Pinebook Pro Hardware Accessory Compatibility
Revision as of 22:59, 18 January 2020 by Arwen (talk | contribs) (→‎USB C alternate mode DP: Fixed my earlier entry for my USB-C to HP Adapter, put comment in notes field.)
Pinebook Pro accessories - by type
This page was started in the early days when not all accessories/peripherals have been working
NVMe SSD drives
Note that only PCIe type M.2 drives will work. Any SATA or USB type M.2 card will NOT work.
Type Make/Model Size Hardware IDs Result Notes Power options Save
power
setting?
2242 Toshiba OCZ RC 100 240 GB RC100-M22242-240G good
2280 XPS SX8200 512 GB ASX8200PNP-512GT-C good Performed these steps for physical installation. Currently rooting from drive.
2280 Intel 660p M.2 512 GB SSDPEKNW512G8X1 good
2280 Intel 660p M.2 1 TB ? good
2280 Samsung 970 EVO Plus 250 GB MZ-V7S250BW good
2280 Samsung 970 EVO Plus 500 GB MZ-V7S500 fail too power hungry?
2280 Samsung 970 EVO 1 TB MZ-V7E1T0BW fail too power hungry?
2280 Corsair MP300 120 GB good
2280 Silicon Power P34A60 256 GB ??? fail Isn't detected
2242 Sabrent Rocket Nano 512 GB SB-1342-512 good No touchpad issues, didn't trim NVME adapter board.
(Might be too power hungry. More testing needed.)
2280 MyDigitalSSD SBXe 960 GB good APST enabled; Power states N/A N/A
USB hardware
Type Make/Model Hardware IDs Result Notes
USB-2 SDHC reader Sandisk MobileMate+ 0781:b2b3 good
USB-3 SDHC/CF reader Transcend TS-RDF8K 8564:4000 good
USB-3 combo hub (network, card slots, usb ports) generic 05e3:0610 hub, 0bda:8153 gigE, 05e3:0743 card reader network good, usb ports good, card reader good
USB-C combo hub (network, card slots, usb ports) generic 05e3:0612 hub, 0bda:8153 realtek gigE network good, usb ports bad, card reader bad
Yubikey original Yubico 1050:0010 good
4 Port USB 3 NIC Delock 62966 All good 4 individually controllable Gigabit Ethernet Ports. Consider using it with own power supply
USB-2 Fast Ethernet adapter Realtek RTL8152 0bda:8152 good
Note that only USB C alternate mode Display Port will pass video. Any HDMI, DVI or VGA port must be converted internally by the device from Display Port. Or the device won't work for video.
USB-C to HDMI adaptor generic good tested to 4k60
USB-C to DP Adapter OrxnQ good Upto 4K@60Hz, tested to 1080p
USB-C HDMI adapter (DP-alt mode) QGeeM No video. Kernel exception on connect, freezes PBP Manjaro 2020-01-10
USB-C combo hub (hdmi, network, card slots, usb ports) generic all bad
USB-C combo hub (hdmi, vga, ethernet, card slots, usb 2 & 3 Powlaken 05e3:0610 USB and power delivery good, all others don't work
USB-C Dock (hdmi, vga, ethernet, microSD/SD card slots, 2 USB 3 Ports, 1 USB-C Port, USB-Power Passthru Digitus DA-70865 USB, Ethernet and MicroSD/SD good, video crashes System. Tested on Manjaro w/ Kernel 5.5. You have to turn the USB-C connector upside down for it to work. Video seems to be a driver issue.
USB-C Dock (hdmi, vga, ethernet, microSD/SD card slots, 2 USB 3 Ports, 1 USB-C Port, USB-Power pass-through) generic Ethernet and MicroSD/SD good, USB bad, video up to 1080p. https://forum.pine64.org/showthread.php?tid=8728
USB-C Dock (DP, HDMI, 1Gbps Ethernet, SD card, 2 USB 3 Ports, 1 USB-C power in port goFanco All working, (SD card un-tested). Video tested to 1080p Tested on default Debian
Other hardware
Bluetooth Mouse HP Z5000 E5C13AA good
Bluetooth Mouse Logitech Triathlon M720 good
Bluetooth Mouse Logitech MX Anywhere 2 good
Bluetooth Mouse Fenifox low profile MX106-Black good
512GB SD Card Samsung Evo Select MB-ME512GA/AM good
Headphone Sony WH-1000XM2 just tested playback, good Needs pulseaudio-module-bluetooth
