Pinebook
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides pertaining to:
- Enclosures
- Bluetooth and WiFi module
- Real Time Clock (RTC) battery
- Real Time Clock (RTC) battery holder
- First and third party cases
- Featured 3D printed cases (and more).
SoC and Memory Specification
- Based on Allwinner A64
- Quad-core ARM Cortex-A53 Processor@1152Mhz
- A power-efficient ARM v8 architecture
- 64 and 32bit execution states for scalable high performance
- Support NEON Advanced SIMD (Single Instruction Multiple Data) instruction for acceleration of media and signal processing function
- Support Large Physical Address Extensions(LPAE)
- VFPv4 Floating Point Unit
- 32KB L1 Instruction cache and 32KB L1 Data cache
- 512KB L2 cache
GPU Architecture
- ARM Mali400MP2 Dual-core GPU
- Support OpenGL ES 2.0 and OpenVG 1.1 standard
- System RAM Memory: 2GB.
- Storage Memory: 16GB eMMC module, can be upgrade to 32GB or 64GB eMMC module.
Board Features
Video
- HDMI 1.4a (Type A - full)
Audio
- 3.5mm stereo earphone/microphone plug
Network
- 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
- WiFi 802.11 b/g/n with Bluetooth 4.0 (optional)
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 2 USB2.0 Host port
Expansion Ports
- DSI - Display Serial Interface, 4 lanes MiPi, up to 1080P
- CSI - CMOS Camera Interface up to 5 mega pixel
- TP - Touch Panel Port, SPI with interrupt
- RTC - Real Time Clock Battery Connector
- VBAT - Lithium Battery Connector with temperature sensor input
- Wifi/BT Module Header - SDIO 3.0 and UART
- 2x20 pins "Pi2" GPIO Header
- 2x17 pins "Euler" GPIO Header
- 2x5 pins "EXP" Console Header
Pine A64 Board Information and Schematics
- Board Dimensions: 133mm x 80mm x 19mm
- Input Power: DC 5V @ 2A, 3.7V Li-Ion battery connector, microUSB connector, Euler connector
- Power Consumption: 2.5W
- PINE A64 Connector Layout @courtesy of norm24
- PINE A64 Heat Sink Location @courtesy of norm24
- PINE A64 Connector List
- PINE A64 Pi-2/Eular/Ext Bus/Wifi Bus Connector Pin Assignment (Updated 15/Feb/2016)
- PINE A64 PCB dimension
- Board Model Comparison
- PINE A64 Board Schematic:
- PINE A64 Certification:
- Allwinner A64 SoC information:
- X-Powers AXP803 PMU (Power Management Unit) information:
- AXP803 PMIC Datasheet
- Ethernet PHY information:
- Wifi/BT module information:
- LCD Panel:
- Touchpad information:
- Camera sensor:
- Lithium Battery information:
Other Resources
- Linux Sunxi Wiki page on PINE A64
- Collection of scripts to set up a minimal Xenial 14.04.3 / Debian 8 Jessie root filesystem Contributed By Uli Middelberg
- Linux Image created by Andre Przywara
- PINE A64 with HypriotOS by Dieter and Govinda
- H2testw 1.4 – Gold Standard In Detecting USB Counterfeit Drives
- F3 - an alternative to h2testw
- Benchmarking The Low-Cost PINE 64+ ARM Single Board Computer by Michael Larabel
- PINE64 Linux build scripts, tools and instructions by Longsleep
- PINE64 Linux image by Longsleep
- A series of Youtube video on PINE A64 Developers Board by Michael Larson
- PINE64 Quick Start Guide (with Gotchas)
- Shrinking images on Linux by FrozenCow
