Pinebook Pro
Revision as of 15:54, 24 October 2019 by Luke (Talk | contribs) (Quick Links to OS Images Build Sources)
Jump to: navigation, search
User Guide
Introducing PineBook Pro
Pinebook Pro running stock Debian with MATE
When disassembling the laptop make sure that it is powered off and closed. To open the Pinebook Pro you have to remove 10 Phillips head screws that hold the bottom section of the laptop in place. Remove the bottom from the back where the hinges are situated by lifting it up and away from the rest of the chassis.
WARNING Do not reopen the laptop by lifting the lid whilst the Pinebook Pro bottom enclosure section is removed - this can cause structural damage to the hinges and/or other plastic components of the chassis such as the IO port cut-outs.
During reassembly, make sure that the back-screw standoffs are in place and seated correctly. To reassembled the Pinebook Pro, slide the bottom section into place so it meets the front lip of the keyboard section. Secure the front section (where trackpad is located) in place using short screws in the front left and right corners. Having done so, proceed to pop in the bottom pannel into place. Secure the bottom section (where hinges are located) by screwing in the left and right corners. Having completed this, screw in the remaining screws and run your finger though the rim on the chassis to make sure its fitted correctly.
Pinebook Pro
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
Keyboard
The keyboard firmware is open sourced can be flashed from userspace using the provided utility.
Privacy Switches
Combination Effect Description
PINE64 logo key+F11 WiFi Privacy switch NUM lock LED blinks. 2 blinks = enabled, 3 blinks = disabled. Re-enabling requires reboot.
(Press the PINE64 logo key plus Fn (10/11/12) for 3 seconds)
The keyboard uses special firmware that operates separately of the operating system. It detects if either the F10, F11 or F12 key, and the Pine key were pressed for 3 seconds. This disables the peripherals as listed above by cutting off their power. Which has the same result as cutting off the power to each peripheral with a physical switch. This implementation is very secure since the firmware that determines whether a peripheral gets power is not a part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots.
Trackpad
The trackpad is large, smooth (metallic to-the-touch), and has two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality.
The trackpad firmware is open sourced can be flashed from userspace using the provided utility.
Documentation trackpad can be found in Datasheets for Components and Peripherals.
Power Supply
Input Power: DC 5V @ 3A 3.5mm OD/ 1.35mm ID Barrel jack or USB-C 15W PD quickcharge
LEDs
3. The Num lock, green LED.
4. The Caps lock, green LED.
Webcam
WIP
Microphones
WIP
Bluetooth and WiFi
WIP
LCD Panel
WIP
Using the PineBook Pro
Bypass Cables
Technical Reference
Pinebook Pro Internal Layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
Key Internal Parts
Number Type Descriptor
3 Socket Speakers socket
4 Socket Trackpad socket
5 Component Left speaker
7 Socket Keyboard Socket
11 Socket Battery socket
12 Component Trackpad
13 Component Battery
14 Component Right speaker
15 Socket Micro SD socket
17 Socket USB 2.0
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0
33 Socket USB type C
Bootable Storage
At this time, the Pinebook Pro ships with a Debian + MATE build with uboot on the eMMC. Its boot order is: SD, USB 2.0, eMMC. Booting off USB 3.0 storage is not currently available, but will be in the future.
(An update has been pushed for the default Debian + MATE build that improves compatibility with booting other OSs from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
Pinebook Pro Dimensions
  • Weight: 1.26Kg
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
GPU Architecture
  • Frequency 650MHz
  • LPDDR4 RAM Memory Variants: Dual Channels 4GB.
  • Storage Memory:
    • 64GB eMMC module, can be upgraded to a 128GB eMMC module. (The initial PINE64 community build version shipped with a 128GB eMMC.)
Battery
Display
  • 14.1" 1920x1080 IPS LCD panel
Video
  • USB-C Alt model DP up to 3840x2160 p60
Audio
  • Build in stereo speakers
Network
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
Expansion Ports
  • MicroSD card:
    • Bootable
    • Supports SDHC and SDXC cards, up to 256GB
    • Version SD3.0, up to 50MB/s
  • USB ports:
    • 1 x USB 3.0 Type-A Host Port, can be bootable based on uboot software
    • 1 x USB 3.0 Type-C OTG Port, (includes laptop charging function), is not bootable
  • Optional NVMe adapter:
    • PCIe 2.x, 5GT/s per lane
    • 4 PCIe lanes
    • Maximum length for M.2 card is 80mm (M.2 2280)
  • Pinebook Pro Certifications:
    • Not Yet Available
Other Resources
