Pinebook Pro
Revision as of 00:14, 5 June 2020 by Arwen (talk | contribs) (→‎Bootable Storage: Simplified the re-enable commands for the eMMC)
Contents
User Guide
Introducing PineBook Pro
Pinebook Pro running stock Debian with MATE
Default Debian MATE Desktop Quick Start
The default Operating system that ships with the Pinebook Pro is Debian 9 with MATE desktop. It has been built by a community developer called MrFixIt2001, who can be reached on the PINE64 forum or in the chats. The newest release of the build can downloaded directly from MrFixIt2001's GitHub.
The default username and password is:
  • Username: rock
  • Password: rock
You can change the default rock username and rock home directory by logging into root (credentials root/root) instead of the default 'rock' user and running the following in root terminal and substituting desired username for NewUser:
Location of update script applet icon on stock Debian with MATE
usermod -l NewUser -d /home/NewUser -m rock
Once you log back into your new user, Bluetooth will complain about no transfer folder location. To fix this open terminal and type:
blueman-services
From here, select incoming folder under the 'transfer' tab.
The build includes a custom updater capable of updating uboot, the Linux kernel and numerous packages. The update script can be ran from both the userspace and the commandline. You will find a small 'Update Script' applet icon in the bottom panel, next to time and date applet.
You can run the script from the terminal using:
sudo /usr/bin/mrfixit_update.sh
More information about the default OS build and version history can be found on the Default OS update log PINE64 forum thread.
Pinebook Pro images
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
debian.png Debian Desktop (microSD and eMMC Boot)
lxde.png Bionic LXDE (microSD and eMMC Boot)
mate.png Bionic Mate (microSD and eMMC Boot)
fedora.png Fedora (microSD and eMMC Boot)
manjaro.png Manjaro ARM (microSD and eMMC Boot)
note: When upgrading from a prior release of Manjaro to version 20.1, you may need to increase the backlight as the number of steps for the backlight exposed by the kernel was changed from 256 to 4096
opensuse.png OpenSUSE (microSD and eMMC Boot)
q4os.png Q4OS (microSD and eMMC Boot)
armbian.png Armbian (microSD and eMMC Boot)
netbsd.png NetBSD (microSD and eMMC Boot)
Puffy mascot openbsd.png OpenBSD release for ARM64
chromium.jpg Chromium (microSD and eMMC Boot)
android_7.png Android 7.1 (microSD Boot)           android_7.png Android 7.1 (eMMC)
debian.png Debian Installer for Pinebook Pro
gentoo.png Gentoo Script for Pinebook Pro
Kali.jpeg Kali Script for Pinebook Pro (microSD and eMMC Boot)
Keyboard
Typing special characters
µ [AltGr]+[m]
Ø, ø [AltGr]+[O], [AltGr]+[o]
ß [AltGr]+[s]
§ [AltGr]+[S]
° [AltGr]+[)]
Privacy Switches
PINE64 logo key+F11 WiFi Privacy switch NUM lock LED blinks. 2 blinks = WiFi enabled / killswitch disabled, 3 blinks = WiFi disabled / killswitch enabled. Re-enabling requires reboot (or a command line hack to bind/unbind).
The keyboard uses special firmware that operates separately of the operating system. It detects if either the F10, F11 or F12 key, and the Pine key were pressed for 3 seconds. This disables the peripherals as listed above by cutting off their power. Which has the same result as cutting off the power to each peripheral with a physical switch. This implementation is very secure since the firmware that determines whether a peripheral gets power is not a part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots inside the keyboard's firmware flash memory.
Trackpad
The trackpad is a reasonable size, has a matte finish that that your finger can slide along easily, and two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality. Documentation for the trackpad can be found in Datasheets for Components and Peripherals. The trackpad firmware binary can be flashed from userspace using the provided open source utility (https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater). A fork with more recent changes is also available (https://github.com/jackhumbert/pinebook-pro-keyboard-updater) and may want to be considered instead while feature parity is different.
Before you start:
Your Pinebook Pro should be either fully charged or, preferably, running of mains. This utility will be writing chips on the keyboard and trackpad, so a loss of power during any stage of the update can result in irrecoverable damage to your trackpad or keyboard.
The scripts ought to work on all OSs available for the Pinebook Pro. Some OSs may, however, require installation of relevant dependencies.
There are two keyboard versions of the Pinebook Pro, ISO and ANSI. You need to know which model you have prior to running the updater. FW update steps for both models are listed below.
What you will need:
  • Connection to WiFi
  • An external USB keyboard & mouse. Or access to the Pinebebook Pro via SSH
ISO Model
make
Step 1
sudo ./updater step-1 iso
sudo reboot
Step 2 (after reboot)
sudo ./updater step-2 iso
sudo reboot
ANSI Model
  • NOTE: Running step-1 on the ansi keyboard model will make the keyboard and trackpad inaccessible until step-2 is run, so an external keyboard must be connected to complete the update on this model!
make
Step 1
sudo ./updater step-1 ansi
sudo reboot
sudo ./updater step-2 ansi
sudo reboot
When done, if some of the keys produce in-correct characters, please check your OSes' language settings. For ANSI users, the default OS shipped with English UK as the default language. You can change it to English US if desired.
X-Windows & trackpad settings
Some forum members have found that an adjustment to X-Windows will allow finer motion in the trackpad. If you use the Synaptic mouse/trackpad driver use this command to make the change live;
synclient MinSpeed=0.25
You may experiment with different settings, but 0.25 was tested as helping noticably.
To make the change persist across reboots, change the file /etc/X11/xorg.conf similar to below;
    Section "InputClass"
        Driver "synaptics"
        MatchIsTouchpad "on"
        Option "MinSpeed" "0.25"
    EndSection
synclient FingerLow=30
synclient PalmDetect=1
synclient VertScrollDelta=64
synclient HorizScrollDelta=64
FingerLow has the same value as 'FingerHigh' in one config (30). It is believed to help reduce mouse movement as you lift your finger, but it's not sure if synaptic works like this. You may find this config to be comfortable for daily use.
The right mouse click is emulated by tapping with two fingers on the trackpad. If you feel that this is not very responsive you can try this value:
 synclient MaxTapTime=250
Power Supply
  • Input Power: 5V DC @ 3A
  • USB-C 15W PD quickcharge
LEDs
3. The Num lock, green LED.
4. The Caps lock, green LED.
Webcam
    • 320 x 240
    • 640 x 480
    • 800 x 600
    • 1280 x 720
    • 1600 x 1200
    • 160 x 120
    • 176 x 144
    • 320 x 240
    • 352 x 288
    • 640 x 480
    • 800 x 600
    • 1280 x 720
    • 1600 x 1200
WIP
Microphones
Microphones not working?
If pavucontrol input doesn't show microphone activity try the Pinebook_Pro#Privacy_Switches; once that is set to on do the below; if that still hasn't fixed it you may want to check that the microphone connector is plugged in (see the Pinebook_Pro#Technical_Reference).
run alsamixer from the command line > hit F6 and select the es8316 > hit F4 to get to the capture screen > select the bar labeled ADC >
> increase the gain to 0dB > change the audio profile in pavucontrol to another with input
Additionally:
you may want to modify ADC PGA to get the levels to where you want them
Bluetooth and WiFi
Hardware Overview
Issues
Wi-Fi Capabilities
Bluetooth Capabilities
Disabling Bluetooth
#disable bluetooth once
#confirm
rfkill
#disable bluetooth on boot**
LCD Panel
  • Model: BOE NV140FHM-N49
  • 1920x1080 resolution
  • 60hz refresh rate
  • IPS
  • 1000:1 contrast
  • 250nt brightness
  • 63% sRGB coverage
  • 6 bit colour
  • 30 pin eDP connection
External ports list
  • Left side
    • USB 3, Type A
    • USB 3, Type C
  • Right side
    • USB 2, Type A
    • Standard headset jack
    • MicroSD card slot
Using the UART
$ lsusb
screen /dev/ttyUSB0 1500000
Installing the adapter
Actual installation instructions are a work in progress.
NVME Identify Controller:
Using as data drive
Using as OS root drive
  • MicroSD
  • eMMC
  • NVMe
Please see Bootable Storage.
Caring for the PineBook Pro
Bypass Cables
Using the SPI flash device
  • You need the kernel built with SPI flash device support, which will supply a device similar to:
    /dev/mtd0
  • The Linux package below, will need to be available:
    mtd-utils
  • You can then use this program from the package to write the SPI device:
    flashcp <filename> /dev/mtd0
The procedures described above are a lot less risky than attaching an external SPI flasher and do not require any additional hardware.
At present, April 19th, 2020, there is no good bootloader image to flash into the SPI flash device. This is expected to change, as there are people working on issue.
FAQ
Software tuning guide
Customizing Pinebook Pro's factory OS
Here are some hints on what you can do to customize the Pinebook Pro's factory image (aka mrfixit2001 debian build)
# passwd (and follow prompts)
# groupmod -n myself rock
# chfn -f "John A Doe" myself
# passwd myself
# logout
$ blueman-services
Changing the default hostname
> sudo hostnamectl
         Icon name: computer
            Kernel: Linux 4.4.210
      Architecture: arm64
> sudo vi /etc/hosts
127.0.0.1	localhost
127.0.0.1	My_Hostname
fe00::0		ip6-localnet
ff00::0		ip6-mcastprefix
ff02::1		ip6-allnodes
ff02::2		ip6-allrouters
127.0.1.1       linaro-alip
Perform the following steps:
By default most Linux distros have a boot screen with a picture. To see all the messages, use the following;
vi /etc/default/u-boot
u-boot-update
Improving readability
Some people find that a 14" LCD screen with 1080p, (1920 x 1080), has text and icons a bit too small. There are things you can do to make the screen easier to use & read.
  • Increase the font size
  • Use a font with more pronounce features
  • Increase the various window manager sizes, (like increase the height of the tool bar)
  • Change the color scheme to be easier on the eyes, (even though it may not be bigger, proper contrast can help usability)
  • Change the window manager's decorations, (like using larger icons)
  • Use a workspace manager, (so one application per workspace)
  • When at home or office, use an external monitor
  • Changing the X-Window's DPI, (Dot's Per Inch), can help too
However, do not change the resolution of the LCD screen, otherwise you may end up with a blank / black screen. If that happens, see this trouble shooting section for the fix:
Blank screen after changing builtin LCD resolution
Chromium tweaks
Flags
--disable-low-res-tiling \
--num-raster-threads=6 \
--profiler-timing=0 \
--test-type \
--ignore-gpu-blacklist \
--use-gl=egl \
--enable-pinch \
--flag-switches-begin \
--enable-gpu-rasterization \
--enable-oop-rasterization \
--flag-switches-end
GVIM has performance issue
It appears that using GTK3 can cause very slow scolling, while VIM in a terminal window works fine.
Simply revert back to using GTK2, (how to do so, is somewhat Linux distro specific).
Kernel options
CONFIG_PHY_ROCKCHIP_PCIE=m
Hardware video decoding
The default Debian uses Rockchip supplied kernel module rk-vcodec. To check, something like this can be used;
$ lsmod | grep rk-vcodec
    or
CONFIG_RK_VCODEC=y
Later kernels may use a different option in the configuration as below;
CONFIG_VIDEO_HANTRO=m
Troubleshooting guide
Tips, tricks and other information for troubleshooting your Pinebook Pro
New from the factory - Pinebook Pro won't boot / power on
  • Some Pinebook Pros came from the factory with the eMMC switch in the disabled position. It should be switched towards the back / hinge to enable the eMMC.
  • The eMMC may have come loose during shipment. Open the back and verify that the eMMC is firmly seated.
  • You may want to try unplugging the SD card daughterboard ribbon cable and see if it powers on (remove the battery and peel off a bit of the tape before unplugging it to avoid damage). If it does, try reseating it on both sides. It might have come loose during shipping.
  • It's possible that your eMMC is empty from the factory. Simply create a bootable SD card and see if your Pinebook Pro boots. If so, you can then write an OS image to the eMMC.
Pinebook Pro will not power on after toggling the eMMC enable/disable switch
  • This may happen if you meant to toggle the UART/Headphone switch (9) towards touchpad for headphone use and instead you toggled the eMMC enable/disable switch (24).
  • After reenabling eMMC by toggling switch (24) towards hinge, if Pinebook Pro does not turn on then press the RESET button (28). It is clearly marked 'reset' on the PCB board.
Pinebook Pro will not power on after removing and replacing EMI shielding
  • Closely inspect that the shielding is firmly seated in the clips on all sides. You can be seated in the clips on one axis, and have missed on an another axis.
Pinebook Pro won't boot when using UART console cable
  • If you're using the UART cable sold on the Pine Store, you may want to see if it boots after you disconnect it. Some users report that custom-made cables based on FTDI UART adapters do not cause this issue.
  • Make sure your USB to serial UART device is 3.3v. Many are 5v and some even +-12v. Pinebook Pro's only support 3.3v and may act eratically when using higher voltage. Further, higher voltage could permananetly damage the Pinebook Pro's SoC.
WiFi issues
  • First, check the privacy switches to make sure your WiFi is enabled. They are persistant. See Privacy Switches
  • Next, you may have to modify the /etc/NetworkManager/NetworkManager.conf as root user, and replace managed=false with managed=true. Then reboot.
  • For connections that drop and resume too often, it might be due to WiFi power management from earlier OS releases. Later OS releases either removed WiFi power management, or default to full power. (Power management can be turned off via command line with iw dev wlan0 set power_save off or iwconfig wlan0 power off, although it is not persistent through re-boot.)
  • For connections that drop under load on the default Debian, remove iwconfig wlan0 power off in the file /etc/rc.local.
  • If WiFi is un-usable or often crashes when using an alternate OS, then it might because its WiFi firmware is not appropriate for the WiFi chip in the Pinebook Pro. Try the latest firmware patch from https://gitlab.manjaro.org/tsys/pinebook-firmware/tree/master/brcm
  • After re-enabling WiFi via the privacy switch, you have to reboot to restore function. There is a work around for the default Debian, (and may work with others);
        sudo tee /sys/bus/platform/drivers/dwmmc_rockchip/{un,}bind <<< 'fe310000.dwmmc'
Bluetooth issues
  • When connecting a Bluetooth device, such as a Bluetooth mouse, it does not automatically re-connect on re-boot. In the Bluetooth connection GUI, there is a yellow star for re-connect on boot. Use that button to enable a persistent connection. It can be changed back later.
  • Bluetooth-attached speakers or headset require the pulseaudio-module-bluetooth package. If not already installed, it can be installed with a package manager or with:
sudo apt-get install pulseaudio-module-bluetooth
  • When using Bluetooth-attached speakers or headset and 2.4Ghz WiFi at the same time, you may experience stuttering of the audio. One solution is to use 5Ghz WiFi if you can. Or you may try using a different 2.4Ghz channel, perhaps channel 1 or the top channel, (11 in the USA, or 13/14 in some other countries).
Sound issues
  • Many reports of no sound are due to the OS, incorrect settings, or other software problems (eg. PulseAudio). So first test to see if it is a software or hardware problem, by trying another OS via SD card. (For example, if Debian is installed on the eMMC, try Ubuntu on SD.)
  • If you cannot get sound from the headphone jack, but can get sound from the speakers, then the headphone / UART console switch may be set to the UART mode. You can open the back and check the position of the switch. If set to UART mode, switch it to headphone mode. See the parts layout for the location and correct position of the switch.
  • When using the USB C alternate DisplayPort mode, it is possible that the audio has been re-directed through this path. If your monitor has speakers, see if they work.
  • See manjaro-arm/pinebookpro-post-install /var/lib/alsa/asound.state for some ALSA tweaks.
  • See manjaro-arm/pinebookpro-audio for how to handle 3.5mm jack plug/unplug events with ACPID.
  • Serveral users have reported that one internal speaker had reversed polarity. Thus, sound from the speakers is like an echo effect.
    • Their is a software fix using alsamixer and then enable either "R invert" or "L invert", however, now the headphones have incorrect audio.
    • The permanent fix is to re-wire one speaker, though this requires soldering small wires.
USB docks & USB C alternate mode video
The Pinebook Pro uses the RK3399 SoC (System on a Chip). It supports a video pass through mode on the USB C port using DisplayPort alternate mode. This DisplayPort output comes from the same GPU used to display the built-in LCD.
Here are some selection criteria for successfully using the USB C alternate mode for video:
  • The device must use USB C alternate mode DisplayPort. Not USB C alternate mode HDMI, or other.
  • The device can have a HDMI, DVI, or VGA connector, if it uses an active translater.
  • If USB 3 is also desired from a USB dock, the maximum resolution, frame rate and pixel depth is reduced to half the bandwidth. For example, 4K @ 30hz instead of 60hz.
  • USB docks that also use USB C alternate mode DisplayPort will always have USB 2 available, (480Mbps, half-duplex).
Keys not registering / missing keys when typing
This issue occurs when your thumb or edge of the palm makes contact with left or right tip of the trackpad when you type. This is due to the palm rejection firmware being too forceful. Instead of only disabling the trackpad, so your cursor does not move all over the screen, it disables both the trackpad and the keyboard.
Using Fn+F7 to disable the touchpad will keep it from also disabling the keyboard.
A firmware update has been released to address this.
Key Mapping
Pinebook Pro gets stuck after first reboot in Trackpad Firmware Update
This refers to the firmware update shown here: https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater#update-all-firmwares
ANSI Fn + F keys wrong for F9, F10, F11 and F12
There appears to be a minor firmware issue for ANSI keyboard models of the Pinebook Pro. Some discussion and fixes have been proposed;
After changing builtin LCD resolution, blank screen
Some people find that the text or icons are too small, so they attempt to change the resolution of the built-in display. Afterwards, the display is blank.
Use the following to fix when logged into a text console as yourself, (Control-Alt-F1 through F6). After listing the resolutions, select the native resolution, (1920x1080 aka 1080p).
export DISPLAY=:0.0
xrandr -q
xrandr -s [resolution]
Once your resolution is restored, try using the Tweak app to set scaling, instead.
If the above fix did not work, you can try this:
  • Using a text console, (Control-Alt-F1), login with your normal user ID
  • Edit the file nano ~/.config/monitors.xml
  • Change the "width" value to "1920"
  • Change the "height" value to "1080"
  • If there is more than one monitor configuration listed, edit that one too.
    Be careful to make no other changes. If needed, exit without saving and re-edit.
  • Save the file and exit.
  • Login using the GUI and test
  • If you are still loggied in via the GUI, you will have to reboot using sudo shutdown -r now
    After the reboot, you should be able to login to the GUI login and have the resolution back to normal.
When you have restored usability to your Pinebook Pro's graphical screen, see this section on improving readability and usability:
Cracks in the plastic
There have been multiple reports of cracks in the plastic keyboard & trackpad part of the case. These are generally near here;
  • Hinges
  • USB ports
  • Top side, around the corners
This seems to apply to the first batches in 2019. Later versions of the keyboard & trackpad have used better plastic. With replacements now in the Pine64 Store, it's possible to simply order a replacement.
There have been a few reports of cracks in the plastic around the LCD display, but these appear to be less common. There are replacement LCDs with bezel available in the Pine64 Store.
PineBookPro Hardware Compatibility
Please contribute to the hardware compatibility page, which lists hardware which has been tested with the PBP, whether successful or not!
Technical Reference
NOTE: a basic 3d model to print replacement back-screw standoffs is available on Thingiverse [1] pending release of something more definitive
Pinebook Pro Internal Layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
Key Internal Parts
Number Type Descriptor
3 Socket Speakers socket
4 Socket Trackpad socket
5 Component Left speaker
7 Socket Keyboard Socket
11 Socket Battery socket
12 Component Trackpad
13 Component Battery
14 Component Right speaker
15 Socket MicroSD card slot
17 Socket USB 2.0 Type A
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0 Type A
33 Socket USB 3.0 Type C
Smallboard detailed picture
Bootable Storage
At this time, the Pinebook Pro ships with a Debian + MATE build with uboot on the eMMC. Its boot order is: SD, then eMMC. Booting off USB storage is not currently available, but will be in the future.
(An update has been pushed for the default Debian + MATE build that improves compatibility with booting other OSs from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
eMMC information
If the eMMC module is enabled after boot from an SD card, you can detect this change with the following commands as user "root";
echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
Boot sequence details
Pinebook Pro Dimensions
  • Weight: 1.26Kg
  • Screws
    • Philips head type screws
    • M2 flat head machine screws (measurements in mm)
    • 4 x Small screws (used along the front edge): Head - 3.44, Thread Diameter - 1.97, Thread Length - 2.1, Overall length - 3.05
    • 6 x Large screws: Head - 3.44, Thread Diameter - 1.97, Thread Length - 4.41, Overall Length - 5.85
  • Rubber Feet
    • 18mm diameter
    • 3mm height
    • Dome shaped
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
    • Cortex-M0 CPU
    • Architecture: Armv6-M
    • 32 bit only
GPU Architecture
  • Frequency 650MHz
  • RAM Memory:
    • LPDDR4
  • Storage Memory:
    • 64GB eMMC module, can be upgraded to a 128GB eMMC module. (The initial PINE64 community build version shipped with a 128GB eMMC.)
Video out
  • USB-C Alt mode DP
Expansion Ports
  • MicroSD card:
    • Bootable
  • USB ports:
Additional hardware
Battery
Display
Audio
  • Built-in stereo speakers:
    • Oval in design
    • 3 mm high x 20 mm x 30 mm
Network
  • WiFi:
    • 802.11 b/g/n/ac
    • Dual band: 2.4Ghz & 5Ghz
    • Single antenna
  • Bluetooth 5.0
Optional NVMe adapter
  • PCIe 2.x, 5GT/s per lane
Versions
Other Resources
