Pinebook
Revision as of 14:06, 17 December 2019 by Wizzard (Talk | contribs) (SoC and Memory Specification)
Jump to: navigation, search
Pinebook
Under 'Pinebook Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software. The list includes OS images and descriptions of:
mate.png Xenial Mate (eMMC)           mate.png Xenial Mate (microSD Boot)
android_7.png Android 7.x (microSD Boot)           android_6.png Android 6.x (eMMC)
kde.png KDE Neon (microSD Boot)
bliss_os.png Bliss OS (microSD Boot)
penguin.png Xenial Minimal Image (microSD Boot)
armbian.png Armbian (microSD Boot)
archlinux.png Arch Linux mainline XFCE (microSD Boot)
q4os.pngQ4OS (microSD Boot)
i3.pngi3 (microSD Boot)
netrunner.png Netrunner (microSD Boot)
aosc.pngAOSC (microSD and eMMC boot)
dietpi.png DietPi(microSD Boot)
manjaro.png Manjaro (microSD Boot)
RISC_os.png RISC OS (microSD Boot)
Under 'Service Guides for Pinebook' you can instructions guides concerning disassembly of:
  • 11.6″ Pinebook Lithium Battery Pack Removal Guide
  • 11.6″ Pinebook LCD Panel Screen Removal Guide
  • 11.6″ Pinebook eMMC Module Removal Guide
Pinebook Information
  • Dimensions: 329mm x 220mm x 12mm (WxDxH - 14" Pinebook)
  • Weight: 1.26Kg (14" Pinebook)
  • Input Power: DC 5V @ 3A
  • Based on Allwinner A64
  • Quad-core ARM Cortex-A53 [email protected]
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • System RAM Memory: 2GB
  • Storage Memory: 16GB eMMC module, can be upgrade to 32GB or 64GB eMMC module
Battery
  • Lithium Polymer Battery (10,000mAH)
Video
  • Mini Digital Video Port (Type A - mini)
Audio
Network
  • WiFi 802.11 b/g/n with Bluetooth 4.0
  • 10/100Mbps USB Ethernet Dongle (Optional)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • mini Digital Video port
  • microSD card port - support SD, SDHC, SDXC uo to 256GB
  • 2x USB 2.0 port
  • earphone plug with UART console mux circuit
Pinebook Schematics and Certifications
Other Resources
