Pinebook
Revision as of 02:33, 14 October 2017 by Tllim (talk | contribs)
Under 'Service Guides for Pinebook' you can find removal instructions guides pertaining to:
  • 11.6″ Pinebook Lithium Battery Pack Removal Guide
  • 11.6″ Pinebook LCD Panel Screen Removal Guide
  • 11.6″ Pinebook eMMC Module Removal Guide
Pinebook Information
  • Dimensions: 329mm x 220mm x 12mm (WxDxH - 14" Pinebook)
  • Weight: 1.26Kg (14" Pinebook)
  • Input Power: DC 5V @ 3A
SoC and Memory Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • System RAM Memory: 2GB.
  • Storage Memory: 16GB eMMC module, can be upgrade to 32GB or 64GB eMMC module.
Battery
  • Lithium Polymer Battery (10,000mAH)
Video
  • HDMI 1.4a (Type A - mini)
Audio
Network
  • WiFi 802.11 b/g/n with Bluetooth 4.0
  • 10/100Mbps USB Ethernet Dongle (Optional)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • mini HDMI port
  • microSD card port - support SD, SDHC, SDXC uo to 256GB
  • 2x USB 2.0 port
  • earphone plug with UART console mux circuit
Pinebook Schematics and Certification
  • PINE A64 Main Board Schematic:
Other Resources
