Pinebook Pro
Contents
Pinebook Pro
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software. The list includes OS images and descriptions of:
- ayufan's Linux build repo
- ayufan's Chromium OS build repo
- mrfixit2001's Linux debian desktop build repo
- Q4OS
Under 'Service Guides for Pinebook' you can instructions guides concerning disassembly of:
- 14″ Pinebook Lithium Battery Pack Removal Guide
- 14″ Pinebook LCD Panel Screen Removal Guide
- 14″ Pinebook eMMC Module Removal Guide
Pinebook Pro Information
- Dimensions: 329mm x 220mm x 12mm (WxDxH)
- Weight: 1.26Kg
- Input Power: DC 5V @ 3A 3.5mm OD/ 1.35mm ID Barrel jack or USB-C 15W PD quickcharge
SoC and Memory Specification
- Based on Rockchip RK3399
- Dual-core Cortex-A72 up to 2.0GHz CPU
- Quad-core Cortex-A53 up to 1.5GHz CPU
- big.LITTLE architecture: Dual Cortex-A72 + Quad Cortex-A53, 64-bit CPU
- Cortex-A72:
- 1-4x Symmetrical Multiprocessing (SMP) within a single processor cluster, and multiple coherent SMP processor clusters through AMBA 5 CHI or AMBA 4 ACE technology
- AArch64 for 64-bit support and new architectural features
- L1 cache 48KB Icache and 32KB Dcache for each A72
- L2 cache 1024KB for big cluster
- DSP & SIMD extensions
- VFPv4 floating point
- Hardware virtualization support
- Cortex-A53:
- L1 cache 32KB Icache and 32KB Dcache for each A53
- L2 cache 512KB for little cluster
- Full implementation of the ARM architecture v8-A instruction set
- ARM Neon Advanced SIMD (single instruction, multiple data) support for accelerated media and signal processing computation
- ARMv8 Cryptography Extensions
- In-order pipeline with symmetric dual-issue of most instructions
- Include VFP v3 hardware to support single and double-precision operations
- TrustZone technology support
- Full CoreSight debug solution
- One isolated voltage domain to support DVFS
GPU Architecture
- ARM Mali-T860MP4 Quad-core GPU
- The highest performance GPUs built on Arm Mali’s famous Midgard architecture, the Mali-T860 GPU is designed for complex graphics use cases and provide stunning visuals for UHD content.
- Frequency 650MHz
- Throughput 1300Mtri/s, 10.4Gpix/s
- OpenGL® ES 1.1, 1.2, 2.0, 3.1, 3.2., Vulkan 1.0*., OpenCL™ 1.1, 1.2., DirectX® 11 FL11_1., RenderScript™.
- LPDDR4 RAM Memory Variants: Dual Channels 4GB.
- Storage Memory:
- 64GB eMMC module, can be upgrade to 128GB eMMC module. The initiial PINE64 community build version comes wit 128GB eMMC configuration
- 128Mb built-in SPI Flash memory
Battery
- Lithium Polymer Battery (10,000mAH)
Display
- 14.1" 1920x1080 IPS LCD panel
Video
- USB-C Alt model DP up to 3840x2160p60
Audio
- 3.5mm stereo earphone/microphone plug
- Build in stereo speaker
Network
- WiFi 802.11 b/g/n/ac with Bluetooth 5.0
Expansion Ports
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 1x USB2.0 Type-A Host Port, 1x USB3.0 Type-A Host Port, 1x USB3.0 Type-C OTG Port
- optional NVMe adapter
- earphone plug with UART console mux circuit
- Pinebook Pro Main Board Schematic:
- Pinebook Daughter Board Schematic:
- Pinebook Pro NVMe Adapter Schematic:
- Serial Console Earphone Jack Pinout:
- Pinebook Pro Certifications:
- Not Yet Available
- Rockchip RK3399 SoC information:
- LPDDR4 (366 Balls) SDRAM:
- eMMC information:
- SPI NOR Flash information:
- Wireless related info:
- Audio Codec (ES8316)
- LCD Panel:
- Touchpad information:
- Full HD Camera sensor:
- Lithium Battery information:
