Pinebook Pro
Revision as of 16:56, 3 November 2019 by Zaius (talk | contribs) (→‎Using UART)
User Guide
Introducing PineBook Pro
Pinebook Pro running stock Debian with MATE
Pinebook Pro
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
Keyboard
The keyboard firmware is open sourced can be flashed from userspace using the provided utility.
German umlaute and the like
On the UK Layout you can type umlaute by pressing [AltGr]+["] followed by [A], [O], [U], [a], [o] or [u]. The key combination [AltGr]+[s] generates the letter 'ß'.
Privacy Switches
Combination Effect Description
PINE64 logo key+F11 WiFi Privacy switch NUM lock LED blinks. 2 blinks = enabled, 3 blinks = disabled. Re-enabling requires reboot.
(Press the PINE64 logo key plus Fn (10/11/12) for 3 seconds)
The keyboard uses special firmware that operates separately of the operating system. It detects if either the F10, F11 or F12 key, and the Pine key were pressed for 3 seconds. This disables the peripherals as listed above by cutting off their power. Which has the same result as cutting off the power to each peripheral with a physical switch. This implementation is very secure since the firmware that determines whether a peripheral gets power is not a part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots.
Trackpad
The trackpad is large, smooth (metallic to-the-touch), and has two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality.
The trackpad firmware is open sourced can be flashed from userspace using the provided utility.
Documentation trackpad can be found in Datasheets for Components and Peripherals.
Power Supply
Input Power: DC 5V @ 3A 3.5mm OD/ 1.35mm ID Barrel jack or USB-C 15W PD quickcharge
LEDs
3. The Num lock, green LED.
4. The Caps lock, green LED.
Webcam
WIP
Microphones
WIP
Bluetooth and WiFi
WIP
LCD Panel
WIP
Using UART
Headphone Jack UART wiering reference
UART output is enabled by flipping the UART switch to on position (item 9). To do so you need to remove the Pinebook Pro's bottom cover - please follow proper dissasembly and reassembly protocol.
With the UART switch in the 'on' position, console is relayed via the audiojack and the laptop's sound is turned off. PINE64 store sells a dedicated serial console but you can make your own if you have a serial console USB 2.0 adapter and old/ broken headphones.
screen /dev/ttyUSB0 1500000
Using the PineBook Pro
Bypass Cables
Technical Reference
During reassembly, make sure that the back-screw standoffs are in place and seated correctly. To reassemble the Pinebook Pro, slide the bottom section into place so it meets the front lip of the keyboard section. Secure the front section (where the trackpad is located) in place using the short screws in the front left and right corners. Then proceed to pop in the bottom pannel into place. Secure the bottom section (where hinges are located) by screwing in the left and right corners. Then screw in the remaining screws and run your finger though the rim on the chassis to make sure its fitted correctly. Note that the front uses the remaining 2 short screws.
Pinebook Pro Internal Layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
Key Internal Parts
Number Type Descriptor
3 Socket Speakers socket
4 Socket Trackpad socket
5 Component Left speaker
7 Socket Keyboard Socket
11 Socket Battery socket
12 Component Trackpad
13 Component Battery
14 Component Right speaker
15 Socket Micro SD socket
17 Socket USB 2.0
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0
33 Socket USB type C
Bootable Storage
At this time, the Pinebook Pro ships with a Debian + MATE build with uboot on the eMMC. Its boot order is: SD, USB 2.0, eMMC. Booting off USB 3.0 storage is not currently available, but will be in the future.
(An update has been pushed for the default Debian + MATE build that improves compatibility with booting other OSs from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
eMMC information
  • mmcblk1rpmb - eMMC standard secure data partition. may be 16MB
Boot sequence details
The RK3399's mask 32KB ROM boot code looks for the next stage of code at byte off-set 32768. This is where u-Boot code would reside on any media that is bootable.
Pinebook Pro Dimensions
  • Weight: 1.26Kg
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
    • Thumb instruction set
    • 32 bit only
GPU Architecture
  • Frequency 650MHz
  • RAM Memory:
    • LPDDR4
  • Storage Memory:
    • 64GB eMMC module, can be upgraded to a 128GB eMMC module. (The initial PINE64 community build version shipped with a 128GB eMMC.)
Battery
Display
  • 14.1" 1920x1080 IPS LCD panel
Video out
  • USB-C Alt mode DP up to 3840x2160 p60
Audio
  • Build in stereo speakers
Network
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
Expansion Ports
  • MicroSD card:
    • Bootable
    • Supports SD, SDHC and SDXC cards, up to 256GB
    • Version SD3.0, up to 50MB/s
  • USB ports:
    • 1 x USB 3.0 Type-A Host Port, 5Gbps, can be bootable based on u-boot software
  • Optional NVMe adapter:
    • PCIe 2.x, 5GT/s per lane
    • 4 PCIe lanes, can not be bifurcated
    • Maximum length for M.2 card is 80mm (M.2 2280)
  • Pinebook Pro Certifications:
    • Not Yet Available
Trouble shooting guide
Tips, tricks and other information for trouble shooting your Pinebook Pro
New Pinebook won't boot / power on
Some user's Pinebook Pros came from the factory with the eMMC switch in the disabled position. It's supposed to be towards the back / hinge.
Alternatively, the eMMC may have come loose during shipment. Simply open the back and verify that the eMMC is firmly seated.
Other Resources
