User:Dieselnutjob/Pinebook Pro/Veracrypt on Manjaro
You can install Veracrypt on the Pinebook Pro, but you have to (at this time) compile it from source. This is how to do it, You need to install the following packages:-
sudo pacman -Syu gcc binutils fakeroot yasm wxgtk3 patch asp make dracut
Create a new folder and cd into it.
asp checkout veracrypt
cd into the folder with the PKGBUILD (./veracrypt/trunk)
makepkg --ignorearch --skippgpcheck
If you are in luck you will find this file appearing in the trunk folder
veracrypt-1.24.update4-1-aarch64.pkg.tar.xz
you can install it with this command
sudo pamac install veracrypt-1.24.update4-1-aarch64.pkg.tar.xz
if you need a loop interface to make it work do this:-
sudo echo "loop" >> /etc/modules-load.d/veracrypt.conf
sudo echo "options loop max_loop=8" >> /etc/modprobe.d/eightloop.conf
Make it permanent by rebuilding initrd
dracut --force
reboot
