Pinebook Pro
Revision as of 21:27, 24 September 2019 by Tllim (talk | contribs) (→‎Pinebook)
Pinebook Pro
Under 'Pinebook Pro Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software. The list includes OS images and descriptions of:
Under 'Service Guides for Pinebook' you can instructions guides concerning disassembly of:
Pinebook Pro Information
  • Weight: 1.26Kg
  • Input Power: DC 5V @ 3A 3.5mm OD/ 1.35mm ID Barrel jack or USB-C 15W PD quickcharge
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72:
    • DSP & SIMD extensions
    • VFPv4 floating point
  • Cortex-A53:
GPU Architecture
  • Frequency 650MHz
  • LPDDR4 RAM Memory Variants: Dual Channels 4GB.
  • Storage Memory:
    • 64GB eMMC module, can be upgrade to 128GB eMMC module. The initiial PINE64 community build version comes wit 128GB eMMC configuration
    • 128Mb built-in SPI Flash memory
Battery
  • Lithium Polymer Battery (10,000mAH)
Display
  • 14.1" 1920x1080 IPS LCD panel
Video
  • USB-C Alt model DP up to 3840x2160p60
Audio
  • Build in stereo speaker
Network
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
Expansion Ports
  • USB - 1x USB2.0 Type-A Host Port, 1x USB3.0 Type-A Host Port, 1x USB3.0 Type-C OTG Port
  • optional NVMe adapter
  • earphone plug with UART console mux circuit
  • Pinebook Pro Certifications:
    • Not Yet Available
Other Resources
