Pinebook Pro
Contents
- 1 User Guide
- 1.1 Introducing PineBook Pro
- 1.2 Software and OS Image Downloads
- 1.3 Keyboard
- 1.4 Trackpad
- 1.5 Power Supply
- 1.6 LEDs
- 1.7 Webcam
- 1.8 Microphones
- 1.9 Bluetooth and WiFi
- 1.10 LCD Panel
- 1.11 External ports list
- 1.12 Using the UART
- 1.13 Using the optional NVMe adapter
- 1.14 Caring for the PineBook Pro
- 1.15 Using the SPI flash device
- 1.16 FAQ
- 2 Software tuning guide
- 3 Troubleshooting guide
- 3.1 New from the factory - Pinebook Pro won't boot / power on
- 3.2 Pinebook Pro will not power on after toggling the eMMC enable/disable switch
- 3.3 Pinebook Pro will not power on after removing and replacing EMI shielding
- 3.4 Pinebook Pro won't boot when using UART console cable
- 3.5 WiFi issues
- 3.6 Bluetooth issues
- 3.7 Sound issues
- 3.8 USB docks & USB C alternate mode video
- 3.9 Keys not registering / missing keys when typing
- 3.10 Key Mapping
- 3.11 Pinebook Pro gets stuck after first reboot in Trackpad Firmware Update
- 3.12 ANSI Fn + F keys wrong for F9, F10, F11 and F12
- 3.13 After changing builtin LCD resolution, blank screen
- 3.14 Cracks in the plastic
- 4 PineBookPro Hardware Compatibility
- 5 Technical Reference
- 5.1 Accessing the Internals - Disassembly and Reassembly
- 5.2 Pinebook Pro Internal Layout
- 5.3 Bootable Storage
- 5.4 Pinebook Pro Dimensions
- 5.5 SoC and Memory Specification
- 5.6 Additional hardware
- 5.7 Pinebook Pro Schematics and Certifications
- 5.8 Datasheets for Components and Peripherals
- 5.9 Versions
- 6 Skinning and Case Customization
- 7 Other Resources
User Guide
Default Debian MATE Desktop Quick Start
The default Operating system that ships with the Pinebook Pro is Debian 9 with MATE desktop. It has been built by a community developer called MrFixIt2001, who can be reached on the PINE64 forum or in the chats. The newest release of the build can downloaded directly from MrFixIt2001's GitHub.
The default username and password is:
- Username: rock
- Password: rock
You can change the default rock username and rock home directory by logging into root (credentials root/root) instead of the default 'rock' user and running the following in root terminal and substituting desired username for NewUser:
usermod -l NewUser -d /home/NewUser -m rock
Once you log back into your new user, Bluetooth will complain about no transfer folder location. To fix this open terminal and type:
blueman-services
From here, select incoming folder under the 'transfer' tab.
The build includes a custom updater capable of updating uboot, the Linux kernel and numerous packages. The update script can be ran from both the userspace and the commandline. You will find a small 'Update Script' applet icon in the bottom panel, next to time and date applet.
You can run the script from the terminal using:
sudo /usr/bin/mrfixit_update.sh
More information about the default OS build and version history can be found on the Default OS update log PINE64 forum thread.
Pinebook Pro images
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
Debian Desktop (microSD and eMMC Boot)
Bionic LXDE (microSD and eMMC Boot)
Bionic Mate (microSD and eMMC Boot)
Fedora (microSD and eMMC Boot)
Manjaro ARM (microSD and eMMC Boot)
note: When upgrading from a prior release of Manjaro to version 20.1, you may need to increase the backlight as the number of steps for the backlight exposed by the kernel was changed from 256 to 4096
OpenSUSE (microSD and eMMC Boot)
Armbian (microSD and eMMC Boot)
NetBSD (microSD and eMMC Boot)
Chromium (microSD and eMMC Boot)
Android 7.1 (microSD Boot)
Android 7.1 (eMMC)
Debian Installer for Pinebook Pro
Gentoo Script for Pinebook Pro
Kali Script for Pinebook Pro (microSD and eMMC Boot)
- ayufan's Linux build repo
- ayufan's Chromium OS build repo
- mrfixit2001's Linux debian desktop build repo
Keyboard
Typing special characters
Character | Key combination/sequence |
Ä, Ö, Ü, ä, ö, ü | [AltGr]+'[' followed by [A], [O], [U], [a], [o] or [u] |
µ | [AltGr]+[m] |
Ø, ø | [AltGr]+[O], [AltGr]+[o] |
@ | [AltGr]+[q] (as on the German layout) |
ß | [AltGr]+[s] |
§ | [AltGr]+[S] |
° | [AltGr]+[)] |
Privacy Switches
Combination | Effect | Description | Notes |
PINE64 logo key+F10 | Microphone Privacy switch | CAPs lock LED blinks. 2 blinks = enabled, 3 blinks = disabled | |
PINE64 logo key+F11 | WiFi Privacy switch | NUM lock LED blinks. 2 blinks = enabled, 3 blinks = disabled. | Re-enabling requires reboot (or a command line hack to bind/unbind). |
PINE64 logo key+F12 | Camera privacy switch | CAPs lock and NUM lock LEDs blink together. 2 blinks = enabled, 3 blinks = disabled |
The keyboard uses special firmware that operates separately of the operating system. It detects if either the F10, F11 or F12 key, and the Pine key were pressed for 3 seconds. This disables the peripherals as listed above by cutting off their power. Which has the same result as cutting off the power to each peripheral with a physical switch. This implementation is very secure since the firmware that determines whether a peripheral gets power is not a part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots.
Trackpad
The trackpad is a reasonable size, has a matte finish that that your finger can slide along easily, and two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality. Documentation for the trackpad can be found in Datasheets for Components and Peripherals. The trackpad firmware binary can be flashed from userspace using the provided open source utility (https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater).
Before you start:
Your Pinebook Pro should be either fully charged or, preferably, running of mains. This utility will be writing chips on the keyboard and trackpad, so a loss of power during any stage of the update can result in irrecoverable damage to your trackpad or keyboard.
The scripts ought to work on all OSs available for the Pinebook Pro. Some OSs may, however, require installation of relevant dependencies.
There are two keyboard versions of the Pinebook Pro, ISO and ANSI. You need to know which model you have prior to running the updater. FW update steps for both models are listed below.
What you will need:
- Your Pinebook Pro fully charged or running off of mains power
- Connection to WiFi
- An external USB keyboard & mouse. Or access to the Pinebebook Pro via SSH
ISO Model
git clone https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater cd pinebook-pro-keyboard-updater sudo apt-get install build-essential libusb-1.0-0-dev xxd make
Step 1
cd pinebook-pro-keyboard-updater sudo ./updater step-1 iso sudo reboot
Step 2 (after reboot)
cd pinebook-pro-keyboard-updater sudo ./updater step-2 iso sudo reboot
ANSI Model
- NOTE: Running step-1 on the ansi keyboard model will make the keyboard and trackpad inaccessible until step-2 is run, so an external keyboard must be connected to complete the update on this model!
Step 1
cd pinebook-pro-keyboard-updater sudo ./updater step-1 ansi sudo reboot
cd pinebook-pro-keyboard-updater sudo ./updater step-2 ansi sudo reboot
When done, if some of the keys produce in-correct characters, please check your OSes' language settings. For ANSI users, the default OS shipped with English UK as the default language. You can change it to English US if desired.
X-Windows & trackpad settings
Some forum members have found that an adjustment to X-Windows will allow finer motion in the trackpad. If you use the Synaptic mouse/trackpad driver use this command to make the change live;
synclient MinSpeed=0.25
You may experiment with different settings, but 0.25 was tested as helping noticably.
To make the change persist across reboots, change the file /etc/X11/xorg.conf
similar to below;
Section "InputClass" Identifier "touchpad catchall" Driver "synaptics" MatchIsTouchpad "on" MatchDevicePath "/dev/input/event*" Option "MinSpeed" "0.25" EndSection
The line Option "MinSpeed" "0.25"
is the change.
synclient MinSpeed=0.25 synclient FingerLow=30 synclient PalmDetect=1 synclient VertScrollDelta=64 synclient HorizScrollDelta=64
FingerLow
has the same value as 'FingerHigh' in one config (30). It is believed to help reduce mouse movement as you lift your finger, but it's not sure if synaptic works like this.
You may find this config to be comfortable for daily use.
The right mouse click
is emulated by tapping with two fingers on the trackpad. If you feel that this is not very responsive you can try this value:
synclient MaxTapTime=250
Power Supply
- Input Power: 5V DC @ 3A
- Mechanical: 3.5mm OD / 1.35mm ID, Barrel jack
- USB-C 15W PD quickcharge
- Only use one power input at a time, barrel jack OR USB-C
LEDs
- 1. The red LED next to the barrel-port indicates charging. It will illuminate when mains power is supplied to the Pinebook Pro from either the standard power supply unit or a USB-C smartphone charger.
- 2. The power indicator LED on the Pinebook Pro supports three different colours: green, amber and red. It is also capable of flashing/blinking to indicate activity. In the default Debian with MATE build, green LED means power and red means suspend (amber is unused).
- 3. The Num lock, green LED.
- 4. The Caps lock, green LED.
Webcam
- Streaming video resolutions supported, (un-compressed):
- 320 x 240
- 640 x 480
- 800 x 600
- 1280 x 720
- 1600 x 1200
- Still frame resolutions supported:
- 160 x 120
- 176 x 144
- 320 x 240
- 352 x 288
- 640 x 480
- 800 x 600
- 1280 x 720
- 1600 x 1200
- Some people test with the application Cheese
WIP
Microphones
Microphones not working?
If pavucontrol input doesn't show microphone activity try the Pinebook_Pro#Privacy_Switches; once that is set to on do the below; if that still hasn't fixed it you may want to check that the microphone connector is plugged in (see the Pinebook_Pro#Technical_Reference).
run alsamixer from the command line > hit F6 and select the es8316 > hit F4 to get to the capture screen > select the bar labeled ADC > > increase the gain to 0dB > change the audio profile in pavucontrol to another with input Additionally: you may want to modify ADC PGA to get the levels to where you want them
Bluetooth and WiFi
Hardware Overview
Issues
Wi-Fi Capabilities
Be aware that Linux userspace utilities, such as iw
, may report inaccurate information about the capabilities of wireless devices. Parameter values derived from vendor datasheets, or direct testing, should be preferred to the outputs of hardware-querying tools.
Bluetooth Capabilities
Disabling Bluetooth
#disable bluetooth once sudo rfkill block bluetooth && #confirm rfkill
#disable bluetooth on boot** sudo systemctl enable rfkill-block@bluetooth
LCD Panel
- Model: BOE NV140FHM-N49
- 14.0" (35.56cm) diagonal size
- 1920x1080 resolution
- 60hz refresh rate
- IPS
- 1000:1 contrast
- 250nt brightness
- 63% sRGB coverage
- 6 bit colour
- 30 pin eDP connection
External ports list
- Left side
- Barrel jack for power, (with LED)
- USB 3, Type A
- USB 3, Type C
- Right side
- USB 2, Type A
- Standard headset jack
- MicroSD card slot
Using the UART
$ lsusb
screen /dev/ttyUSB0 1500000
Installing the adapter
Actual installation instructions are a work in progress.
$ sudo nvme id-ctrl /dev/nvme0 NVME Identify Controller: ... ps 0 : mp:9.00W operational enlat:0 exlat:0 rrt:0 rrl:0 rwt:0 rwl:0 idle_power:- active_power:- ps 1 : mp:4.60W operational enlat:0 exlat:0 rrt:1 rrl:1 rwt:1 rwl:1 idle_power:- active_power:- ps 2 : mp:3.80W operational enlat:0 exlat:0 rrt:2 rrl:2 rwt:2 rwl:2 idle_power:- active_power:- ps 3 : mp:0.0450W non-operational enlat:2000 exlat:2000 rrt:3 rrl:3 rwt:3 rwl:3 idle_power:- active_power:- ps 4 : mp:0.0040W non-operational enlat:6000 exlat:8000 rrt:4 rrl:4 rwt:4 rwl:4 idle_power:- active_power:- $ sudo nvme get-feature /dev/nvme0 -f 2 get-feature:0x2 (Power Management), Current value:00000000 $ sudo nvme set-feature /dev/nvme0 -f 2 -v 2 -s set-feature:02 (Power Management), value:0x000002
Using as data drive
Using as OS root drive
- MicroSD
- eMMC
- NVMe
It is also possible to initially boot off an eMMC or SD card, then transfer to a root file system on the NVMe. Currently, it is necessary to have the U-Boot code on an eMMC or SD card. (A forum member posted here about using a modified version of U-Boot with NVMe drivers, that uses /boot
and /
off the NVMe drive. So this may change in the future.)
Please see Bootable Storage.
Bypass Cables
- 14″ Pinebook Lithium Battery Pack Removal Guide
- 14″ Pinebook LCD Panel Screen Removal Guide
- 14″ Pinebook eMMC Module Removal Guide
- You need the kernel built with SPI flash device support, which will supply a device similar to:
/dev/mtd0
- The Linux package below, will need to be available:
mtd-utils
- You can then use this program from the package to write the SPI device:
flashcp <filename> /dev/mtd0
The procedures described above are a lot less risky than attaching an external SPI flasher and do not require any additional hardware.
At present, April 19th, 2020, there is no good bootloader image to flash into the SPI flash device. This is expected to change, as there are people working on issue.
FAQ
Customizing Pinebook Pro's factory OS
Here are some hints on what you can do to customize the Pinebook Pro's factory image (aka mrfixit2001 debian build)
- Reboot (this is just to ensure all background processes belong to the user are not running... there are other ways to achieve this but this way is easy)
- Once the machine reboots press Alt-Ctrl-F1 to bring up a text terminal
- Login as root (login: root, password: root)
- Set a strong password for the root user using the following command and it's prompts:
# passwd (and follow prompts)
- Rename the rock user to your prefered username (replace myself with whatever you like):
- Rename the rock group to match your preferred username:
# groupmod -n myself rock
- Put your name in the account, (replace "John A Doe" with your name):
# chfn -f "John A Doe" myself
- Set a strong password for the normal user:
# passwd myself
- Log out of the text terminal:
# logout
- Press Alt-Ctrl-F7 to go back to the login screen and then login as the normal user
- Open text terminal to fix login error: "Configured directory for incoming files does not exist";
$ blueman-services
Changing the default hostname
> sudo hostnamectl Static hostname: Debian-Desktop Icon name: computer Machine ID: dccbddccbdccbdccbdccbdccbdccbccb Boot ID: ea99ea99ea99ea99ea99ea99ea99ea99 Operating System: Debian GNU/Linux 9 (stretch) Kernel: Linux 4.4.210 Architecture: arm64
Then you should backup and edit your /etc/hosts
entry's name;
> sudo cp -p /etc/hosts /etc/hosts.`date +%Y%m%d` > sudo vi /etc/hosts 127.0.0.1 localhost 127.0.0.1 My_Hostname ::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters 127.0.1.1 linaro-alip
Perform the following steps:
- On the tool bar, hover over the Chromium icon
- Using the right mouse button, select Properties
- In the Command: line section, add
--password-store=basic
before the%U
- Use the x Close button to save the change
- Install ImageMagick which will do the conversion
- Create a 1920 x 1080 picture. For the best results, use a PNG image (It supports lossless compression).
- From the directory in which your new image is stored run the following commands
- Convert your image to the bootsplash raw format using imagemagick convert.
- Create a backup copy of your current splash screen
- Copy your new splash screen into place
- Set the correct permissions on the splash.fb file
- If you do not want to see kernel console text messages, make sure you don't have Plymouth installed
By default most Linux distros have a boot screen with a picture. To see all the messages, use the following;
- Backup and edit the U-Boot configuration file:
cp -p /etc/default/u-boot /etc/default/u-boot.`date +%Y%m%d` chmod a-w /etc/default/u-boot.`date +%Y%m%d` vi /etc/default/u-boot
- Update the U-Boot configuration:
u-boot-update
- Test and verify you get what you think you should be seeing.
Chromium tweaks
Flags
--disable-low-res-tiling \ --num-raster-threads=6 \ --profiler-timing=0 \ --disable-composited-antialiasing \ --test-type \ --show-component-extension-options \ --ignore-gpu-blacklist \ --use-gl=egl \ --ppapi-flash-path=/usr/lib/chromium-browser/pepper/libpepflashplayer.so \ --ppapi-flash-version=32.0.0.255 \ --enable-pinch \ --flag-switches-begin \ --enable-gpu-rasterization \ --enable-oop-rasterization \ --flag-switches-end
GVIM has performance issue
It appears that using GTK3 can cause very slow scolling, while VIM in a terminal window works fine.
Simply revert back to using GTK2, (how to do so, is somewhat Linux distro specific).
Kernel options
$ zgrep -i rockchip_pcie /proc/config.gz # CONFIG_ROCKCHIP_PCIE_DMA_OBJ is not set CONFIG_PHY_ROCKCHIP_PCIE=m
If it's listed as =m
, then it's a module. You can see if the module is loaded with;
$ lsmod | grep -i rockchip_pcie phy_rockchip_pcie 16384 0
Hardware video decoding
The default Debian uses Rockchip supplied kernel module rk-vcodec
. To check, something like this can be used;
$ lsmod | grep rk-vcodec or $ zgrep RK_VCODEC /proc/config.gz CONFIG_RK_VCODEC=y
Later kernels may use a different option in the configuration as below;
$ zgrep HANTRO /proc/config.gz CONFIG_VIDEO_HANTRO=m CONFIG_VIDEO_HANTRO_ROCKCHIP=y
Tips, tricks and other information for troubleshooting your Pinebook Pro
- Some Pinebook Pros came from the factory with the eMMC switch in the disabled position. It should be switched towards the back / hinge to enable the eMMC.
- The eMMC may have come loose during shipment. Open the back and verify that the eMMC is firmly seated.
- You may want to try unplugging the SD card daughterboard ribbon cable and see if it powers on (remove the battery and peel off a bit of the tape before unplugging it to avoid damage). If it does, try reseating it on both sides. It might have come loose during shipping.
- It's possible that your eMMC is empty from the factory. Simply create a bootable SD card and see if your Pinebook Pro boots. If so, you can then write an OS image to the eMMC.
- This may happen if you meant to toggle the UART/Headphone switch (9) towards touchpad for headphone use and instead you toggled the eMMC enable/disable switch (24).
- After reenabling eMMC by toggling switch (24) towards hinge, if Pinebook Pro does not turn on then press the RESET button (28). It is clearly marked 'reset' on the PCB board.
- Closely inspect that the shielding is firmly seated in the clips on all sides. You can be seated in the clips on one axis, and have missed on an another axis.
- If you're using the UART cable sold on the Pine Store, you may want to see if it boots after you disconnect it. Some users report that custom-made cables based on FTDI UART adapters do not cause this issue.
- Make sure your USB to serial UART device is 3.3v. Many are 5v and some even +-12v. Pinebook Pro's only support 3.3v and may act eratically when using higher voltage. Further, higher voltage could permananetly damage the Pinebook Pro's SoC.
WiFi issues
- First, check the privacy switches to make sure your WiFi is enabled. They are persistant. See Privacy Switches
- Next, you may have to modify the
/etc/NetworkManager/NetworkManager.conf
as root user, and replacemanaged=false
withmanaged=true
. Then reboot. - For connections that drop and resume too often, it might be due to WiFi power management from earlier OS releases. Later OS releases either removed WiFi power management, or default to full power. (Power management can be turned off via command line with
iw dev wlan0 set power_save off
oriwconfig wlan0 power off
, although it is not persistent through re-boot.) - For connections that drop under load on the default Debian, remove
in the file/etc/rc.local
. - If WiFi is un-usable or often crashes when using an alternate OS, then it might because its WiFi firmware is not appropriate for the WiFi chip in the Pinebook Pro. Try the latest firmware patch from https://gitlab.manjaro.org/tsys/pinebook-firmware/tree/master/brcm
- After re-enabling WiFi via the privacy switch, you have to reboot to restore function. There is a work around for the default Debian, (and may work with others);
sudo tee /sys/bus/platform/drivers/dwmmc_rockchip/{un,}bind <<< 'fe310000.dwmmc'
Bluetooth issues
- When connecting a Bluetooth device, such as a Bluetooth mouse, it does not automatically re-connect on re-boot. In the Bluetooth connection GUI, there is a yellow star for re-connect on boot. Use that button to enable a persistent connection. It can be changed back later.
- Bluetooth-attached speakers or headset require the pulseaudio-module-bluetooth package. If not already installed, it can be installed with a package manager or with:
sudo apt-get install pulseaudio-module-bluetooth
- When using Bluetooth-attached speakers or headset and 2.4Ghz WiFi at the same time, you may experience stuttering of the audio. One solution is to use 5Ghz WiFi if you can. Or you may try using a different 2.4Ghz channel, perhaps channel 1 or the top channel, (11 in the USA, or 13/14 in some other countries).
Sound issues
- Many reports of no sound are due to the OS, incorrect settings, or other software problems (eg. PulseAudio). So first test to see if it is a software or hardware problem, by trying another OS via SD card. (For example, if Debian is installed on the eMMC, try Ubuntu on SD.)
- If you cannot get sound from the headphone jack, but can get sound from the speakers, then the headphone / UART console switch may be set to the UART mode. You can open the back and check the position of the switch. If set to UART mode, switch it to headphone mode. See the parts layout for the location and correct position of the switch.
- When using the USB C alternate DisplayPort mode, it is possible that the audio has been re-directed through this path. If your monitor has speakers, see if they work.
- See manjaro-arm/pinebookpro-post-install /var/lib/alsa/asound.state for some ALSA tweaks.
- See manjaro-arm/pinebookpro-audio for how to handle 3.5mm jack plug/unplug events with ACPID.
- Serveral users have reported that one internal speaker had reversed polarity. Thus, sound from the speakers is like an echo effect.
- Their is a software fix using alsamixer and then enable either "R invert" or "L invert", however, now the headphones have incorrect audio.
- The permanent fix is to re-wire one speaker, though this requires soldering small wires.
The Pinebook Pro uses the RK3399 SoC (System on a Chip). It supports a video pass through mode on the USB C port using DisplayPort alternate mode. This DisplayPort output comes from the same GPU used to display the built-in LCD.
Here are some selection criteria for successfully using the USB C alternate mode for video:
- The device must use USB C alternate mode DisplayPort. Not USB C alternate mode HDMI, or other.
- The device can have a HDMI, DVI, or VGA connector, if it uses an active translater.
- If USB 3 is also desired from a USB dock, the maximum resolution, frame rate and pixel depth is reduced to half the bandwidth. For example, 4K @ 30hz instead of 60hz.
- USB docks that also use USB C alternate mode DisplayPort will always have USB 2 available, (480Mbps, half-duplex).
This issue occurs when your thumb or edge of the palm makes contact with left or right tip of the trackpad when you type. This is due to the palm rejection firmware being too forceful. Instead of only disabling the trackpad, so your cursor does not move all over the screen, it disables both the trackpad and the keyboard.
Using Fn+F7 to disable the touchpad will keep it from also disabling the keyboard.
A firmware update has been released to address this.
Key Mapping
- See this /etc/udev/hwdb.d/10-usb-kbd.hwdb for some key mapping tweaks
This refers to the firmware update shown here: https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater#update-all-firmwares
- If the system is not responding after the 1st reboot, it's might be easiest to do a system restore, and follow up by running the second step of the trackpad firmware update.
- System restore https://forum.pine64.org/showthread.php?tid=8229
- Firmware update https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater#update-all-firmwares
There appears to be a minor firmware issue for ANSI keyboard models of the Pinebook Pro. Some discussion and fixes have been proposed;
- Discussion thread Fn + F keys screwy for F9, F10, F11 and F12
- Proposed fix (ANSI) Fn + F(9-12) has wrong assignment after firmware update #14
Some people find that the text or icons are too small, so they attempt to change the resolution of the built-in display. Afterwards, the display is blank.
Use the following to fix when logged into a text console as yourself, (Control-Alt-F1 through F6). After listing the resolutions, select the native resolution, (1920x1080 aka 1080p).
export DISPLAY=:0.0 xrandr -q xrandr -s [resolution]
Once your resolution is restored, try using the Tweak app to set scaling, instead.
If the above fix did not work, you can try this:
- Using a text console, (Control-Alt-F1), login with your normal user ID
- Edit the file
nano ~/.config/monitors.xml
- Change the "width" value to "1920"
- Change the "height" value to "1080"
- If there is more than one monitor configuration listed, edit that one too.
Be careful to make no other changes. If needed exit without saving and re-edit.
- Save the file and exit.
- Login using the GUI and test
- If you are still loggied in via the GUI, you will have to reboot using
sudo shutdown -r now
After the reboot, you should be able to login to the GUI login and have the resolution back to normal.
There have been multiple reports of cracks in the plastic keyboard & trackpad part of the case. These are generally near here;
- Hinges
- USB ports
- Top side, around the corners
This seems to apply to the first batches in 2019. Later versions of the keyboard & trackpad have used better plastic. With replacements now in the Pine64 Store, it's possible to simply order a replacement.
There have been a few reports of cracks in the plastic around the LCD display, but these appear to be less common. There are replacement LCDs with bezel available in the Pine64 Store.
Please contribute to the hardware compatibility page, which lists hardware which has been tested with the PBP, whether successful or not!
Technical Reference
NOTE: a basic 3d model to print replacement back-screw standoffs is available on Thingiverse [1] pending release of something more definitive
Main chips
- RK3399 system-on-chip (1)
- LPDDR4 SDRAM (21)
- SPI NOR flash memory (29)
- eMMC flash memory (26)
- WiFi/BT module (27)
Key Internal Parts
Number | Type | Descriptor |
1 | Component | RK3399 System-On-Chip |
2 | Socket | PCIe 4X socket for optional NVMe adapter |
3 | Socket | Speakers socket |
4 | Socket | Trackpad socket |
5 | Component | Left speaker |
6 | Connector | Male power bridge connector |
7 | Socket | Keyboard Socket |
8 | Component | Optional NVMe SSD adapter |
9 | Switch | UART/Audio switch - outputs UART via headphone jack |
10 | Socket | Female power bridge socket |
11 | Socket | Battery socket |
12 | Component | Trackpad |
13 | Component | Battery |
14 | Component | Right speaker |
15 | Socket | MicroSD card slot |
16 | Socket | Headphone / UART jack |
17 | Socket | USB 2.0 Type A |
18 | Socket | Daughterboard-to-mainboard ribbon cable socket |
19 | Cable | Daughterboard-to-mainboard ribbon cable |
20 | Component | microphone |
21 | Component | LPDDR4 RAM |
22 | Socket | Mainboard-to-daughterboard ribbon cable socket |
23 | Socket | Microphone socket |
24 | Switch | Switch to hardware disable eMMC |
25 | Antenna | BT/WiFI antenna |
26 | Component | eMMC flash memory module |
27 | Component | BT/WiFi module chip |
28 | Buttons | Reset and recovery buttons |
29 | Component | SPI flash storage |
30 | Socket | eDP LCD socket |
31 | Socket | Power in barrel socket |
32 | Socket | USB 3.0 Type A |
33 | Socket | USB 3.0 Type C |
Smallboard detailed picture
Bootable Storage
At this time, the Pinebook Pro ships with a Debian + MATE build with uboot on the eMMC. Its boot order is: SD, then eMMC. Booting off USB storage is not currently available, but will be in the future.
(An update has been pushed for the default Debian + MATE build that improves compatibility with booting other OSs from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
eMMC information
- mmcblk1boot0 - eMMC standard boot0 partition, may be 4MB
- mmcblk1boot1 - eMMC standard boot1 partition, may be 4MB
- mmcblk1rpmb - eMMC standard secure data partition, may be 16MB
- mmcblk1 - This block contains the user areas
If the eMMC module is enabled after boot from an SD card, you can detect this change with the following command:
echo 'fe330000.sdhci' | tee /sys/bus/platform/drivers/sdhci-arasan/unbind echo 'fe330000.sdhci' | tee /sys/bus/platform/drivers/sdhci-arasan/bind
Boot sequence details
- Dimensions: 329mm x 220mm x 12mm (WxDxH)
- Weight: 1.26Kg
- Screws
- Philips head type screws
- M2 flat head machine screws (measurements in mm)
- 4 x Small screws (used along the front edge): Head - 3.44, Thread Diameter - 1.97, Thread Length - 2.1, Overall length - 3.05
- 6 x Large screws: Head - 3.44, Thread Diameter - 1.97, Thread Length - 4.41, Overall Length - 5.85
- Rubber Feet
- 18mm diameter
- 3mm height
- Dome shaped
- Based on Rockchip RK3399
- big.LITTLE architecture: Dual Cortex-A72 + Quad Cortex-A53, 64-bit CPU
- Full implementation of the ARM architecture v8-A instruction set (both AArch64 and AArch32)
- ARM Neon Advanced SIMD (single instruction, multiple data) support for accelerated media and signal processing computation
- ARMv8 Cryptography Extensions
- VFPv4 floating point unit supporting single and double-precision operations
- Hardware virtualization support
- TrustZone technology support
- Full CoreSight debug solution
- One isolated voltage domain to support DVFS
- Cortex-A72 (big cluster):
- Dual-core Cortex-A72 up to 2.0GHz CPU
- Superscalar, variable-length, out-of-order pipeline
- L1 cache 48KB Icache and 32KB Dcache for each A72
- L2 cache 1024KB for big cluster
- Cortex-A53 (little cluster):
- Quad-core Cortex-A53 up to 1.5GHz CPU
- In-order pipeline with symmetric dual-issue of most instructions
- L1 cache 32KB Icache and 32KB Dcache for each A53
- L2 cache 512KB for little cluster
- Cortex-M0 (control processors):
- Cortex-M0 CPU
- Two Cortex-M0 cooperate with the central processors
- Architecture: Armv6-M
- Thumb/Thumb2 instruction set
- 32 bit only
GPU Architecture
- ARM Mali-T860MP4 Quad-core GPU
- The highest performance GPUs built on Arm Mali’s famous Midgard architecture, the Mali-T860 GPU is designed for complex graphics use cases and provide stunning visuals for UHD content.
- Frequency 650MHz
- Throughput 1300Mtri/s, 10.4Gpix/s
- OpenGL® ES 1.1, 1.2, 2.0, 3.1, 3.2., Vulkan 1.0*., OpenCL™ 1.1, 1.2., DirectX® 11 FL11_1., RenderScript™.
- RAM Memory:
- LPDDR4
- Dual memory channels on the CPU, each 32 bits wide
- Quad memory channels on the RAM chip, each 16 bits wide, 2 bonded together for each CPU channel
- 4GB as a single 366 pin mobile RAM chip
- Storage Memory:
- 64GB eMMC module, can be upgraded to a 128GB eMMC module. (The initial PINE64 community build version shipped with a 128GB eMMC.)
- eMMC version 5.1, HS400, 8 bit on RK3399 side
Video out
- USB-C Alt mode DP
- Up to 3840x2160 p60, dependant on adapter, (2 lanes verses 4 lanes)
Expansion Ports
- MicroSD card:
- Bootable
- Supports SD, SDHC and SDXC cards, up to 512GB tested. SDXC standard says 2TB is the maximum.
- Version SD3.0, (MMC 4.5), up to 50MB/s
- SD card Application Performance Class 1 (A1), (or better), recommended by some users, for better IOPS
- USB ports:
- 1 x USB 2.0 Type-A Host Port, bootable
- 1 x USB 3.0 Type-A Host Port, 5Gbps, is not bootable
- 1 x USB 3.0 Type-C OTG Port, 5Gbps, (includes laptop charging function), is not bootable
- Note that high power USB devices may not work reliably on a PBP. Or they may draw enough power to drain the battery even when the PBP is plugged into A.C. One alternative is externally powered USB devices.
- Headphone jack switchable to UART console mux circuit
Additional hardware
Battery
- Lithium Polymer Battery (10,000 mAH)
Display
- 14.0" 1920x1080 IPS LCD panel
Audio
- 3.5mm stereo earphone/microphone plug
- Built-in stereo speakers:
- Oval in design
- 3 mm high x 20 mm x 30 mm
Network
- WiFi:
- 802.11 b/g/n/ac
- Dual band: 2.4Ghz & 5Ghz
- Single antenna
- Bluetooth 5.0
Optional NVMe adapter
- PCIe 2.x, 5GT/s per lane
- 4 PCIe lanes, can not be bifurcated, (however, can be used with 1 or 2 lane NVMe cards)
- M keyed, though M+B keyed devices will work too
- Maximum length for M.2 card is 80mm (M.2 2280). The following sizes will also work: 2230, 2242, 2260
- Power: 2.5W continuous, 8.25W peak momentary
- Does not support SATA M.2 cards
- Does not support USB M.2 cards
- Pinebook Pro Main Board Schematic And Silkscreen:
- Pinebook Pro Daughter Board Schematic:
- Optional Pinebook Pro NVMe Adapter Schematic:
- Serial Console Earphone Jack Pinout:
- Pinebook Pro Case:
- Pinebook Pro Certifications:
- Rockchip RK3399 SoC information:
- LPDDR4 (366 Balls) SDRAM:
- eMMC information:
- SPI NOR Flash information:
- Wireless related info:
- Audio Codec (ES8316)
- LCD Panel:
- Internal USB 2 hub:
- Touchpad information:
- Keyboard information:
- Sinowealth SH68F83 Datasheet
- US ANSI: XK-HS002 MB27716023
- Full HD Camera sensor:
- Lithium Battery information:
- NVMe adapter:
Versions
- Template files for creating custom skins. Each includes template layers for art placement, and CUT lines.
