User:Dieselnutjob/Pinebook Pro/Veracrypt on Manjaro
< User:Dieselnutjob
Revision as of 01:28, 22 March 2021 by Ura (talk | contribs) (Added Category)
You can install Veracrypt on the Pinebook Pro, but you have to (at this time) compile it from source. This is how to do it, You need to install the following packages:-
sudo pacman -Syu --asdeps gcc binutils fakeroot yasm wxgtk3 patch asp make pkgconfig
Create a new folder and cd into it.
asp checkout veracrypt
cd into the folder with the PKGBUILD (./veracrypt/trunk)
makepkg --ignorearch --skippgpcheck
If you are in luck you will find this file appearing in the trunk folder
veracrypt-1.24.update4-1-aarch64.pkg.tar.xz
you can install it with this command
sudo pamac install veracrypt-1.24.update4-1-aarch64.pkg.tar.xz
