro project offers a mainline kernel with patches and modules to support PBPro hardware in two flavors. Both provide DD images and installer images (DD to SD card which will then install to eMMC when booted).
  • To learn more about Manjaro please visit Manjaro Forum
  • You can follow the ongoing discussion about Twister OS on the PINE64 forum (https://forum.pine64.org/showthread.php?tid=8207)
Manjaro ARM with KDE (Plasma) desktop [microSD / eMMC Boot]
Manjaro ARM with GTK (XFCE) desktop [microSD / eMMC Boot]
Manjaro ARM with i3 tiling window manager [microSD / eMMC Boot]
Manjaro ARM with Sway tiling window manager [microSD / eMMC Boot]
Manjaro ARM installer
The manjaro-arm-installer script is intended to install Manjaro ARM directly to SD/eMMC cards without the need for images (including LXQT, Mate & CuboCore editions, as well as full disk encryption). Running on a Linux x86 computer, it can install Manjaro ARM directly to an empty eMMC using an eMMC to USB adapter. The script can also be run from SD to install an image to the eMMC.
Fedora
Fedora 34/33/32 Gnome/KDE/Minimal Images [microSD / eMMC Boot]
Fedora 32 Cinnamon Desktop OS Image [microSD / eMMC Boot]
  • This image contains an install of Fedora with Cinnamon desktop environment.
  • To learn more about Fedora please visit the official website.
  • DD image (for 12GB microSD card / eMMC module and above)
  • login with:
    • username: root
    • password: fedora
Fedora 32 KDE Desktop OS Image [microSD / eMMC Boot]
Fedora 32 Xfce Desktop OS Image [microSD / eMMC Boot]
  • This image contains an install of Fedora with xfce desktop environment.
  • login with:
    • username: root
    • password: fedora
Fedora 32 Workstation OS Image [microSD / eMMC Boot]
  • This image contains an install of Fedora with GNOME 3 desktop environment.
  • login with:
    • username: root
    • password: fedora
Armbian
Armbian Ubuntu Focal XFCE Desktop mainline kernel [microSD / eMMC Boot]
Armbian Ubuntu Focal XFCE Desktop legacy kernel [microSD / eMMC Boot]
Armbian Debian Buster XFCE Desktop legacy kernel [microSD / eMMC Boot]
Armbian Ubuntu Bionic XFCE Desktop legacy kernel [microSD / eMMC Boot]
Twister OS
Twister OS Armbian-Reforged XFCE Dsktop beta images [SD boot]
Twister OS Monka-Manjaro XFCE Dsktop beta images [SD boot]
Ubuntu 20.04 Focal Fossa MATE / GNOME
Ubuntu 20.04 Focal Fossa MATE and GNOME Community Builds [microSD/ eMMC Boot] by ayufan
postmarketOS
Official postmarketOS build [microSD/ eMMC Boot]
  • Official postmarketOS build with the GNOME desktop for the Pinebook Pro.
  • DD image (for 8GB microSD card /16GB eMMC module and above):
  • Login with
    • username: demo
    • password: demo OR 147147
Q4OS
Q4OS Test Build Image [microSD / eMMC Boot]
BSD OS Image Release
NetBSD
NetBSD [microSD /eMMC Boot]
    • username: root
    • password: [none]
OpenBSD
OpenBSD
Linux Installer Releases
Debian Installer
Daniel Thompson's Debian Installer for the Pinebook Pro
  • This is an image creator and Debian installer that runs from an existing Linux OS and installs Debian Bullseye
    • Installer can configure an encrypted rootfs and provides a choice of desktops, including the default Debian desktop based on Gnome 3
    • Strict adoption of upstream Debian packages (with exception of kernel and bootloaders) in order to provide a clean upgrade path as Bullseye matures
  • Download at: https://github.com/daniel-thompson/pinebook-pro-debian-installer/
  • Pull requests welcome but for discussion and support please use the forum topic.
For more information, see the Pinebook_Pro_Debian_Installer wiki page
Official Debian Installer Images
  • Uses only the upstream kernel and firmware without special patches
  • No graphical display yet, works only through serial console
  • Requires adding the non-free component to your /etc/apt/sources.list file and installing the "firmware-linux" package for Wi-Fi and Bluetooth support
  • Installer is loaded into RAM, can install onto the same media from which it’s booted
  • Supports automatic partitioning and full disk encryption through LVM
  • Installer currently doesn't install the bootloader, leaving the installed system in an unbootable state until it's manually added
The relevant files are built daily here and may sometimes be unavailable if the build system is having issues. The "README.concatenateable_images" file provides instructions on how to combine the partition.img.gz file with the firmware.pinebook-pro.rk3399.img.gz file in order to create a DD-able image.
The official images are not recommended yet until the display begins working and the installer properly installs the bootloader. Most users will want to see Daniel Thompson's Debian Installer instead.
Gentoo Script
Gentoo Script for Pinebook Pro
  • This is a script that prepares a Gentoo arm64 stage 3 tarball for the Pinebook Pro
    • The script takes care of device specifics like an optimized make.conf, an overlay that provides kernel and firmware amongst others, and other miscellaneous fixes
  • The usual tarball setup as per Gentoo Handbook is left to the user.
  • Forum thread with instructions at https://forum.pine64.org/showthread.php?tid=8765
Kali Script
Kali Linux for Pinebook Pro
K1ss OS Script
K1ss Linux for Pinebook Pro
  • This is a repository containing an unofficial port of KISS Linux to aarch64. The tarball is built for generic aarch64, currently being tested on the Pinebook Pro.
  • Please pull the latest K1ss Linux install script from the project's GitHub.
  • * You can follow the ongoing discussion about K1ss Linux on the PINE64 forum (https://forum.pine64.org/showthread.php?tid=9304)
NixOS Script
NixOS for Pinebook Pro
SkiffOS for Pinebook Pro
SkiffOS Boot Image for Pinebook Pro
  • Instructions to build/install on the Pinebook Pro: https://github.com/skiffos/SkiffOS/tree/master/configs/pine64/book
  • Please pull the latest version from the project's GitHub.
  • Compiling the boot image takes approximately 30 minutes.
  • Easily configure the kernel, compiler, etc with Buildroot.
  • Pre-built ISOs will be available with the upcoming 2021.02
release.
Skiff Core
  • Supports multiple distros running simultaneously.
  • Optionally build from scratch on device on first boot.
  • Pre-built multi-arch core container images are available.
GentooLTO with KDE Apps
  • GentooLTO with O3 optimized KDE Desktop configuration.
  • Use SKIFF_CONFIG=pine64/book,core/pinebook_gentoo
  • Default sign-in is username "core" w/ empty password.
