Pinebook
Revision as of 03:00, 14 October 2017 by Tllim (talk | contribs) (→Software and OS Image Downloads)
Software and OS Image Downloads (still under construction)
Under 'Service Guides for Pinebook' you can find removal instructions guides pertaining to:
- 14″ Pinebook Lithium Battery Pack Removal Guide
- 14″ Pinebook LCD Panel Screen Removal Guide
- 14″ Pinebook eMMC Module Removal Guide
- 11.6″ Pinebook Lithium Battery Pack Removal Guide
- 11.6″ Pinebook LCD Panel Screen Removal Guide
- 11.6″ Pinebook eMMC Module Removal Guide
Pinebook Information
- Dimensions: 329mm x 220mm x 12mm (WxDxH - 14" Pinebook)
- Weight: 1.26Kg (14" Pinebook)
- Input Power: DC 5V @ 3A
SoC and Memory Specification
- Based on Allwinner A64
- Quad-core ARM Cortex-A53 Processor@1152Mhz
- A power-efficient ARM v8 architecture
- 64 and 32bit execution states for scalable high performance
- Support NEON Advanced SIMD (Single Instruction Multiple Data) instruction for acceleration of media and signal processing function
- Support Large Physical Address Extensions(LPAE)
- VFPv4 Floating Point Unit
- 32KB L1 Instruction cache and 32KB L1 Data cache
- 512KB L2 cache
GPU Architecture
- ARM Mali400MP2 Dual-core GPU
- Support OpenGL ES 2.0 and OpenVG 1.1 standard
- System RAM Memory: 2GB.
- Storage Memory: 16GB eMMC module, can be upgrade to 32GB or 64GB eMMC module.
Battery
- Lithium Polymer Battery (10,000mAH)
Video
- HDMI 1.4a (Type A - mini)
Audio
- 3.5mm stereo earphone/microphone plug
Network
- WiFi 802.11 b/g/n with Bluetooth 4.0
- 10/100Mbps USB Ethernet Dongle (Optional)
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 2 USB2.0 Host port
Expansion Ports
- mini HDMI port
- microSD card port - support SD, SDHC, SDXC uo to 256GB
- 2x USB 2.0 port
- earphone plug with UART console mux circuit
Pinebook Schematics and Certification
- Pinebook A64 Main Board Schematic:
- Pinkbook Daughter Board Schematic:
- Pinkbook Serial Console Earphone Jack Pinout:
- PINE A64 Certification:
- Allwinner A64 SoC information:
- X-Powers AXP803 PMU (Power Management Unit) information:
- AXP803 PMIC Datasheet
- Wifi/BT module information:
- LCD Panel:
- Touchpad information:
- Camera sensor:
- Lithium Battery information:
