Pinebook Pro
Contents
User Guide
Introducing PineBook Pro
Pinebook Pro running stock Debian with MATE
Pinebook Pro
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
Keyboard
Typing special characters
µ [AltGr]+[m]
Ø, ø [AltGr]+[O], [AltGr]+[o]
ß [AltGr]+[s]
§ [AltGr]+[S]
° [AltGr]+[)]
Privacy Switches
Combination Effect Description
PINE64 logo key+F11 WiFi Privacy switch NUM lock LED blinks. 2 blinks = enabled, 3 blinks = disabled. Re-enabling requires reboot (or a command line hack to bind/unbind).
(Press the PINE64 logo key plus Fn (10/11/12) for 3 seconds)
The keyboard uses special firmware that operates separately of the operating system. It detects if either the F10, F11 or F12 key, and the Pine key were pressed for 3 seconds. This disables the peripherals as listed above by cutting off their power. Which has the same result as cutting off the power to each peripheral with a physical switch. This implementation is very secure since the firmware that determines whether a peripheral gets power is not a part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots.
Trackpad
The trackpad is large, smooth (metallic to-the-touch), and has two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality. Documentation for the trackpad can be found in Datasheets for Components and Peripherals. The trackpad firmware binary can be flashed from userspace using the provided open source utility (https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater).
Before you start:
Your Pinebook Pro should be either fully charged or, preferably, running of mains. This utility will be writing chips on the keyboard and trackpad, so a loss of power during any stage of the update can result in irrecoverable damage to your trackpad or keyboard.
The scripts ought to work on all OSs available for the Pinebook Pro. Some OSs may, however, require installation of relevant dependencies.
What you will need:
  • Connection to WiFi
  • An external USB keyboard or access to the Pinebebook Pro via ssh
make
Step 1
sudo ./updater step-1
sudo reboot
Step 2 (after reboot)
sudo ./updater step-2
sudo reboot
Power Supply
  • Input Power: 5V DC @ 3A
  • USB-C 15W PD quickcharge
LEDs
3. The Num lock, green LED.
4. The Caps lock, green LED.
Webcam
  • 1080p resolution
WIP
Microphones
Some Pinebook Pro chassis have 2 microphone labeled holes. Only the right hole is populated with a microphone.
Bluetooth and WiFi
WIP
LCD Panel
  • 1080p resolution
WIP
Using the UART
Headphone Jack UART wiring reference
With the UART switch in the ON position, console is relayed via the audiojack and the laptop's sound is turned OFF. PINE64 store sells a dedicated serial console but you can make your own if you have a serial console USB 2.0 adapter and old/ broken headphones. If you do make your own cable, please ensure that you are using a 3.3v interface (such as the CH340, FTDI-232R or PL2303 - which are often sold in 3.3v and 5v variants) to avoid damage to the CPU.
$ lsusb
screen /dev/ttyUSB0 1500000
Current versions of U-Boot do not use the UART for console output. The console function is activated by the Linux kernel. Thus, if you use a non-Pinebook Pro Linux distro and want the UART as a console, you have to manually enable it.
The optional NVMe adapter allows the use of M.2 cards that support the NVMe standard, (but not SATA standard).
Installing the adapter
The v2.1 SSD adapter that is shipped with the initial Pinebook Pro batches had significant issues. A repair kit will be shipped to address those issues.
(If necessary, they can be modified to work. There is an unofficial tutorial on the forums describing these modifications.)
Using as data drive
As long as the kernel in use has both the PCIe and NVMe drivers, you should be able to use a NVMe drive as a data drive. It can automatically mount when booting from either the eMMC or an SD card. This applies to both Linux and FreeBSD, using the normal partitioning and file system creation tools. Android and Chromium OS require testing.
Using as OS root drive
It is not possible to boot directly off an NVMe drive. The SoC does not include the NVMe boot code, so the NVMe is not in the SoC's boot order.
However, it is possible to initially boot off an eMMC or SD card, then transfer to a root file system on the NVMe. Currently, it is necessary to have the U-Boot code on an eMMC or SD card. (A forum member posted here about using a modified version of U-Boot with NVMe drivers, that uses /boot and / off the NVMe drive. So this may change in the future.)
Please see Bootable Storage.
Caring for the PineBook Pro
Bypass Cables
FAQ
Troubleshooting guide
Tips, tricks and other information for troubleshooting your Pinebook Pro
New from the factory - Pinebook Pro won't boot / power on
  • Some Pinebook Pros came from the factory with the eMMC switch in the disabled position. It should be switched towards the back / hinge to enable the eMMC.
  • The eMMC may have come loose during shipment. Open the back and verify that the eMMC is firmly seated.
  • You may want to try unplugging the SD card daughterboard ribbon cable and see if it powers on (remove the battery and peel off a bit of the tape before unplugging it to avoid damage). If it does, try reseating it on both sides. It might have come loose during shipping.
  • It's possible that your eMMC is empty from the factory. Simply create a bootable SD card and see if your Pinebook Pro boots. If so, you can then write an OS image to the eMMC.
Pinebook Pro won't boot when using UART console cable
  • If you're using the UART cable sold on the Pine Store, you may want to see if it boots after you disconnect it. Some users report that custom-made cables based on FTDI UART adapters do not cause this issue.
Pinebook Pro will not power on after toggling the eMMC enable/disable switch
  • This may happen if you meant to toggle the UART/Headphone switch (9) towards touchpad for headphone use and instead you toggled the eMMC enable/disable switch (24).
  • After reenabling eMMC by toggling switch (24) towards hinge, if Pinebook Pro does not turn on then press the RESET button (28). It is clearly marked 'reset' on the PCB board.
Keys not registering / missing keys when typing
This issue occurs when your thumb or edge of the palm makes contact with left or right tip of the trackpad when you type. This is due to the palm rejection firmware being too forceful. Instead of only disabling the trackpad, so your cursor does not move all over the screen, it disables both the trackpad and the keyboard.
Using Fn+F7 to disable the touchpad will keep it from also disabling the keyboard.
A firmware update has been released to address this.
WiFi issues
  • First, check the privacy switches to make sure your WiFi is enabled. They are persistant. See Privacy Switches
  • Next, you may have to modify the file "/etc/NetworkManager/NetworkManager.conf" as user "root", and replace "managed=false" with "managed=true". Then reboot.
  • For connections that drop and resume too often, it might be due to WiFi power management from earlier OS releases. Later OS releases either removed WiFi power management, or default to full power. (Power management can be turned off via command line with iw dev wlan0 set power_save off or iwconfig wlan0 power off, although it is not persistent through re-boot.)
  • If WiFi is un-usable or often crashes when using an alternate OS, then it might because its WiFi firmware is not appropriate for the WiFi chip in the Pinebook Pro. Try the latest firmware patch from;
https://gitlab.manjaro.org/tsys/pinebook-firmware/tree/master/brcm
Bluetooth issues
  • If attempting to use Bluetooth attached speakers or headset, you will need to have the pulseaudio-module-bluetooth package installed. If not installed, you can do so with;
sudo apt-get install pulseaudio-module-bluetooth
Sound issues
  • Many reports of no sound are due to the OS, incorrect settings, or other software problems (eg. PulseAudio). So first test to see if it is a software or hardware problem, by trying another OS via SD card. (For example, if Debian is installed on the eMMC, try Ubuntu on SD.)
  • If you cannot get sound from the headphone jack, but can get sound from the speakers, then the headphone / UART console switch may be set to the UART mode. You can open the back and check the position of the switch. If set to UART mode, switch it to headphone mode. See the parts layout for the location and correct position of the switch.
  • When using the USB C alternate DisplayPort mode, it is possible that the audio has been re-directed through this path. If your monitor has speakers, then see if they work.
USB docks & USB C alternate mode video
The Pinebook Pro uses the RK3399 SoC, (System on a Chip). It supports a video pass through mode on the USB C port called alternate mode, using DisplayPort. This DisplayPort would come from the same GPU as the builtin LCD is displaying. Here are some selection criteria for successfully using the USB C alternate mode for video:
  • The device must use USB C alternate mode DisplayPort. Not USB C alternate mode HDMI, or other.
  • The device can have a HDMI, (or VGA) connector, if it uses an active translater from DisplayPort to HDMI, (or VGA)
  • If USB 3 is also desired for a USB dock, the maximum resolution, frame rate and pixel depth is reduced to half the bandwidth. For example, 4K @ 30hz instead of 60hz.
  • USB docks that also use USB C alternate mode DisplayPort always have USB 2 available, (480Mbps, half-duplex).
Accessory Hardware Compatibility
Technical Reference
Pinebook Pro Internal Layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
Key Internal Parts
Number Type Descriptor
3 Socket Speakers socket
4 Socket Trackpad socket
5 Component Left speaker
7 Socket Keyboard Socket
11 Socket Battery socket
12 Component Trackpad
13 Component Battery
14 Component Right speaker
15 Socket MicroSD card slot
17 Socket USB 2.0 Type A
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0 Type A
33 Socket USB 3.0 Type C
Bootable Storage
At this time, the Pinebook Pro ships with a Debian + MATE build with uboot on the eMMC. Its boot order is: SD, then eMMC. Booting off USB storage is not currently available, but will be in the future.
(An update has been pushed for the default Debian + MATE build that improves compatibility with booting other OSs from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
eMMC information
Boot sequence details
Pinebook Pro Dimensions
  • Weight: 1.26Kg
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
    • Cortex-M0 CPU
    • Architecture: Armv6-M
    • 32 bit only
GPU Architecture
  • Frequency 650MHz
  • RAM Memory:
    • LPDDR4
  • Storage Memory:
    • 64GB eMMC module, can be upgraded to a 128GB eMMC module. (The initial PINE64 community build version shipped with a 128GB eMMC.)
Battery
Display
  • 14.1" 1920x1080 IPS LCD panel
Video out
  • USB-C Alt mode DP
Audio
  • Build in stereo speakers
Network
  • WiFi:
    • 802.11 b/g/n/ac
    • Dual band: 2.4Ghz & 5Ghz
    • Single antenna
  • Bluetooth 5.0
Expansion Ports
  • MicroSD card:
    • Bootable
    • Supports SD, SDHC and SDXC cards, up to 512GB
  • USB ports:
  • Optional NVMe adapter:
    • PCIe 2.x, 5GT/s per lane
    • Maximum length for M.2 card is 80mm (M.2 2280)
Other Resources
