PINE A64 Software Releases
Checking microSD Card performance and check whether is counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not.
Linux Image Release
Special thanks to Sunxi community and longsleep contribution
Debian Linux Jessie with Mate GUI Image [20160701] by lenny.raposo with Longsleep kernel
Debian Linux Jessie with Mate GUI Image [20160508] by lenny.raposo with Longsleep kernel
  • DD image (for 8GB and above SD Card):
  • Up to date on longsleep uboot, kernel and fixes
  • Suitable for 512MB/1GB/2GB PineA64 Board
  • Login with
    • username: debian
    • password: debian
  • Execute resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
Ubuntu Linux Image [20160530] based on Longsleep work, build by Pine64
  • Thanks to longsleep works, the Linux build progress rapidly, This is a build based on longsleep works and may not have all bell and whistles from longsleep and Sunxi community. For latest build, you can create one and following this thread
  • Based on longsleep xubuntu-xenial 20160507
  • Included Mate Desktop, Firebox Browser, Thunderbird Email, and LibreOffice Suite.
  • Included with Wifi, [Bluetooth still not yet working]
  • Suitable for 1GB/2GB Pine A64+ Board, not advise to run on 512MB Pine A64 Board
  • Login with
    • username: ubuntu
    • password: ubuntu
Arch Linux with XFCE GUI Image [20160501] based on Longsleep build, updated by Pine64
  • Thanks to longsleep works, the Linux build progress rapidly, This is an OLD build based on longsleep and may not have all bell and whistles from longsleep and Sunxi community. Please note that longsleep no longer support on the ArchLinux development and focus on ubuntu.
  • Included XFCE Desktop, Midori Browser, Thunder Email, LibreOffice Suite, and Gnome MPlayer
  • Login with
    • User Name: alarm Password: alarm
    • User Name: root Password: root
Ubuntu Linux Image base on Longsleep 20160415 image, courtesy of Michael Larson
  • Direct download from google drive
  • Included Midori Browser, Geary Email, LibreOffice Suite, VLC, and Gimp
  • You can flash this in linux using all the regular methods or you can use Win32 Disk Image software or something simular.
  • Gparted is installed and allows you to re-size the rootfs partition to the rest of your drive if it is bigger than an 8GB drive.See the video instruction on how to use Gpart and change login information
  • User Name: Ubuntu Password: ubuntu
  • User Name: Ubuntu2 Password: ubuntu2
openHAB Open Source Home Automation Image Release
openHAB Image base on Ubuntu Linux Longsleep 20160415 image
  • This image is a headless Ubuntu with a pre-installed openHAB 2.0 beta3.
  • You need to agree on Oracle Binary Code License Agreement for the Java SE Platform Products and JavaFX in order to download
  • openHAB Image Download
  • You can flash this in linux using all the regular methods or you can use Win32 Disk Image software or something similar.
  • This is a "headless" build, the setup process thru serial console, no HDMI vidoe output.
  • Login with
    • username: openhab
    • password: changeit
  • Includes Oracle JDK 1.8.0
  • openHAB is installed in /opt/openhab
  • openHAB is started as a system service, you can use systemctl for it:
    • sudo systemctl status openhab
    • sudo systemctl stop openhab
    • sudo systemctl start openhab
  • Initial boot can take a few minutes before http://openhab:8080 becomes available.
  • Note: ZWave is NOT yet supported
  • For getting started with openHAB, please refer to http://docs.openhab.org/
Remix OS Image Release
Remix OS 2.0 Image Release 20160718
  • This version best suitable for 2GB Pine A64+ Board, can runs on 1GB Pine A64+ Board with performance lagging, not suitable for 512MB Pine A64 Board
  • OTA starts distribute after two weeks when this build confirmed as good released candidate
  • Overall performance improvement
  • Add Remix apps market
  • Video setting supports both 720P and 1080P
  • Supports video screen scaling function
  • New MAC address assignment method, tags to board and SoC unique ID.
  • Support UVC USB camera as front camera
  • Known issues:
    • Not yet support 5M Pixel camera module as real camera
    • Even the HDMI output can set to 720P, but during boot up time, the boot logo stil maintain as 1080P.
  • DD image (for 8GB microSD Card):
  • Phoenix Card image:
    • Only use Phoenixcard method as last resort option.
    • Expected slow (10-30 minutes) boot up and response time during initialization. After initial setup and reboot, the performance will resume back to normal.
    • This process may not everytime build up successfully
    • Direct Download from pine64.org
    • Torrent download
    • MD5 (Zip file): 69566EF6E37340ACD138F58C66B6C6C7
    • File Size: 575MB
Remix OS 2.0 Image Release 20160415 [BETA]
Android Image Release
Android 5.1.1 Image (HDMI Video Output) Release 20160711
  • The Android build suitable for 1GB/2GB Pine A64+ Board, not advise to run on 512MB Pine A64 Board due to system memory constrain
  • Rootable build, online update (OTA) only work when the build still not root.
  • Set default HDMI output to 720P, video setting supports both 720P and 1080P
  • Add Ethernet Network setting.
  • Update GMS software package to 5.1r4
  • Set UVC USB camera as front camera and 5M Pixel camera module as real camera
  • DD images:
Android 5.1.1 Image (HDMI Video Output) Release 20160505
  • new MAC address assignment method, tags to board and SoC unique ID.
  • The Bluetooth functions now work which broken on previous build.
  • HDMI output can set to either 720P or 1080P. The boot up logo screen still display on 1080P and will change to 720P on next build
  • Implement new UVC USB camera driver
  • DD images:
Android 5.1.1 Image (LCD Panel Video Output) Release 20160603
  • THIS VERSION IS FOR LCD PANEL !!!! (Same LCD panel orientation as previous build)
  • The Android build suitable for 1GB/2GB Pine A64+ Board.
  • LCD resolution is 1024 x 600
  • Support CSI camera module
  • DD images:
Android 5.1.1 Image (HDMI Video Output) Release 20160303
Android 5.1.1 Image (LCD Panel Video Output) Release 20160419
  • The Android build only suitable for 1GB/2GB Pine A64+ Board
Android PhoenixCard Image Release 20160216
Linux BSP SDK
Linux BSP 2.0
Linux BSP 1.2
Linux BSP 1.0 20151120
Android SDK
Android Marshmallow ver 6.0
Android Lollipop ver 5.1.1
Mali 64-bit Driver
Mali 64-bit Driver dated 2016-06-22
Other Tools
