Pinebook Pro Hardware Accessory Compatibility
Revision as of 10:14, 15 January 2020 by Fpex73 (talk | contribs)
This page was started in the early days when not all accessories/peripherals have been working
NVMe SSD drives
Type Make/Model Size Hardware IDs Result Notes
2242 Toshiba OCZ RC 100 240 GB RC100-M22242-240G good
2280 XPS SX8200 512 GB ASX8200PNP-512GT-C good Performed these steps for physical installation. Currently rooting from drive.
2280 Intel 660p M.2 512 GB SSDPEKNW512G8X1 good
2280 Samsung 970 EVO Plus 250 GB MZ-V7S250BW good
2280 Samsung 970 EVO Plus 500 GB MZ-V7S500 fail too power hungry?
2280 Samsung 970 EVO 1 TB MZ-V7E1T0BW fail too power hungry?
2280 Corsair MP300 120 GB good
2280 Silicon Power P34A60 256 GB ??? fail Isn't detected
2242 Sabrent Rocket Nano 512 GB SB-1342-512 good No touchpad issues, didn't trim NVME adapter board.
USB hardware
Type Make/Model Hardware IDs Result Notes
USB-2 SDHC reader Sandisk MobileMate+ 0781:b2b3 good
USB-3 SDHC/CF reader Transcend TS-RDF8K 8564:4000 good
USB-3 combo hub (network, card slots, usb ports) generic 05e3:0610 hub, 0bda:8153 gigE, 05e3:0743 card reader network good, usb ports good, card reader good
USB-C combo hub (network, card slots, usb ports) generic 05e3:0612 hub, 0bda:8153 realtek gigE network good, usb ports bad, card reader bad
USB-C combo hub (hdmi, network, card slots, usb ports) generic all bad
USB-C combo hub (hdmi, vga, ethernet, card slots, usb 2 & 3 Powlaken 05e3:0610 USB and power delivery good, all others don't work
USB-C Dock (hdmi, vga, ethernet, microSD/SD card slots, 2 USB 3 Ports, 1 USB-C Port, USB-Power Passthru Digitus DA-70865 USB, Ethernet and MicroSD/SD good, video crashes System. Tested on Manjaro w/ Kernel 5.5. You have to turn the USB-C connector upside down for it to work. Video seems to be a driver issue.
USB-C to HDMI adaptor generic good tested to 4k60
USB C to DP Adapter OrxnQ Upto 4K@60Hz good tested to 1080p
Yubikey original Yubico 1050:0010 good
4 Port USB 3 NIC Delock 62966 All good 4 individually controllable Gigabit Ethernet Ports. Consider using it with own power supply
USB-C Dock (hdmi, vga, ethernet, microSD/SD card slots, 2 USB 3 Ports, 1 USB-C Port, USB-Power pass-through) generic Ethernet and MicroSD/SD good, USB bad, video up to 1080p. https://forum.pine64.org/showthread.php?tid=8728
USB-C HDMI adapter (DP-alt mode) QGeeM No video. Kernel exception on connect, freezes PBP Manjaro 2020-01-10
USB-2 Fast Ethernet adapter Realtek RTL8152 0bda:8152 good
Other hardware
Bluetooth Mouse HP Z5000 E5C13AA good
Bluetooth Mouse Logitech Triathlon M720 good
Bluetooth Mouse Logitech MX Anywhere 2 good
Bluetooth Mouse Fenifox low profile MX106-Black good
512GB SD Card Samsung Evo Select MB-ME512GA/AM good
