Pinebook Pro
Revision as of 19:16, 6 October 2019 by Arwen (talk | contribs) (→‎Bootable Storage: Added card after SD; Mention SoC when referring to hard-coded boot order; Made some of the USB 3.0 wording flow better.)
Pinebook Pro running stock Debian with MATE
Pinebook Pro Internal Layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
Key Internal Parts
Number Type Descriptor
3 Socket Speakers socket
4 Socket Trackpad socket
5 Component Left speaker
7 Socket Keyboard Socket
11 Socket Battery socket
12 Component Trackpad
13 Component Battery
14 Component Right speaker
15 Socket Micro SD socket
17 Socket USB 2.0
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0
33 Socket USB type C
Bootable Storage
The Pinebook Pro is capable of booting from SPI, eMMC, USB 2.0, USB 3.0, or an SD card. It cannot boot from USB-C.
At this time, the boot order for the custom uboot (on eMMC) on the default Debian MATE build is: SD, then USB 2.0, then eMMC. This boot order is different then the default hard-coded boot order of the SoC: SPI, eMMC, USB 2.0, USB 3.0, SD card. Booting off USB 3.0 storage is not currently available, but will be in the future.
Please note that PCIe, which is the interface used for an NVMe SSD on the Pinebook Pro, is not bootable on the RK3399 and therefore is not a part of the boot hierarchy. It is possible to run the desired OS from NVMe by pointing extlinux (on eMMC) to rootfs flashed to NVMe. This requires the following on eMMC in a /boot partition: uboot, the Kernel image, DTB, extlinux.conf
Bypass Cables
Keyboard and Trackpad
The Pinebook Pro is available in two keyboard configurations: ISO and ANSI. Both the keyboard and trackpad in the Pinebook Pro use the USB 2.0 protocol and show up as such in xinput. The keyboard features function (Fn) keys in the F-key row, which include display brightness controls, sound volume, trackpad lock, and other functionality. There is also a custom PINE64 logo key that functions as menu/SUPER key, that also a secondary functionality for setting the privacy switches.
The trackpad is large, smooth (metallic to-the-touch), and has two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality.
The keyboard and trackpad firmware is open sourced can be flashed from userspace using the provided utility.
Documentation for the keyboard and trackpad can be found in Datasheets for Components and Peripherals.
Privacy Switches
Combination Effect Description
PINE64 logo key+F11 WiFi Privacy switch NUM lock LED blinks. 2 blinks = enabled, 3 blinks = disabled. Re-enabling requires reboot.
(Press the PINE64 logo key plus Fn (10/11/12) for 3 seconds)
The keyboard uses special firmware that operates separately of the operating system. It detects if either the F10, F11 or F12 key, and the Pine key were pressed for 3 seconds. This disables the peripherals as listed above by cutting off their power. Which has the same result as cutting off the power to each peripheral with physical switch. This implementation is very secure since the firmware that determines whether a peripheral gets power is not a part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots.
LEDs
1. The amber LED next to the barrel-port indicates charging. It will illuminate when mains power is supplied to the Pinebook Pro from either the standard power supply unit or a USB-C smartphone charger.
3. The Num lock, green LED.
4. The Caps lock, green LED.
Webcam
WIP
Microphones
WIP
Bluetooth and WiFi
WIP
LCD Panel
WIP
Pinebook Pro
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
Pinebook Pro Information
  • Weight: 1.26Kg
  • Input Power: DC 5V @ 3A 3.5mm OD/ 1.35mm ID Barrel jack or USB-C 15W PD quickcharge
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
GPU Architecture
  • Frequency 650MHz
  • LPDDR4 RAM Memory Variants: Dual Channels 4GB.
  • Storage Memory:
    • 64GB eMMC module, can be upgraded to a 128GB eMMC module. (The initial PINE64 community build version shipped with a 128GB eMMC.)
Battery
Display
  • 14.1" 1920x1080 IPS LCD panel
Video
  • USB-C Alt model DP up to 3840x2160p60
Audio
  • Build in stereo speakers
Network
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
Expansion Ports
  • microSD - bootable, supports SDHC and SDXC, storage up to 256GB
  • USB ports:
    • 1 x USB 2.0 Type-A Host Port
    • 1 x USB 3.0 Type-A Host Port
    • 1 x USB 3.0 Type-C OTG Port, (includes laptop charging function)
  • earphone plug with UART console mux circuit
  • Optional NVMe adapter:
    • PCIe 2.x, 5GT/s per lane
    • 4 PCIe lanes
    • Maximum length for M.2 card is 80mm (M.2 2280)
  • Pinebook Pro Certifications:
    • Not Yet Available
Other Resources
