Pine A64 openHAB Release
Revision as of 20:26, 17 October 2020 by Abcde (talk | contribs) (added categories)
openHAB Open Source Home Automation Image Release
openHAB 2.0 Image 20170129 based on Ubuntu Linux Base image by Longsleep
  • This image is a headless Ubuntu with pre-installed openHAB 2.0 final.
  • Suitable for 512MB/1GB/2GB Pine A64(+) Board
  • You can flash this in linux using all the regular methods or you can use Win32 Disk Image software or something similar.
  • Login with
    • username: openhab
    • password: changeit
  • Execute sudo /usr/local/sbin/resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
  • Includes Zulu Embedded JDK 1.8.0 Update 112
  • openHAB is installed via apt
  • openHAB is started as a system service, you can use systemctl for it:
    • sudo systemctl status openhab2.service
    • sudo systemctl stop openhab2.service
    • sudo systemctl start openhab2.service
  • Initial boot can take a few minutes before http://openhab:8080 becomes available.
  • The ZWave board is preconfigured as a Thing in openHAB - all that needs to be done is to install the Z-Wave binding
  • For getting started with openHAB, please refer to http://docs.openhab.org/
  • DD images:
