Pinebook
The Pinebook
The Pinebook is an 11.6″ or 11.6″ with 1080P IPS panel or 14″ notebook powered by the same quad-core ARM Cortex A53 64-Bit Processor used in our popular PINE A64 Single Board Computer. It is very lightweight, hackable and comes equipped with a full-sized keyboard and large multi-touch trackpad. It runs numerous mainline Linux distributions as well as *BSD and Android.
Software releases
Under Pinebook Software Releases you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
Variants
The following variants exist of the Pinebook:
  • Pinebook 11.6″
  • Pinebook 11.6″ 1080p
  • Pinebook 14″
More information can be found on the sunxi wiki.
These are instruction guides for the disassembly:
11.6″ Pinebook:
14″ Pinebook:
Pinebook Information
  • Dimensions: 299mm x 200mm x 12mm (WxDxH - 11″ Pinebook); 329mm x 220mm x 12mm (WxDxH - 14″ Pinebook)
  • Weight: 1.04Kg (11″ Pinebook); 1.26Kg (14″ Pinebook)#
  • Input Power: DC 5V @ 3A
SoC and Memory Specification
  • Based on Allwinner A64
CPU Architecture:
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture:
System Memory:
  • System RAM Memory: 2GB
  • Storage Memory: 16GB eMMC module, can be upgrade to 32GB or 64GB eMMC module
Battery:
  • Lithium Polymer Battery (10,000mAH)
Video:
  • Mini Digital Video Port (Type A - mini)
Audio:
Network:
  • WiFi 802.11 b/g/n with Bluetooth 4.0
  • 10/100Mbps USB Ethernet Dongle (Optional)
Storage:
  • USB - 2 USB2.0 Host port
Expansion Ports:
  • mini Digital Video port
  • microSD card port - support SD, SDHC, SDXC uo to 256GB
  • 2x USB 2.0 port
  • earphone plug with UART console mux circuit
Pinebook Schematics and Certifications
Mainboard schematics:
Daughter Board schematics:
Serial Console Earphone Jack pinout:
Certifications:
Allwinner A64 SoC:
X-Powers AXP803 PMU (Power Management Unit):
LPDDR3:
eMMC:
SPI NOR flash:
WiFi/BT module:
LCD Panel:
Touchpad:
Camera sensor:
Lithium battery:
Other Resources
FAQ / Tips and tricks
Prolong battery life
How to reduce the max voltage the battery is charged to?
$ cd /sys/class/power_supply/axp20x-battery
Notice that voltage_max_design is writable by root, values are in microvolts. The factory value is 4200000 or 4.2V on my device. This charges to 100% capacity.
$ cat voltage_max_design
4200000
Check the factory value on your device, and record it if different. It depends on the battery installed. You can reduce to 4.1V as superuser:
$ sudo echo 4100000 >voltage_max_design
If you are fully charged and on AC, the battery will start discharging until it reaches 4.1V. This will be about 98% capacity on my device. This prolongs the battery life when you don't need the extra few minutes of offline power. The driver will not let you set the max voltage less than 4.1V as of kernel-6.3.8
The setting seems to be retained across reboots.
Key left of Z ( \ | )
How to map the key next to Z to the symbols on \ and | (rather than <>) ?
Choose the alternative international US keyboard layout and variant. The name will depend on your desktop environment:
  • English (US, alt. intl.)
  • English (US, international AltGr Unicode combining, alternative)
  • English (US, alternative international)
Note: keyboard variants with similar names as the ones above change the upper left key for ` and ~. You have to press that key twice to get the desired char. This happens with the alt-intl variant. Choose the altgr-intl variant (or however it is called in your desktop environment) and it should work as expected.
To set the keyboard layout and variant in the terminal for X-Windows use:
setxkbmap -layout us -variant altgr-intl
The Archlinux Wiki has some good help if you need to tweak your layout further [1]
Key between Fn and Alt (Menu)
How to map the key between Fn and Alt to SUPER / META ?
The initial setup in many desktop environments maps the key between Fn and Alt to MENU. Although the menu key can be useful as well (e.g. spell correction in the browser) many desktop environments and window manager use the Super key for many other useful functions. And users are probably more used to have the META key near Ctrl and Alt.
In X-windows the following command maps the key between Fn and Alt to META and the Caps-Lock key to MENU.
setxkbmap -option caps:menu,altwin:alt_super_win
Set display brightness in the terminal
To set the display brightness in the terminal use xbacklight (if available in your distro):
xbacklight -setXX
XX is the percentage (%) of brightness. E.g. for 70% brightness
xbacklight -set70
If you use LXQt you can also use:
pkexec lxqt-backlight_backend --inc
pkexec lxqt-backlight_backend --dec
For an alternative solution please see the scripts discussed in this thread: [2]
Get battery % in CLI
As ACPI is not compatible with ARM, to gather the % battery this can be used:
cat /sys/class/power_supply/battery/capacity
Firefox font size
How to get a useful font size with firefox ?
To have every web page displayed in a larger more readable font size type about:config in the search bar and confirm on the first page that you want to make changes. Then search for this parameter:
layout.css.devPixelsPerPx
and modify the value (right click) to something between 1.2 to 1.5 depending on your preferences.
In addition to that you can set in Preferences -> General -> Fonts & Color -> Advanced Minimum font size to 16
Disable wireless power management
If having issues with wifi connectivity, try to disable power management in the 8723cs module options, adding rtw_power_mgnt=0 in /etc/modprobe.d/8723cs.conf
options 8723cs rtw_initmac=00:ba:ch:16:85:46 rtw_power_mgnt=0
Touchpad acceleration and scroll direction.
To set touchpad parameters from the cli you can use the command xinput. To use it correctly you first need to determine the device id / name for your touchpad. Use
xinput list
to do so. You are looking for a line like this:
HAILUCK CO.,LTD USB KEYBOARD Mouse      	id=7	[slave  pointer  (2)]
With the device id = 7 found you can list the parameters that can be set with xinput.
xinput list-props 7
The result looks similar to this:
device 'HAILUCK CO.,LTD USB KEYBOARD Mouse':
libinput Natural Scrolling Enabled (256):	0
libinput Accel Speed (265):	0.000000
To change the parameter use xinput set-prop
To set reverse scrolling for the touchpad use this command
xinput set-prop 7 'libinput Natural Scrolling Enabled' 1
To set mouse speed
xinput set-prop 7 'libinput Accel Speed' 0.95
Check different numbers for 0.95 to meet your needs.
For more details on xinput and mouse speed also see the Archlinux Wiki [3]
