Pinebook Pro
Revision as of 13:17, 12 November 2019 by Arwen (talk | contribs) (→‎Power Supply: Separated details, attempting to make them clearer; added line about using 1 source at a time.)
User Guide
Introducing PineBook Pro
Pinebook Pro running stock Debian with MATE
Pinebook Pro
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
Keyboard
The keyboard firmware is open sourced can be flashed from userspace using the provided utility.
German umlaute and the like
On the UK Layout you can type umlaute by pressing [AltGr]+["] followed by [A], [O], [U], [a], [o] or [u]. The key combination [AltGr]+[s] generates the letter 'ß'.
Privacy Switches
Combination Effect Description
PINE64 logo key+F11 WiFi Privacy switch NUM lock LED blinks. 2 blinks = enabled, 3 blinks = disabled. Re-enabling requires reboot.
(Press the PINE64 logo key plus Fn (10/11/12) for 3 seconds)
The keyboard uses special firmware that operates separately of the operating system. It detects if either the F10, F11 or F12 key, and the Pine key were pressed for 3 seconds. This disables the peripherals as listed above by cutting off their power. Which has the same result as cutting off the power to each peripheral with a physical switch. This implementation is very secure since the firmware that determines whether a peripheral gets power is not a part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots.
Trackpad
The trackpad is large, smooth (metallic to-the-touch), and has two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality.
The trackpad firmware is open sourced and can be flashed from userspace using the provided utility (https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater[1]). However, the firmware shipped with the provided utility (as of 11/07/2019) can result in a bricked trackpad and thus should not be used until a revised version of said firmware has been published to the linked repo.
Documentation trackpad can be found in Datasheets for Components and Peripherals.
Power Supply
  • Input Power: 5V DC @ 3A
  • USB-C 15W PD quickcharge
LEDs
3. The Num lock, green LED.
4. The Caps lock, green LED.
Webcam
  • 1080p resolution
WIP
Microphones
WIP
Bluetooth and WiFi
WIP
LCD Panel
  • 1080p resolution
WIP
Using UART
Headphone Jack UART wiring reference
UART output is enabled by flipping the UART switch to on position (item 9). To do so you need to remove the Pinebook Pro's bottom cover - please follow proper disassembly and reassembly protocol. The OFF position is towards the touchpad, the ON position is towards the display hinges.
With the UART switch in the 'on' position, console is relayed via the audiojack and the laptop's sound is turned off. PINE64 store sells a dedicated serial console but you can make your own if you have a serial console USB 2.0 adapter and old/ broken headphones.
$ lsusb
screen /dev/ttyUSB0 1500000
Using the NVMe adapter
The optional NVMe adapter allows the use of M.2 cards that support the NVMe standard, (but not SATA standard).
Installing the adapter
stub at present
Using as data drive
As long as the kernel in use has both the PCIe and NVMe drivers, you should be able to use a NVMe drive as a data drive. Even automounting at boot, (from eMMC or SD card). This applies to both Linux and FreeBSD, though Android or Chromium OS may need testing. Simply use the normal partitioning and file system creation tools.
Using as OS root drive
stub at present
Using the PineBook Pro
Bypass Cables
Technical Reference
Pinebook Pro Internal Layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
Key Internal Parts
Number Type Descriptor
3 Socket Speakers socket
4 Socket Trackpad socket
5 Component Left speaker
7 Socket Keyboard Socket
11 Socket Battery socket
12 Component Trackpad
13 Component Battery
14 Component Right speaker
15 Socket Micro SD socket
17 Socket USB 2.0
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0
33 Socket USB type C
Bootable Storage
At this time, the Pinebook Pro ships with a Debian + MATE build with uboot on the eMMC. Its boot order is: SD, then eMMC. Booting off USB storage is not currently available, but will be in the future.
(An update has been pushed for the default Debian + MATE build that improves compatibility with booting other OSs from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
eMMC information
  • mmcblk1rpmb - eMMC standard secure data partition. may be 16MB
Boot sequence details
The RK3399's mask 32KB ROM boot code looks for the next stage of code at byte off-set 32768. This is where u-Boot code would reside on any media that is bootable.
Pinebook Pro Dimensions
  • Weight: 1.26Kg
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
    • Thumb instruction set
    • 32 bit only
GPU Architecture
  • Frequency 650MHz
  • RAM Memory:
    • LPDDR4
  • Storage Memory:
    • 64GB eMMC module, can be upgraded to a 128GB eMMC module. (The initial PINE64 community build version shipped with a 128GB eMMC.)
Battery
Display
  • 14.1" 1920x1080 IPS LCD panel
Video out
  • USB-C Alt mode DP up to 3840x2160 p60
Audio
  • Build in stereo speakers
Network
  • WiFi:
    • 802.11 b/g/n/ac
    • Dual band: 2.4Ghz & 5Ghz
    • Single antenna
  • Bluetooth 5.0
Expansion Ports
  • MicroSD card:
    • Bootable
    • Supports SD, SDHC and SDXC cards, up to 256GB
    • Version SD3.0, up to 50MB/s
  • USB ports:
  • Optional NVMe adapter:
    • PCIe 2.x, 5GT/s per lane
    • Maximum length for M.2 card is 80mm (M.2 2280)
  • Pinebook Pro Certifications:
    • Not Yet Available
Troubleshooting guide
Tips, tricks and other information for troubleshooting your Pinebook Pro
New from the factory - Pinebook Pro won't boot / power on
  • Some Pinebook Pros came from the factory with the eMMC switch in the disabled position. It should be switched towards the back / hinge to enable the eMMC.
  • The eMMC may have come loose during shipment. Open the back and verify that the eMMC is firmly seated.
  • You may want to try unplugging the SD card daughterboard ribbon cable and see if it powers on (remove the battery and peel off a bit of the tape before unplugging it to avoid damage). If it does, try reseating it on both sides. It might have come loose during shipping.
  • It's possible that your eMMC is empty from the factory. Simply create a bootable SD card and see if your Pinebook Pro boots. If so, you can then write an OS image to the eMMC.
Pinebook Pro won't boot when using UART console cable
  • If you're using the UART cable sold on the Pine Store, you may want to see if it boots after you disconnect it. Some users report that custom-made cables based on FTDI UART adapters do not cause this issue.
Pinebook Pro will not power on after toggling the eMMC enable/disable switch
  • This may happen if you meant to toggle the UART/Headphone switch (9) towards touchpad for headphone use and instead you toggled the eMMC enable/disable switch (24).
  • After reenabling eMMC by toggling switch (24) towards hinge, if Pinebook Pro does not turn on then press the RESET button (28). It is clearly marked 'reset' on the PCB board.
Keys not registering / missing keys when typing
This issue occurs when your thumb or edge of the palm makes contact with left or right tip of the trackpad when you type. This is due to the palm rejection firmware being too forceful. Instead of only disabling the trackpad, so your cursor does not move all over the screen, it disables both the trackpad and the keyboard.
Using Fn+F7 to disable the touchpad will keep it from also disabling the keyboard.
A firmware update is planned to address this.
Other Resources
