Pinebook Pro
Revision as of 17:04, 20 February 2023 by Fxc (talk | contribs) (style fix)
The Pinebook Pro is a Linux and *BSD ARM laptop from PINE64. It is built to be a compelling alternative to mid-ranged Chromebooks that people convert into Linux laptops.
It features an IPS 1080p 14″ LCD panel, a premium magnesium alloy shell, high capacity eMMC storage, a 10,000 mAh capacity battery, and the modularity that only an open source project can deliver with the dimensions of 329mm x 220mm x 12mm (WxDxH). Key features include the RK3399 SOC, USB-C for data, video-out and power-in (3A 5V), privacy switches for the microphone, BT/WiFi module, camera and expandable storage via NVMe (PCIe x4) with an optional adapter. The Pinebook Pro is equipped with 4GB LPDDR4 system memory, high capacity eMMC flash storage, and 128Mb SPI boot Flash. The I/O includes: 1 x micro SD card reader (bootable), 1 x USB 2.0, 1 x USB 3.0, 1 x USB type C Host with DP 1.2 and power-in, PCIe x4 for an NVMe SSD drive (requires an optional adapter), and UART (via the headphone jack by setting an internal switch). The keyboard and touchpad both use the USB 2.0 protocol. The LCD panel uses eDP MiPi display protocol.
User Guide
On first boot, it will ask for certain information such as your timezone location, keyboard layout, username, password, and hostname. Most of these should be self-explanatory. Note that the hostname it asks for should be thought of as the "codename" of your machine, and if you don't know what it's about, you can make something up (use a single word, all lower case, no punctuation, e.g. "pbpro").
Pinebook Pro images
Under Pinebook Pro Software Releases you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
Keyboard
The Pinebook Pro is available in two keyboard configurations: ISO and ANSI. Both the keyboard and touchpad in the Pinebook Pro use the USB 2.0 protocol and show up as such in xinput. The keyboard features function (Fn) keys in the F-key row, which include display brightness controls, sound volume, touchpad lock, and other functionality. There is also a custom PINE64 logo key that functions as Menu/Super key. It has also a secondary functionality for setting the privacy switches.
Warning: DO NOT update the keyboard firmware before checking which keyboard IC your Pinebook Pro has. Some Pinebook Pro were delivered with a SH61F83 instead of a SH68F83. The SH61F83 can only be written 8 times, this will render the keyboard and touchpad unusable if this limit is reached when step 1 is flashed, see the Reddit SH61F83 thread. The keyboard IC corresponds to U23 on the top layer silkscreen of the main board. It is located under the keyboard flat flexible cable.
Typing special characters
The UK ISO Layout does not have dedicated keys for characters like the German umlauts (Ä, Ö, Ü, etc). Certain characters can still be generated by means of either key combinations or key sequences.
µ [AltGr]+[m]
Ø, ø [AltGr]+[O], [AltGr]+[o]
ß [AltGr]+[s]
§ [AltGr]+[S]
° [AltGr]+[)]
Privacy Switches
PINE64 logo key+F11 WiFi Privacy switch NUM lock LED blinks. 2 blinks = WiFi enabled / privacy switch disabled, 3 blinks = WiFi disabled / privacy switch enabled. Re-enabling requires reboot (or a command line hack to bind/unbind).
PINE64 logo key+F12 Camera privacy switch CAPs lock and NUM lock LEDs blink together. 2 blinks = enabled, 3 blinks = disabled Can use tools like lsusb to detect camera's presence. If not detected, check privacy switch.
The keyboard operates on firmware independent of the operating system. It detects if one of the F10, F11 or F12 keys is pressed in combination with the Pine key for 3 seconds. Doing so disables power to the appropriate peripheral, thereby disabling it. This has the same effect as cutting off the power to each peripheral with a physical switch. This implementation is very secure, since the firmware that determines whether a peripheral gets power is not part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots inside the keyboard's firmware flash memory.
Basic summary of replacing keyboard
This guide is very basic and should be fleshed out with (better) pictures. There just isn't a list of steps anywhere else yet.
Here's what the replacement keyboard looks like:
Replacement keyboard (front) Replacement keyboard (back)
Step 0: If changing from ISO keyboard to ANSI keyboard, or vice versa, be sure to have a system capable of running the firmware updater that you can access either remotely or with a USB keyboard beyond the internal keyboard, as the firmware for each is very different and keys won't work correctly. See https://forum.pine64.org/showthread.php?tid=8407 (and for NetBSD, https://forum.pine64.org/showthread.php?tid=8716).
Step 1: The remove back back panel.
There are 10 screws on the back that must be removed, and the back panel detached. I recommend using a PH0 bit. The speakers may remain attached via glue to the case and should be carefully pried off. When this is done, taking photos of how everything looks now can help put it all back together later.
Remove the back panel
Step 2: Places to unscrew.
There are 3 items screwed into the keyboard frame that must be removed. There are 2 large screws for daughter board, 3 large screws and 1 small screw for mainboard, and 4 small screws for battery. Be sure to not lose them. I recommend a PH00 bit for the large screws on the daughter and main boards and a PH1 bit for the small screws on the battery and mainboard.
Step 3: Remove the battery.
Once the battery screws are removed, it should be unplugged from the mainboard and removed. Note that there are two unconnected cables lying around, that should remain unconnected. They are used when the battery is disconnected entirely.
Zoom on the mainboard Zoom on the daughterboard
Step 4: Unplug the ribbon cables.
NOTE: you should remove the M.2 adapter board now if you have one installed. See elsewhere in this wiki for instructions on how to install/remove that piece.
There are several ribbon cables. To remove, flip up the tab and gentle pull the ribbon out.
  • One cable runs from the mainboard to the daughterboard underneath the battery. Detach from both ends. With the battery removed, detach from keyboard shell, and set aside for the new keyboard shell.
  • One cable runs between the touchpad and the mainboard. Detach from both ends, and also set aside.
  • One cable runs between the keyboard and the mainboard. This one remains attached to the keyboard and only needs to be detached from the mainboard.
  • One cable from the LCD attaches near the lid hinge. It should be just unplugged.
Step 5: Detach microphone, speakers, and antenna.
One of the Pinebook Pro microphones after removal
The speakers, microphone, and antenna don't have to be detached from the mainboard, but they need to be detached from the keyboard shell. The microphones are held in place by tape, and the speakers have sticky sides. The speakers are found obviously, but the microphones (two of) can be found between the battery and the hinge area. Each microphone can be carefully pulled/wedged out of its position by a small screwdriver or pick. The antenna, similar to the microphones, is found near the hinge area and to the top left of the battery.
Step 6: Remove mainboard and daughterboard.
At this point, the mainboard and daughterboards should be removed. When unscrewed (see Step 2) they should pull out fairly easily. Put them aside (including microphones and speakers if left attached.)
All boards removed
Step 7: Detach the LCD panel.
Step 2 didn't tell you, there are 6 more screws to remove here, 3 for each of the hinges. I recommend a PH1 bit for these screws. Unscrew these and the LCD panel will be able to be removed. You may have to jiggle or move the hinges for this. When detached, be sure to place the LCD panel such that the display is protected.
Display detached Display detached (front)
Step 8: Try not to break your touchpad
NOTE This section really feels like you're going to break something.
The touchpad is glued to the keyboard shell and it's glued well. There are two places it is glued to. If you can, only the middle must be force-detached. You will think you're going to break it. Gently apply increasing force until the glue begins to detach (you will hear a crackle as it comes off), and continue very slowly until the whole thing is detached. This may take minutes due to that feeling you're going to break it.
I found it helpful to lift the top left plastic bit on the keyboard to unstick that portion of the touchpad, then push on the top left portion of the touchpad to unstick the rest of the touchpad.
Unmouting the touchpad Unmouting the touchpad Unmouting the touchpad
Step 9: Over the hill, touchpad goes into new shell.
In the new keyboard shell put the touchpad back where it was, hopefully the glue will remain sufficiently attached. If there is a glue issue, this guide unfortunately has no advice currently.
Install the touchpad
Step 10: Reattach the LCD panel.
The LCD panel should slot back into the keyboard frame, the same way it came out. If the hinges were moved, they should be *very* *gently* closed such that the LCD panel and keyboard closed like normal for the remaining steps.
Step 11: Tape it out.
Move any tape from the old keyboard shell to the new one. These items protect the mainboard and daughterboard, and keep various wires in their right place. Some are grey and some are black. For tape that holds the speakers, microhones, or their cables in place, do not reattach yet.
Step 12: Board install.
Install the mainboard, the daughtboard, and their connecting ribbon cable. Be sure to put the boards in place, 2 large flat screws for the daughterboard, 3 large flat screws and one small screw for the mainboard, before attempting to place the ribbon.
Step 13: Microphone, speaker, and antenna install.
Reattach the microphones, antenna, and speakers to their respective areas, making sure that both are properly oriented - the speaker "out" faces up, and the microphone cables as connected must face up (these are opposite directions.)
Step 14: Reattach other ribbon cables.
NOTE: this would be a good time to attach/install the M.2 adapter board if that is desired. See elsewhere in this wiki for those instructions.
The LCD panel, keyboard and touchpad ribbon cables should be reattached. Make sure the flap is open, insert the ribbon into the slot (a portion of the cable will disappear), and push the flap down. The cable should not be easy to pull out.
Step 15: Reattach the battery, and final re-tape.
The battery should be installed with the 4 screws holding it in place, and the connector attached to the mainboard. Be sure to keep the two other cables remain unconnected. Ensure all wires and other tapes are held in place.
Step 16: Reattach the back panel.
Put the back panel back on, and reattach the 10 screws.
Step 17: If you changed from ISO to ANSI or from ANSI to ISO, you'll need to update your firmware now. See the links in Step 0 above.
Touchpad (trackpad)
Documentation for the touchpad can be found in Datasheets for Components and Peripherals. It is the only component of the Pinebook Pro held in place with strong adhesive tape. Here are some of its features:
  • 2 actuating buttons.
  • multi-touch functionality.
  • A matte finish that your finger can slide along easily.
  • A reasonable size (96mm × 64mm; diagonal: 115.378mm or 4.542”).
Troubleshooting
If you are having trouble using 2 fingers to scroll or emulate the click of a mouse's right-button, then try these solutions:
  • Update the firmware.
  • Keep your 2 fingers spread apart rather than close together.
  • Individual programs might need to be configured specially.
  • For smooth scrolling and gestures under X-Windows, Firefox should be launched with with the following environment variable assignment:
MOZ_USE_XINPUT2=1
  • Experiment with other settings, via X-Windows Configuration or some other system preferences. For example, you could disable double-finger scrolling, and instead enable scrolling by sliding one finger along the edge of the touchpad.
Firmware
The touchpad controller is connected to the keyboard controller. All touchpad events go through the keyboard controller and it's software, then to the keyboard controller's USB port. Note that the touchpad does have separate firmware (which has to be written through the keyboard controller). The touchpad vendor's firmware binary can be flashed from userspace using the following open source command-line utility:
Naturally, forks have begun to appear:
  • Dragan Simic's fork. This one has recently delivered a much improved firmware from the vendor one, which greatly improves the control of the cursor (see this thread for discussion). Before installing this update, consider resetting to the defaults any configuration of your touchpad.
Every Pinebook Pro produced before September 2021 should have its keyboard and touchpad firmware updated.
Warning: DO NOT update the touchpad firmware before checking which keyboard IC your Pinebook Pro has. Some Pinebook Pro were delivered with a SH61F83 instead of a SH68F83. The SH61F83 can only be written 8 times, this will render the keyboard and touchpad unusable if this limit is reached when step 1 (see below) is flashed. See Reddit SH61F83 thread. The keyboard IC corresponds to U23 on the top layer silkscreen of the main board. It is located under the keyboard flat flexible cable.
Before updating any firmware, your Pinebook Pro should be either fully charged or, preferably, running from mains. This utility will be writing data to chips on the keyboard and touchpad, so a loss of power during any stage of the update can result in irrecoverable damage to your touchpad or keyboard.
The scripts ought to work on all operating systems available for the Pinebook Pro. Some operating systems may however, require installation of relevant dependencies. The instructions below assume a Debian desktop. To install these dependencies, newer Pinebook Pro models that come with Manjaro will require a different command.
There are two keyboard versions of the Pinebook Pro: ISO and ANSI. You need to know which model you have prior to running the updater. Firmware update steps for both models are listed below.
TODO Explain how one can know which keyboard model he has.
What you will need:
  • Connection to internet for getting dependencies, either through WIFI or wired ethernet (USB dongle).
  • Your Pinebook Pro fully charged or running from mains power.
  • An external USB keyboard and mouse (or access to the Pinebook Pro via SSH. Please note that for some configurations, the SSH service might not be available without first having logged in once. In this case, you will definitely want at least an external keyboard).
ISO Model
make
Step 1
sudo ./updater step-1 iso
sudo poweroff # do not use 'reboot'
Step 2 (after booting)
sudo ./updater step-2 iso
ANSI Model
Note: Running step 1 on the ANSI keyboard model will make the keyboard and touchpad inaccessible until step 2 is run, so an external keyboard must be connected to complete the update on this model!
make
Step 1
sudo ./updater step-1 ansi
sudo ./updater step-2 ansi
When done, if some of the keys produce incorrect characters, please check your OS’s language settings. For ANSI users, the default OS may have shipped with English UK as the default language. You can change it to English US if desired.
Revised Firmware
In addition, you might consider using revised firmware data. This is one final step that should not require a reboot:
Step 3: ISO (after booting)
sudo ./updater flash-kb firmware/default_iso.hex
Step 3: ANSI (after booting)
sudo ./updater flash-kb firmware/default_ansi.hex
Note: Before making adjustments, consider updating the firmware. Reset your adjustments before updating the firmware, so that your adjustments do not interfere with new functionality.
Some forum members have found that an adjustment to X-Windows will allow finer motion in the touchpad. If you use the Synaptic mouse/touchpad driver, use this command to make the change live:
synclient MinSpeed=0.2
You may experiment with different settings, but 0.25 was tested as helping noticeably.
To make the change persist across reboots, change the file /etc/X11/xorg.conf similar to below:
Section "InputClass"
       Driver "synaptics"
       MatchIsTouchpad "on"
       Option "MinSpeed" "0.25"
EndSection
The line "Option "MinSpeed" "0.25"" is changed here.
synclient MinSpeed=0.25
synclient TapButton1=1
synclient TapButton2=3
synclient TapButton3=2
synclient FingerLow=30
synclient PalmDetect=1
synclient VertScrollDelta=64
synclient HorizScrollDelta=64
FingerLow has the same value as 'FingerHigh' in one config (30). It is believed to help reduce mouse movement as you lift your finger, but it's unknown whether synaptic works like this. You may find this config to be comfortable for daily use.
TabButton allows to just tab the touchpad instead of physically pressing it down (to get this click noise).
The right mouse click is emulated by tapping with two fingers on the touchpad. If you feel that this is not very responsive you can try this value:
synclient MaxTapTime=250
Some users may encounter an issue with the mouse jumping when typing when using libinput driver (has not been test with synaptic) due to their hand hitting the touchpad which can be fixed by updating the X.Org settings to disable it while typing. One can disable the touchpad while typing by setting the below option in the X.Org config simliar to the previous example.
        Option "DisableWhileTyping" "on"
The setting can be verified by using the xinput command to first list the devices and then listing the properties for the touchpad device. Exact commands to check this have been omitted for save of brevity. If DisableWhileTyping is shown enabled but does not appear to be working the issue may be due to the fact that the keyboard is connected to a USB bus which causes it to be seen as a external keyboard. To resolve this one can add the config below which sets the keyboard to internal to ensure the DisableWhileTyping works properly.
You will need to edit /etc/libinput/local-overrides.quirks and add the following lines:
[Serial Keyboards]
MatchUdevType=keyboard
MatchBus=usb
AttrKeyboardIntegration=internal
Once X11 is restarted the new setting should now take effect and you will no longer be able to use the touchpad while typing which will mostly eliminate the mouse jumping issue.
Power Supply
  • Input Power: 5V DC @ 3A
  • USB-C 5V, 15W PD quickcharge
LEDs
In total, there are four LEDs on the Pinebook Pro, three of which are placed in the top-left side of the keyboard, and one near the barrel port:
  1. The red LED next to the barrel port indicates charging, in three ways. First, it will illuminate steadily when either the factory power supply or a USB Type-C charger is connected to the Pinebook Pro, and the battery is getting charged. Second, if the battery is at 100%, the LED will remain turned off regardless of the connected power input. However, this is rather rarely achieved. Third, this LED will flash at 0.5 Hz if there are any problems that prevent charging, such as the battery becoming too hot.
  2. The power indicator LED, above the keyboard, supports three different colors: green, amber and red. It is also capable of flashing to indicate eMMC activity. In the default Debian with MATE build, green LED means power and red means suspend (amber is unused).
  3. The green NumLock LED, above the keyboard.
  4. The green CapsLock LED, above the keyboard.
The NumLock and CapsLock LEDs serve their usual purposes on a keyboard, but they also have a secondary function. When the privacy switches get activated they blink to confirm that the switch has been activated.
Webcam
You can use Cheese to test the Camera functionality
  • Streaming video resolutions supported, (uncompressed):
    • 320 x 240
    • 640 x 480
    • 800 x 600
    • 1280 x 720
    • 1600 x 1200
    • 160 x 120
    • 176 x 144
    • 320 x 240
    • 352 x 288
    • 640 x 480
    • 800 x 600
    • 1280 x 720
    • 1600 x 1200
Microphones
While it has been said that some Pinebook Pro units contain only one microphone despite having two labeled microphone holes on the outer casing, other units do indeed contain two microphones. It is presently unclear which batches have either configuration. Units from the initial community batch of 1000 units (following the initial 100) are believed to contain two, populating both labeled holes.
Microphones not working?
If pavucontrol input doesn't show microphone activity try changing the privacy switches. If the switches are in the correct place and microphone input isn't working you can run alsamixer from the command line, hit F6 and select the es8316, hit F4 to get to the capture screen, select the bar labeled ADC, increase the gain to 0dB, change the audio profile in pavucontrol to another one with input. Additionally you may want to modify ADC PGA to get the levels to where you want them. If that still hasn't fixed it you may want to check that the microphone connector is plugged in (see the section Technical Reference).
Bluetooth and WiFi
Hardware Overview
The wireless module interfaces with the Pinebook Pro’s system-on-chip using a combination of three interfaces: Bluetooth functionality is operated by serial UART and PCM, while the Wi-Fi component uses SDIO. It is unknown if the module’s Bluetooth capabilities are usable under operating systems that do not support SDIO.
Issues
Wi-Fi Capabilities
Bluetooth Capabilities
Disabling Bluetooth
To disable Bluetooth under Linux once:
sudo rfkill block bluetooth
To confirm if Bluetooth under Linux is disabled:
rfkill
To disable Bluetooth on boot (note: for distributions such as Manjaro XFCE see the step below):
To disable Bluetooth on certain distributions, such as Manjaro XFCE, right click on the Bluetooth panel icon, select plugins, then PowerManager, then configuration and then deselect the auto power on option
LCD Panel
  • Model: BOE NV140FHM-N49
  • 14.0" (35.56 cm) diagonal size
  • 1920x1080 resolution
  • 60 Hz refresh rate
  • IPS technology
  • 1000:1 contrast
  • 250 nit brightness
  • 63% sRGB coverage
  • 6-bit color
  • 30-pin eDP connection
Some people have tested hardware video decode using the following:
External ports list
  • Left side
    • USB 3, Type A
    • USB 3, Type C
  • Right side
    • USB 2, Type A
    • Standard headset jack
    • MicroSD card slot
Using the UART
Pinout of the serial adapter. Swapping the tx and rx around from this also works and is more traditional. See the official Pine64 document.
With the UART switch in the ON position, console is relayed via the audiojack and the laptop's sound is turned OFF. Please ensure that you are using a 3.3 V interface (such as the CH340, FTDI-232R, or PL2303, which are sold in both 3.3 V and 5 V variants) to avoid damage to the CPU. Older version of the serial console cable sold by Pine64 uses wrong voltage level and should not be used, see this forum thread for further information. Recent version of the same cable uses the right voltage level.
Insert the USB plug of the cable into an open USB port on the machine which will monitor, ensuring that the audio jack of the serial cable is be fully inserted into the Pinebook Pro audio port. Run the following in a terminal:
$ lsusb
screen /dev/ttyUSB0 1500000
Old versions of U-Boot do not use the UART for console output. The console function is activated by the Linux kernel. Thus, if you use a non-Pinebook Pro Linux distribution and want the UART as a console, you have to manually enable it.
Once you have fitted and tested your NVMe drive, please add a note to this page Pinebook Pro Hardware Accessory Compatibility to help build a list of tried and tested devices.
Please see a separate section that describes reported issues with the NVMe drives in PineBook Pro.
Installing the adapter
The updated SSD adapter, labeled V2-2019-1107, takes into account the prior problems with touchpad interference. New orders as of Feb. 22nd, 2020 will be the updated adapter.
This is the link to the Pinebook Pro accessories in the store: [[1]]
Some NVMe SSDs allow reducing the maximum amount of power. Doing so may reduce the speed, but it may be needed in the Pinebook Pro to both improve reliability on battery: Some NVME may be stable with default settings when runnning on AC power but cause frequent kernel panics (system freeze with power LED blinking red/green) when running on battery. Reducing NVME power drain solves this in some cases. And reducing power used gives better battery life. Here are the commands to obtain and change the power settings. The package 'nvme-cli' is required to run these commands. The example shows how to find the available power states, and then sets it to the lowest, non-standby setting, (which is 3.8 watts for the device shown):
NVME Identify Controller:
Some NVMe SSDs don't appear to allow saving the setting with "-s" option. In those cases, leave off the "-s" and use a startup script to set the non-default power state at boot. If you want to test performance without saving the new power setting semi-permanantly, then leave off the "-s" option.
On systemd based distributions like Manjaro, a non-default power state for an NVME can be set using a systemd service. This is useful in cases where the NVME drive does not save the power state and/or uses APST. An example systemd service, nvme-throttle.service, is shown below:
[Unit]
Description=Throttles NVME to lesss power hungry mode
After=suspend.target hibernate.target hybrid-sleep.target suspend-then-hibernate.target
[Service]
Type=oneshot
ExecStart=/usr/bin/nvme set-feature /dev/nvme0 -f 2 -v 1
[Install]
WantedBy=multi-user.target suspend.target hibernate.target hybrid-sleep.target suspend-then-hibernate.target
Here the value after "-v" is the maximum power state that you want your SSD to use. This will be executed at system startup, and every time your system exits any suspend mode that might reset the SSD to default values.
This file needs to be placed in the /etc/systemd/system directory. Afterwards, to activate the service, run:
systemctl daemon-reload
systemctl enable --now nvme-throttle.service
There is another power saving feature for NVMes, APST, (Autonomous Power State Transitions). This performs the power saving & transitions based on usage. To check if you have a NVMe SSD with this feature:
Information for this feature, (on a Pinebook Pro), is a work in progress. It is enabled by default in latest Manjaro kernels and reported to work. On some NVME SSDS (WD), APST is compatible with limiting NVME maximum power: APST will work and not exceed maximum power state defined using previous method.
Using as data drive
Using as OS root drive
  • MicroSD
  • eMMC
  • NVMe
Please see Bootable Storage.
Caring for the PineBook Pro
Bypass Cables
Warning: Do not connect the bypass cables with the battery connected. Using the bypass cables with the battery connected can permanently damage the computer.
These are instruction guides for the disassembly:
Using the SPI flash device
See Pinebook Pro SPI for details.
  • You need the kernel built with SPI flash device support, which will supply a device similar to: /dev/mtd0
  • The Linux package below, will need to be available: mtd-utils
  • You can then use this program from the package to write the SPI device: flashcp <filename> /dev/mtd0
The procedures described above are a lot less risky than attaching an external SPI flasher and do not require any additional hardware. At present, April 19th, 2020, there is no good bootloader image to flash into the SPI flash device. This is expected to change, as there are people working on issue.
Software tuning guide
Customizing the Pinebook Pro's default Manjaro KDE system
Watching DRM content (Netflix, etc.)
Most paid online streaming services use Widevine DRM to make their content more difficult to pirate. Widevine is not directly supported on Manjaro KDE, however it is still possible to watch DRM content via the "chromium-docker" package which downloads a 32-bit ARM container and installs Chromium with Widevine inside of that. While not space-efficient, or efficient in general, it's the recommended solution for watching this content on your Pinebook Pro. You can install this package with:
sudo pacman -Sy chromium-docker
Checking GPU capabilities
To see what versions of OpenGL and OpenGL ES are supported by the Pinebook Pro, what driver is in use, and what version of the driver is loaded, install the "mesa-demos" package with:
sudo pacman -Sy mesa-demos
And then run:
glxinfo | grep OpenGL
This will give detailed information about your graphics card and driver, useful for debugging.
Better GPU compatibility and performance
For better graphics performance, you may install the "mesa-git" package, built and supplied in the Manjaro ARM repos. This lets you bring in the latest features, optimizations, and bugfixes for the graphics driver used by the Pinebook Pro. Installation is as simple as:
pacman -Sy mesa-git
Then you may reboot to load the newer driver.
With Mesa 20.2 there is no longer much reason to use this over the standard mesa package, and applications may occasionally break with mesa-git.
Reporting bugs to the Mesa project will help make sure any problems are quickly fixed.
OpenGL 3.3 support
By default, with the current state of the Panfrost GPU driver, the Pinebook Pro supports OpenGL 2.1 and OpenGL ES 3.0. If you want to use OpenGL 3.3, you need to set the system-wide environment variable, open the /etc/environment file with:
kate /etc/environment
And then at the bottom of the file, on a new line, add:
PAN_MESA_DEBUG="gl3"
Then save the file, entering your password when prompted, and reboot the system. When you check your GPU capabilities, it should report OpenGL 3.3 and applications that rely on it should function properly. Note that GL 3.3 support is incomplete and some rendering features do not work yet, notably geometry shaders.
Install Anbox on Pinebook Pro Manjaro 20.10
Youtube video on installing Anbox on Pienbook Pro Manjaro Build 20.10 by LivingLinux
Customizing the Pinebook Pro's previously-default Debian system
Here are some hints on what you can do to customize the Pinebook Pro's previous factory image (aka mrfixit2001 debian build)
# passwd (and follow prompts)
  • Rename the rock user to your prefered username (replace username with whatever you like):
# usermod -l username -d /home/username -m rock
# groupmod -n username rock
# chfn -f "John A Doe" username
# passwd username
# logout
  • Open text terminal to fix login error: "Configured directory for incoming files does not exist":
$ blueman-services
Select "Transfer" tab and set "Incoming Folder" to yourself or if adduser is in the distributions, create an user with sudo adduser $USER (fill out variables as required), then add the user to the groups using sudo adduser $USER $GROUP by adding one group at a time.
Changing the default hostname
Debian 9 has a command to allow you to change the hostname. You can see the current settings using:
$ sudo hostnamectl
         Icon name: computer
            Kernel: Linux 4.4.210
      Architecture: arm64
To change, use this, (with hostname used as the example):
$ sudo hostnamectl set-hostname hostname
Then you should backup and edit your /etc/hosts entry's name:
$ sudo cp -p /etc/hosts /etc/hosts.`date +%Y%m%d`
$ sudo vi /etc/hosts
127.0.0.1	localhost
127.0.0.1	hostname
fe00::0		ip6-localnet
ff00::0		ip6-mcastprefix
ff02::1		ip6-allnodes
ff02::2		ip6-allrouters
127.0.1.1       linaro-alip
Perform the following steps:
Watching Amazon Prime videos with Chromium
When you create a new user, it will be necessary to launch the Chromium browswer with a specific user agent like below:
chromium-browser --user-agent="Mozilla/5.0 (X11; CrOS armv7l 6946.63.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.121 Safari/537.36"
There may be more tweaks needed.
By default, most Linux distributions have a boot screen with a picture. To see all the boot time messages, use one of the following:
Debian
vi /etc/default/u-boot
u-boot-update
Manjaro
cp -p /boot/extlinux/extlinux.conf /boot/extlinux/extlinux.conf.`date +%Y%m%d`
chmod a-w /boot/extlinux/extlinux.conf.`date +%Y%m%d`
vi /boot/extlinux/extlinux.conf
  • Change console=ttyS2,1500000 to console=tty1
  • Remove the bootsplash.bootfile option and it's parameter.
  • You can add verbose logging by appending ignore_loglevel to the line where boot splash was.
  • Leave everything else alone.
Retro Gaming on the Pinebook Pro
A retro-gaming OS named R-Cade has been made available for the Pinebook Pro, provided by The Retro Center.
R-Cade includes over 100 retro-gaming systems, a lightweight web browser, and includes the latest release of KODI to provide full 4K UHD media playback and streaming. Streaming options in KODI are provided by various addons, such as Netflix, Disney+, and Amazon Prime. More information can be found here.
Releases can be downloaded from their GitHub.
Improving readability
Some people find that a 14" LCD screen with 1080p, (1920 x 1080), has text and icons a bit too small. There are things you can do to make the screen easier to use and read.
  • Increase the font size
  • Use a font with more pronounced features
  • Increase the various window manager sizes (e.g. increase the height of the tool bar)
  • Change the color scheme to be easier on the eyes. Higher contrast can help usability.
  • Change the window manager's decorations (e.g. use larger icons)
  • Use a workspace manager, with one application per workspace
  • When at home or office, use an external monitor
  • Change the X-Windows DPI. One such method that someone used successfully, is: echo "Xft.dpi: 150" >> ~/.Xresources Change the 150 as desired to get the size adjustment you want.
However, do not change the resolution of the LCD screen, otherwise you may end up with a blank / black screen. If that happens, see this troubleshooting section for the fix: Blank screen after changing builtin LCD resolution
Chromium tweaks
Flags
--disable-low-res-tiling \
--num-raster-threads=6 \
--profiler-timing=0 \
--test-type \
--ignore-gpu-blacklist \
--use-gl=egl \
--enable-pinch \
--flag-switches-begin \
--enable-gpu-rasterization \
--enable-oop-rasterization \
--flag-switches-end
Note that in some cases, this may also decrease performance substantially, as observed when using these flags on the Manjaro KDE desktop. Feel free to experiment to find what is smoothest for you personally.
gVim has performance issue
It appears that using GTK3 can cause very slow scrolling, while Vim in a terminal window works fine. Simply revert back to using GTK2, (how to do so is somewhat Linux distro-specific).
Another solution may be to run gVim with
GDK_RENDERING=image
environment variable set. It seems that this improves the performance by reverting back to software-only rendering.
Kernel options
To see if a specific feature is enabled in the current kernel, you can use something like this:
CONFIG_PHY_ROCKCHIP_PCIE=m
If it's listed as =m, then it's a module. You can see if the module is loaded with:
Hardware video decoding
Older systems, such as the previously-default Debian desktop, use the Rockchip-supplied kernel module rk-vcodec. To check, something like this can be used:
$ lsmod | grep rk-vcodec
or
CONFIG_RK_VCODEC=y
Newer systems may use a different option as in the configuration below:
CONFIG_VIDEO_HANTRO=m
Troubleshooting guide
Do not panic if something goes wrong or in an unexpected way. Instead, stop and consider carefully how to undo something, or how to redo it. This particularly applies when flashing a new operating system, or flashing new firmware to the keyboard or touchpad. If everything fails, consider reporting the issue on the forums, with as many relevant details as available.
Please, have a look at the Pinebook Pro Troubleshooting Guide, which details a number of issues you may encounter.
Hardware/Accessory Compatibility
Please contribute to the hardware/accessory compatibility page, which lists the status of hardware tested with the Pinebook Pro. Available hardware categories include the following:
Technical Reference
Disassembly and Reassembly
Hinge area of the Pinebook Pro lid with the cover removed
Close-up of a Pinebook Pro lid hinge
There are a few mandatory precautions to be taken:
  • Do not open the laptop by lifting the lid while the Pinebook Pro bottom cover is removed - this can cause structural damage to the hinges and/or other plastic components of the chassis such as the IO port cut-outs.
  • When removing the back cover plate, *do not, under any circumstances, slide your fingertips between the metal shell and the plastic frame!* The back cover plate edges are sharp, and when combined with the pressure and movement generated from, specifically, attempting to slide the tips of your fingers along the bottom edge of the plate along the lid-hinge, they *will* slice open the tips of your fingers like a knife.
  • When removing the back cover plate, use care to avoid damaging the speakers. They can be stuck to the back cover with double-sided tape, and the thin wires are very delicate. Newer Pinebook Pro laptops (as of the May 2021 batch, and perhaps earlier) seem to lack the double-sided tape to the rear cover, instead opting for tape or glue that makes them stick to the front cover. Nevertheless, be gentle when removing the back cover.
Pinebook Pro external screws (this particular unit has suffered damage on screw (4)L)
When disassembling the laptop make sure that it is powered off and folded closed. To remove the bottom cover of the Pinebook Pro, first remove the ten (10) Phillips head screws that hold the bottom section of the laptop in place. There are four (4) short screws along the front edge, and six (6) long screws along the 3 remaining sides. Remove the cover from the back where the hinges are situated by lifting it up and away from the rest of the chassis. The aluminum case is held on only by screws. There are no plastic snaps, and the shell should pull away without any effort. If you experience any resistance at all stop and ensure all ten (10) screws are accounted for.
During reassembly, make sure that the back-screw standoffs are in place and seated correctly. Before replacing the aluminum back-plate, ensure that the speakers are properly seated by pressing gently on the hard plastic edge of the speaker module. Slide the bottom section into place so it meets the front lip of the keyboard section. Secure the front section (where the touchpad is located) in place using the short screws in the front left and right corners. Then proceed to pop in the bottom panel into place. Secure the bottom section (where hinges are located) by screwing in the left and right corners. Then screw in the remaining screws and run your finger though the rim on the chassis to make sure its fitted correctly. Note that the front uses the remaining 4 short screws.
The screws are small and should only be finger tight. Too much force will strip the threads. If after installing screws the back cover plate has not seated properly on one side (which may be caused by the aforementioned misseating of the speakers), open the display and hold the base on either side of the keyboard and gently flex the base with both hands in opposing directions. Once the side pops further in, then recheck the screws on that side. If it does not pop back in, re-open the machine and check for misseated components.
A basic 3D model to print replacement standoffs for the back cover screws is available on Thingiverse, until the official drawings or 3D models are made available.
Display Disassembly
It is not recommended to adjust the position of the lid when the bottom cover is removed, because the bottom cover provides structural strength, so the lid should be open fully as the first step, before starting any disassembly of the laptop. After opening the lid, remove the bottom cover by following the instruction found in the section above. Alternatively, you can keep the lid closed and remove the screws that hold the hinges to the main laptop body, as described in Pinebook Service Step by Step Guides.
Parts of the hinge mechanism, as well as the screws that hold the hinges to the lid, are hidden behind an elongated plactic U-shaped cover that snaps in place using latches. Use a dedicated plastic prying tool or a guitar pick to gently pry the cover and remove it, starting from the outer edge. Once you pry the cover to a certain extent, it should be possible to remove it fully using only your hands. The U-shaped cover is rather sturdy, but still be careful not to break or bend it.
There are two small screws hidden underneath the two small rubber nubs on the upper part of the screen bezel, so first gently remove the nubs and then remove the screws. The screen bezel is held in place with a combination of latches and some adhesive tape, which is there to prevent dust ingress. The adhesive isn't very strong, and the bezel is capable of flexing back into shape after being twisted to a certain extent. There is more adhesive on the bottom part of the screen bezel, so be more careful while prying that section apart. Use the same prying tool that you used for the U-shaped cover, and work it around the outer edges of the screen bezel.
Internal Layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
The Reset and Recovery buttons (28): the reset button performs an immediate reset of the laptop. The Recovery button is used to place the device in maskrom mode. This mode allows flashing eMMC using Rockchip tools (e.g. rkflashtools).
Key Internal Parts
Number Type Descriptor
2 Socket PCIe x4 slot for optional NVMe adapter
3 Socket Speakers socket
4 Socket Touchpad socket
5 Component Left speaker
6 Connector Power bridge connector
7 Socket Keyboard Socket
10 Socket Power bridge socket
11 Socket Battery socket
12 Component Touchpad
13 Component Battery
14 Component Right speaker
15 Socket MicroSD card slot
17 Socket USB 2.0 Type A
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0 Type A
33 Socket USB 3.0 Type C
Smallboard detailed picture
Bootable Storage
The PineBook Pro eMMC module and switch, shown in 'enabled' position
Boot sequence details
The RK3399's mask 32KB ROM boot code looks for the next stage of code at byte off-set 32768, (sector 64 if using 512 byte sectors). This is where U-Boot code would reside on any media that is bootable, RK3399 boot sequence
Boot devices
At this time, the Pinebook Pro ships with a Manjaro + KDE build with u-boot on the eMMC. Its boot order is: SD, USB, then eMMC.
(An update has been pushed for the older Debian + MATE build that improves compatibility with booting other operating systems from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
eMMC information
The eMMC appears to be hot-pluggable. This can be useful if trying to recover data or a broken install. Best practice is probably to turn the eMMC switch to off position before changing modules. Note that the enable/disable label on the silkscreen is incorrect on some board revisions (known bad on v2.1).
If the eMMC module is enabled after boot from an SD card, you can detect this change with the following commands as user "root":
echo fe330000.mmc >/sys/bus/platform/drivers/sdhci-arasan/unbind
echo fe330000.mmc >/sys/bus/platform/drivers/sdhci-arasan/bind
(Note: with the device trees coming with older kernels (Linux < 5.11), the device name may be fe330000.sdhci instead of fe330000.mmc)
Case Dimensions and Data
  • Weight: 1.26Kg
  • Screws
    • Philips head type screws
    • M2 flat head machine screws (measurements in mm)
    • 4 x Small screws (used along the front edge): Head - 3.44, Thread Diameter - 1.97, Thread Length - 2.1, Overall length - 3.05
    • 6 x Large screws: Head - 3.44, Thread Diameter - 1.97, Thread Length - 4.41, Overall Length - 5.85
  • Rubber Feet
    • 18mm diameter
    • 3mm height
    • Dome shaped
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
    • Cortex-M0 CPU
    • Architecture: Armv6-M
    • 32 bit only
GPU Architecture
  • Frequency 650MHz
    • OpenCL™ 1.1, 1.2
    • DirectX® 11 FL11_1
    • RenderScript™
  • RAM Memory:
    • LPDDR4
    • 800MHz, (limited by RK3399)
  • Storage Memory:
    • Bootable
  • SPI flash:
    • Pinebook Pro SPI
    • 128Mbit / 16MByte
    • 1 bit interface
Video out
  • USB-C Alt mode DP
Expansion Ports
  • MicroSD card:
    • Bootable
  • USB ports:
Additional hardware
Battery
Display
Lid closed magnet
There is a magnet to detect when the laptop lid is closed, so action can be taken like sleep. This meets up with the Hall sensor on the daughter / small board to detect lid closed.
  • The magnet is located on the LCD panel right side, around 1.5 inches up measure from bottom edge.
Webcam
Audio
  • Built-in microphone
  • Built-in stereo speakers:
    • Oval in design
    • 3 mm high x 20 mm x 30 mm
Network
  • WiFi:
    • 802.11 b/g/n/ac
    • Dual band: 2.4Ghz & 5Ghz
    • Single antenna
  • Bluetooth 5.0
Optional NVMe adapter
  • PCIe 1.1, 2.5 GT/s per lane
    • Note that due to errata, PCIe is limited to Gen1. See this commit.
  • Four PCIe lanes, which can not be bifurcated, but can be used with one- or two-lane NVMe cards
  • Power: 2.5 W continuous, 8.25 W peak momentary
Rockchip RK3399 SoC information:
LPDDR4 SDRAM (366-pin BGA):
eMMC information:
SPI NOR Flash information:
Wireless and Bluetooth information:
Audio codec:
LCD panel:
USB-related information:
Touchpad information:
Keyboard information:
Full HD camera sensor:
Battery-related information:
Power path device:
NVMe adapter:
Versions
Template files for creating custom skins. Each includes template layers for art placement, and CUT lines:
Other Resources
