Pinebook
Revision as of 22:13, 28 October 2020 by Fxc (talk | contribs) (https)
Pinebook
Under 'Pinebook Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software. The list includes OS images and descriptions of:
Xenial Mate (eMMC) / Xenial Mate (microSD Boot)
Android 7.x (microSD Boot) / Android 6.x (eMMC)
KDE Neon (microSD Boot)
Bliss OS (microSD Boot)
Xenial Minimal Image (microSD Boot)
Armbian (microSD Boot)
Arch Linux mainline XFCE (microSD Boot)
Q4OS (microSD Boot)
i3 (microSD Boot)
Netrunner (microSD Boot)
AOSC (microSD and eMMC boot)
DietPi(microSD Boot)
Manjaro (microSD Boot)
RISC OS (microSD Boot)
Under 'Service Guides for Pinebook' you can instructions guides concerning disassembly of:
  • 11.6″ Pinebook Lithium Battery Pack Removal Guide
  • 11.6″ Pinebook LCD Panel Screen Removal Guide
  • 11.6″ Pinebook eMMC Module Removal Guide
Pinebook Information
  • Dimensions: 329mm x 220mm x 12mm (WxDxH - 14" Pinebook)
  • Weight: 1.26Kg (14" Pinebook)
  • Input Power: DC 5V @ 3A
SoC and Memory Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • System RAM Memory: 2GB
  • Storage Memory: 16GB eMMC module, can be upgrade to 32GB or 64GB eMMC module
Battery
  • Lithium Polymer Battery (10,000mAH)
Video
  • Mini Digital Video Port (Type A - mini)
Audio
Network
  • WiFi 802.11 b/g/n with Bluetooth 4.0
  • 10/100Mbps USB Ethernet Dongle (Optional)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • mini Digital Video port
  • microSD card port - support SD, SDHC, SDXC uo to 256GB
  • 2x USB 2.0 port
  • earphone plug with UART console mux circuit
Pinebook Schematics and Certifications
Other Resources
