PINE A64 Software Releases
Revision as of 21:57, 28 December 2020 by Tllim (talk | contribs)
Note that, PINE A64(+) OS images are not compatible with PINE A64-LTS due to LPDDR3 memory configuration. For PINE A64-LTS, please use the 'SOPINE OS images'
Linux Image Releases
Special thanks to Sunxi community and longsleep for their contributions
Armbian
Armbian Debiab Buster for XFCE Desktop Usage
Armbian Ubuntu Bionic for XFCE Desktop Usage
Armbian Debian Buster for Server and Light Desktop Usage
Armbian Ubuntu Bionic for Server and Light Desktop Usage
Armbian Ubuntu Focal for Desktop Usage
AOSC
  • To learn more about AOSC, please visit the official AOSC website
  • AOSC using LZ4 compression algorithm, please visit the LZ4 github site for utility
  • 8GB microSD card and above
  • Login with
    • username: aosc
    • password: anthon
AOSC MATE Community Build Image [microSD Boot]
AOSC XFCE Community Build Image [microSD Boot]
AOSC LXDE Community Build Image [microSD Boot]
Fedora Base Image
Fedora 32 Minimal Build Image [microSD Boot]
  • Suitable for 1GB/2GB PINE A64+ Board, not advise to run on 512MB PINE A64 Board
  • Fedora 32 with kernel from Armbian 5.7.15 (minimum build)
  • Login with
    • username: root
    • password: fedora
Fedora 32 Server Build Image [microSD Boot]
  • Fedora 32 with kernel from Armbian 5.7.15 (server build)
  • Login with
    • username: root
    • password: fedora
Fedora 27 and 28 Image
Please follow this PINE64 forum post for Fedora 27 bring up and update to Fedora 28 on this thread
openSUSE
oepnSusu Tumbleweed Community Build Image [microSD Boot]
Please follow this https://en.opensuse.org/HCL:Pine64 openSUSE wki site] or bring up, upate and discussion
OpenWRT
OpenWRT Community Build Image [microSD Boot]
Volumio 2 Digital Audio Player
Volumio 2 Digital Audio Player [2.863-2020-12-23]
  • This version works with (Spdif / Coaxial / RCA).
  • You need to enable Volume Normalization in the Playback Options to fix sound low.
  • supports booting from eMMC and SD card.
  • supports a select number of simple I2S DACS. tested with the Pine64 DAC POT, a wired ES9023 DAC module and a pcm5121 DAC module.
  • Login with
    • Username: volumio
    • Password: volumio
FreedomBox
https://files.pine64.org/sw/pine64_installer/json/FreedomBox.jpg
Stable built
motionEyeOS
  • motionEyeOS is a Linux distribution that turns a single-board computer into a video surveillance system. The OS is based on BuildRoot and uses motion as a backend and motionEye for the frontend
  • Visit the motionEyeOS GitHub and its GitHub Wiki for more information
  • Suitable for 1GB/2GB PINE A64(+) variants
  • Login with
    • Username: admin
    • Password:
    • Scan for its IP with hostname MEYE-* and go to the admin web interface https://[PINE A64(+) motionEyeOS IP Address] and after login, you should able to see the output of the CAMERA MODULE on the web interface
    • Use the PINE64 USB SERIAL CONSOLE/PROGRAMMER and login
DietPi
Q4OS [No Longer Maintained]
Q4OS [24-r3]
Arch mainline Linux XFCE [No Longer Maintained]
* From SSH Login default disable root to access . So please first login alarm and password alarm and then command su type password root
Cent OS [No Longer Maintained]
https://files.pine64.org/sw/pine64_installer/json/centos.jpg
  • Centos-7.4.1708 with kernel from Armbian-5.44 and Gnome Desktop
  • Centos-7.5.1804 with kernel from Armbian-5.44 and Docker v1.13 and OpenShift v3.7.1
  • Centos-7.4.1708 with kernel from Armbian-5.44 (minimum build)
  • Login with
    • username: root
    • password: centos
CentOS-8 Minimal Build Image [microSD Boot]
  • Centos-8.2 with kernel from Armbian 5.7.15 (minimum build)
  • Login with
    • username: root
    • password: centos
CentOS-8 Server Build Image [microSD Boot]
  • Centos-8.2 with kernel from Armbian 5.7.15 (server build)
  • Login with
    • username: root
    • password: centos
LibreELEC(KODI) [No Longer Maintained]
Nightly Build Image [microSD Boot] [20191226]
NEMS Linux [No Longer Maintained]
https://files.pine64.org/sw/pine64_installer/json/nems.jpg
  • Suitable for 512MB/1GB/2GB PINE A64(+) variants
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [v1.5 - Build 1]
openHAB 2 [No Longer Maintained]
Xenial Minimal Image [No Longer Maintained]
Xenial Minimal Image [0.6.2-77] by ayufan
  • This is the latest Xenial 16.04 image provided by ayufan based on longsleep base image. NB. This is a base image and doesn't come with a DE
  • ayufan's GitHub
  • Login with
    • username: pine64
    • password: pine64
  • Execute sudo /usr/local/sbin/resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
  • To update to the newest uboot, kernel and fixes use scripts found in /usr/local/sbin/
  • Install Mate DE using: sudo /usr/local/sbin/install_desktop.sh mate
Gentoo [No Longer Maintained]
  • A Gentoo image built by Xalius
  • To learn more about the Gentoo linux build please see the forum thread
  • Login with
    • Username: gentoo
    • Password: gentoo
    • Root Password: gentoo
China NeoKylin “中标麒麟” [No Longer Maintained]
China NeoKylin “中标麒麟” [20170210]
OpenMediaVault [No Longer Maintained]
OpenMediaVault Community Build Image [microSD Boot]
Retroarch [No Longer Maintained]
Retroarch Community Build Image by pfeerick
BSD Image Releases
NetBSD
NetBSD Community Build Image [microSD Boot]
Android Image Releases
Android 7.x
Android 7.1 Community Image [v0.3.10-r66] [No Longer Maintained]
Android 6.x
Stock Android 6.0 (HDMI Video Output) [20170112 v2.0.1]
  • This build optimizes Gigabit Ethernet parameter and improves on GbE connectivity
  • Rootable build, online update (OTA) only work when the build still not root
  • Set default HDMI output to 720P, video setting supports both 720P and 1080P/
  • There is no Phoenixcard build release
  • The Android build suitable for 1GB/2GB PINE A64+ Board, not advise to run on 512MB PINE A64 Board due to system memory constrain
  • DD images:
Stock Android 6.0.1 (LCD Panel Video Output) [20170209]
  • THIS VERSION IS FOR LCD PANEL !!!!
  • Support dual display (LCD + HDMI output) output
  • new MAC address assignment method, tags to board and SoC unique ID
  • LCD resolution is 1024 x 600
  • Support CSI camera module
  • DD images:
  • Phoenix Card image:
    • Only use Phoenixcard method as last resort option
    • Expected slow (10-30 minutes) boot up and response time during initialization
    • This process may not everytime build up successfully
  • Rooted DD images:
Android 5.x
Stock Android 5.1.1 (HDMI Video Output) [20161208 v1.2.8]
  • Update GMS software package to 5.1r4
  • Set UVC USB camera as front camera and 5M Pixel camera module as real camera
  • Offline OTA Update images 20160711 ver 1.2.6 build:
    • 1. Download the zip file and copy over to Android microSD card using "ES File Explorer" app
    • 2. Launch "Update" app, and press "back" key, the "local update" box will appear
    • 3. Select the download zip file and perform update. Please note that this update file is large and will targets around 10 minutes to perform this update
  • DD images:
  • Rooted DD images:
[OLD] Android 5.1.1 (LCD Panel Video Output) [20160603]
  • THIS VERSION IS FOR LCD PANEL !!!! (Same LCD panel orientation as previous build)
  • DD images:
Bliss OS [No Longer Maintained]
Bliss OS [20170919]
  • An Open-Source OS, based on Android, for phones, tablets & PCs
  • Multi-Windows Android Build
  • You can visit the Bliss OS website here
  • This version best suitable for 2GB PINE A64+ Board, can runs on 1GB PINE A64+ Board with performance lagging, not suitable for 512MB PINE A64 Board
  • DD images:
  • Use the Taskbar launcher for Desktop mode UI
Remix OS [No Longer Maintained]
Remix OS 2.0 [20170105]
Windows 10 IoT Releases
Win10 IoT [10.0.15063.0_20170602] [No Longer Maintained]
  • 10.0.15063.0_20170602
    • Update Notes since 10.0.15063.0_20170524:
      • Fix the failure of default application installation caused by a app certification issue
      • Fix that the default application cannot start automatically after installation
      • Fix Ethernet initialization problem and now the Ethernet will start successfully every time
      • Enable the usermode access for all unusable GPIO pins in Pi-2 bus( later provide a UWP sample to show how to control these pins )
    • Extra Notes:
  • 10.0.15063.0_20170524
    • Some Updates:
      • Update the OS version to build v.10.0.15063.0 (Creators Update)
      • New page style of Device Portal, visit https://deviceipaddr:8080 to check it
      • Built-in Cortana assistant, need to be enabled in settings page in default app and Device Portal
      • Support on-screen keyboard, need to be enabled in Device Portal
      • Enable 100M Ethernet and fix some bugs
      • Support built-in UART bus in A64 SoC(not built in the ffu, later provide driver binary and deployment helper)
      • Support built-in IR module in A64 SoC(not built in the ffu, later provide source code and dev doc for developers in community)
    • Known Issues:
      • Kernel debug is enabled by default. This will slow the bring-up process. If a kernel debug is not necessary for you, visit Device Portal and navigate to Processes->Run Command page, run this command to disable:
        • Bcdedit /store C:\EFIESP\EFI\Microsoft\boot\BCD /set {default} debug off
      • An PnP bug in audio device may cause a blue screen when acting software shutdown
      • Ethernet device may not start with problem code 12 at the first time to bring up
Linux BSP SDK
Linux BSP Kernel 4.9
Android SDK
Android Oreo [v8.1]
Mali-400 64-bit Driver
Other Tools
Checking microSD Card Performance and whether it is Counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not
