Pinebook Pro
Revision as of 14:50, 2 October 2019 by Luke (Talk | contribs) (Privacy Switches)
Jump to: navigation, search
The Pinebook Pro is a Linux and *BSD ARM laptop from PINE64. It is built with the intention to be a compelling alternative to mid-ranged Chromebooks that people convert into Linux laptops. It features an IPS 1080p 14″ LCD panel, a premium magnesium alloy shell, high capacity eMMC storage, a 10,000 mAh capacity battery and the modularity that only an open source project can deliver.
Key features include the RK3399 SOC; USB-C for data, video-out and power-in (3A 5V); privacy switches for the microphone, BT/WiFi module and camera; as well as the possibility to expand storage via NVMe (PCIe 4x).
The Pinebook Pro is equipped with 4GB LPDDR4 system memory, high capacity eMMC flash storage and 128Mb SPI boot Flash. The I/O includes: 1x micro SD card reader (bootable), 1x USB 2.0, 1x USB 3.0, 1x USB type C Host with DP 1.2 and power-in; PCIe 4x for NVMe SSD drives (requires an optional adapter) as well as UART.
The mouse and keyboard both use the USB 2.0 protocol, while the LCD panel uses eDP MiPi display protocol.
Many different Operating Systems (OS) are freely available from the open source community and partner projects - these include various flavours of Linux (Ubuntu, Debian, Manjaro, etc.,) and *BSD.
Pinebook Pro Internal Layout
Pinebook Pro running stock Debian with MATE
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
There are two switches on the main board: for disabling eMMC (24) and enabling UART (9) via headphone jack.
Key Internal Parts
Number Type Descriptor
3 Socket Speakers socket
4 Socket Trackpad socket
5 Component Left speaker
7 Socket Keyboard Socket
11 Socket Battery socket
12 Component Trackpad
13 Component Battery
14 Component Right speaker
15 Socket Micro SD socket
17 Socket USB 2.0
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0
33 Socket USB type C
Bypass Cables
The mainboard features two (disconnected by default) bypass cables that are only to be used with the battery disconnected. The female (10) male (6) ends of the bypass cables can be connected to provide power to the mainboard in the event of battery failure OR if the laptop needs to run with the battery disconnected. Please refer to this engineering notice.
Keyboard and Trackpad
The Pinebook Pro is available in two keyboard configurations: ISO and ANSI. Both the keyboard and trackpad in the Pinebook Pro use the USB 2.0 protocol and show up as such in xinput. The keyboard features function (Fn) keys in the F-key row, which include display brightness controls, sound volume, trackpad lock and other functionality. There is also a custom PINE64 logo key that functions as menu/SUPER key, but has a secondary functionality for triggering privacy switches (see following sub-section).
The trackpad is large, smooth (metallic to-the-touch) and two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality.
The keyboard and trackpad firmware is open sourced can be flashed from userspace using the provided utility.
Documentation for the keyboard and trackpad can be found in Datasheets for Components and Peripherals section.
Privacy Switches
There are three privacy switches mapped to the F1, F2 and F3 keys on the Pinebook Pro keyboard. They de/activate the following:
Key Function
F10 WiFi/Bluetooth
F11 WebCam
F12 Microphones
(Press the Pine key plus Fn (1/2/3) for 10 seconds)
The keyboard has a special firmware that lives on, and operates separately of, the operating system. In a nutshell, it detects if F10, F11 and F12 keys are pressed for 10s. Once one of the keys get pressed for the set duration, the keyboard firmware cuts power to the chosen aforementioned peripheral. The implementation is no different to cutting a peripheral power mechanically via a physical switch, and the power state settings for each is stored across reboots.
This is privacy switch implementation is highly secure since the firmware that dictates if peripherals get powered is not a part of the Pinebook Pro’s operating system. The power state value for each peripheral also cannot be overridden from the operating system. In fact, the keyboard firmware itself cannot be accessed from the operating system.
LEDs
In total there are 4 LEDs on the Pinebook Pro, three of which are placed in the top left side of the keyboard and one near the barrel-port.
The amber LED next to the barrel-port indicates charging. It will illuminate when mains power is supplied to the Pinebook Pro from either the standard power supply unit or a USB-C smartphone charger.
The power indicator LED on the Pinebook Pro supports three different colours: green, amber and red. It is also capable of flashing/blinking to indicate activity. In the default Debian with MATE build, green LED means power and red means suspend (amber is unused).
The remaining two LED indicators are used for Num and Caps locks. They only use green LEDs. These two LEDs have a secondary function; when privacy switches get activated they blink to confirm that the switch has been activated.
Webcam
WIP
Microphones
WIP
Pinebook Pro
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software. The list includes OS images and descriptions of:
Under 'Service Guides for Pinebook' you can instructions guides concerning disassembly of:
Pinebook Pro Information
  • Weight: 1.26Kg
  • Input Power: DC 5V @ 3A 3.5mm OD/ 1.35mm ID Barrel jack or USB-C 15W PD quickcharge
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
GPU Architecture
  • Frequency 650MHz
  • LPDDR4 RAM Memory Variants: Dual Channels 4GB.
  • Storage Memory:
    • 64GB eMMC module, can be upgrade to 128GB eMMC module. The initial PINE64 community build version comes with 128GB eMMC configuration
    • 128Mb (16MB) built-in SPI Flash memory
Battery
  • Lithium Polymer Battery (10,000mAH)
Display
  • 14.1" 1920x1080 IPS LCD panel
Video
  • USB-C Alt model DP up to 3840x2160p60
Audio
  • Build in stereo speaker
Network
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
Expansion Ports
  • USB - 1x USB2.0 Type-A Host Port, 1x USB3.0 Type-A Host Port, 1x USB3.0 Type-C OTG Port
  • optional NVMe adapter
  • earphone plug with UART console mux circuit
  • Pinebook Pro Certifications:
    • Not Yet Available
Other Resources
