PINE A64 Software Releases
Revision as of 01:50, 7 June 2016 by Tllim (talk | contribs) (→openHAB Image base on Ubuntu Linux Longsleep 20160415 image)
Checking microSD Card performance and check whether is counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not.
Linux Image Release
Special thanks to Sunxi community and longsleep contribution
- Sunxi Pine64 Page
- Longsleep BSP Linux Builds Download Page
- Longsleep BSP Linux Kernel Thread on Pine64 Forum
- Longsleep BSP Ubuntu Xenial Thread on Pine64 Forum
- Longsleep BSP Arch Linux Thread on Pine64 Forum
Debian Linux Jessie with Mate GUI Image [20160508] by lenny.raposo with Longsleep kernel
- DD image (for 8GB and above SD Card):
- Direct download from pine64 pro
- Lenny's Debian Support thread on Pine64 forum
- MD5 (Zip file): 278a8bbdc4efa4c8026a2c9f3354dbcf
- File Size: 878MB
- Up to date on longsleep uboot, kernel and fixes
- Suitable for 512MB/1GB/2GB PineA64 Board
- Login with
- username: debian
- password: debian
- Execute resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
Ubuntu Linux Image [20160530] based on Longsleep work, build by Pine64
- Thanks to longsleep works, the Linux build progress rapidly, This is a build based on longsleep works and may not have all bell and whistles from longsleep and Sunxi community. For latest build, you can create one and following this thread
- Direct download from pine64.org
- MD5 (Zip file) : 261E440C324BAAC3B74CDB326DE98A20
- File Size: 2.37GB
- Based on longsleep xubuntu-xenial 20160507
- Included Mate Desktop, Firebox Browser, Thunderbird Email, and LibreOffice Suite.
- Included with Wifi, [Bluetooth still not yet working]
- Suitable for 1GB/2GB Pine A64+ Board, not advise to run on 512MB Pine A64 Board
- Login with
- username: ubuntu
- password: ubuntu
- Previous 20160502 Build [8GB DD image]
- MD5 (Zip file) : D3037E49D2CAB821006E19BE6E6F39BD
- File Size: 1.76GB
- Previous 20160421 Build [8GB DD image]
- Torrent Download
- MD5 (Zip file) : 1cd06bdcbc1ceaf80b81c46638045ff7
- File Size: 1.84GB
Arch Linux with XFCE GUI Image [20160501] based on Longsleep build, updated by Pine64
- Thanks to longsleep works, the Linux build progress rapidly, This is an OLD build based on longsleep and may not have all bell and whistles from longsleep and Sunxi community. Please note that longsleep no longer support on the ArchLinux development and focus on ubuntu.
- MD5 (Zip file): 69D719BA214D1B2842BE0EF79BF034F8
- File Size: 1.15GB
- Included XFCE Desktop, Midori Browser, Thunder Email, LibreOffice Suite, and Gnome MPlayer
- Login with
- User Name: alarm Password: alarm
- User Name: root Password: root
Ubuntu Linux Image base on Longsleep 20160415 image, courtesy of Michael Larson
- Direct download from google drive
- Included Midori Browser, Geary Email, LibreOffice Suite, VLC, and Gimp
- You can flash this in linux using all the regular methods or you can use Win32 Disk Image software or something simular.
- Gparted is installed and allows you to re-size the rootfs partition to the rest of your drive if it is bigger than an 8GB drive.See the video instruction on how to use Gpart and change login information
- User Name: Ubuntu Password: ubuntu
- User Name: Ubuntu2 Password: ubuntu2
openHAB Open Source Home Automation Image Release
- This image is a headless Ubuntu with a pre-installed openHAB 2.0 beta3.
- You need to agree on Oracle Binary Code License Agreement for the Java SE Platform Products and JavaFX in order to download
- openHAB Image Download
- You can flash this in linux using all the regular methods or you can use Win32 Disk Image software or something similar.
- This is a "headless" build, the setup process thru serial console, no HDMI vidoe output.
- Login with
- username: openhab
- password: changeit
- Includes Oracle JDK 1.8.0
- openHAB is installed in /opt/openhab
- openHAB is started as a system service, you can use systemctl for it:
- sudo systemctl status openhab
- sudo systemctl stop openhab
- sudo systemctl start openhab
- Initial boot can take a few minutes before http://openhab:8080 becomes available.
- Note: ZWave is NOT yet supported
- For getting started with openHAB, please refer to http://docs.openhab.org/
Remix OS Image Release
Remix OS 2.0 Image Release 20160415 [BETA]
- This version best suitable for 2GB Pine A64+ Board, can runs on 1GB Pine A64+ Board with performance lagging, not suitable for 512MB Pine A64 Board
- DD image (for 8GB microSD Card):
- 2nd download site
- Torrent download
- MD5 (Zip file): efeb178d28593d4d928f70c8506953a4
- File Size: 1.2GB
- DD image (for 16GB microSD Card):
- MD5 (Zip file): 980FD21C1B5B2E458F37E7C79AA82FFC
- File Size: 1.1GB
- DD image (for 32GB microSD Card):
- MD5 (Zip file): 604AF6EA27694D72726B5EB3FEADCA21
- File Size: 1.0GB
- DD image (for 64GB microSD Card):
- MD5 (Zip file): E229ABB77747EBD4BA7DD511E79332E9
- File Size: 1.4GB
- Phoenix Card image:
- Direct Download from pine64.org
- 2nd download site
- Torrent download
- MD5 (Zip file): 82cb23dfd58d11c53bc7986a7b15d4e6
- File Size: 465MB
Setup Info
- Use Winrar to extract the img file form the archive
- Use Allwinner PhoenixCard Bootable SD-Card Creator to create the bootable SD Card
Android Image Release
Android 5.1.1 Image (HDMI Video Output) Release 20160505
- The Android build suitable for 1GB/2GB Pine A64+ Board, not advise to run on 512MB Pine A64 Board due to system memory constrain
- Rootable build, online update (OTA) only work when the build still not root.
- new MAC address assignment method, tags to board and SoC unique ID.
- The Bluetooth functions now work which broken on previous build.
- HDMI output can set to either 720P or 1080P. The boot up logo screen still display on 1080P and will change to 720P on next build
- Supports video screen scaling function
- Implement new UVC USB camera driver
- For 8GB microSD Card
- MD5 (Zip file): FF893E3BE6C2C3695A6217244AF6A336
- File Size: 596MB
- For 16GB microSD Card
- MD5 (Zip file): 790F89AED4C9236D337EC98D7F74293A
- File Size: 594MB
- For 32GB microSD Card
- MD5 (Zip file): EDE6DDC80C5A2BE7441414D2851ABA0B
- File Size: 931MB
- For 64GB microSD Card
- MD5 (Zip file): 0DEE0A2A9A7F69B6354679C4B7E3CCCF
- File Size: 1.10GB
- Rooted DD image:
- MD5 (Zip file): 322E2680A32B43B5EE4D2DF15BE0B767
- File Size: 600MB
- MD5 (Zip file): D80A6A7E8C013E38C2F647D05C98D300
- File Size: 932MB
- MD5 (Zip file): 21D720FA0AEACEEDEEF53492437539F2
- File Size: 1.10GB
- MD5 (Zip file): 5A3998F6159DF55A68063C0FDE9D183B
- File Size: 1.07GB
- MD5 (Zip file): 8347249BB2106AA103F87B4C9947AFEE
- File Size: 348MB
Android 5.1.1 Image (LCD Panel Video Output) Release 20160603
- THIS VERSION IS FOR LCD PANEL !!!! (Same LCD panel orientation as previous build)
- The Android build suitable for 1GB/2GB Pine A64+ Board.
- LCD resolution is 1024 x 600
- Support CSI camera module
- MD5 (Zip file): 689C05185D95D10B1F211E0A155C3BB2
- File Size: 597MB
- MD5 (Zip file): E24981B1ADECF5E578CB0D4E8FB638D9
- File Size: 604MB
- MD5 (Zip file): 6486B0017DFCCB5068665E24D87C0D22
- File Size: 626MB
- MD5 (Zip file): 3CC094B520C78B90C9F00069AA06B2AB
- File Size: 645MB
- Rooted DD image:
- MD5 (Zip file): 9271CAF9F2C1769664BFCEF30EB829C4
- File Size: 591MB
- MD5 (Zip file): AB45150D5DFCF0FAA438B8323A829BEC
- File Size: 603MB
- MD5 (Zip file): 893D32274C973D41B472228B80DFAFC2
- File Size: 634MB
- MD5 (Zip file): 26ECB4ADECEB5126F7896E80E6123B8B
- File Size: 348MB
Android 5.1.1 Image (HDMI Video Output) Release 20160303
- Torrent download
- MD5 (Zip file): 2abdf3578a50e2df2c3e33b8e61c80c9
- File Size: 594MB
- Torrent download
- MD5 (Zip file): 929ba8659028cf42895804864d66991e
- File Size: 337MB
Android 5.1.1 Image (LCD Panel Video Output) Release 20160419
- The Android build only suitable for 1GB/2GB Pine A64+ Board
- MD5 (Zip file): 9CC51A45F2A44CDD9D6686640BF64EC3
- File Size: 337MB
Android PhoenixCard Image Release 20160216
- Torrent Download
- MD5: 0aca1b9cc94babdb9313ce8c33a154f2
- File Size: 345MB
Linux BSP SDK
Linux BSP 2.0
- MD5 (Zip file): 29F82640BE1D48616365FC854A23A496
- File Size: 6.68GB
Linux BSP 1.2
- MD5 (Zip file): 60FC4462586C48822408865F1D2A8B25
- File Size: 5.92GB
Linux BSP 1.0 20151120
- Google Drive : Allwinner A64 Linux 3.10 BSP
- Torrent : Allwinner A64 Linux 3.10 BSP
- Direct download from pine64.org : Allwinner A64 Linux 3.10 BSP
- Linux Boot Image Release 2016/Feb/16 (8.3MB)
- This Linux boot.img support Gigabit Ethernet
Android SDK
Android Marshmallow ver 6.0
- MD5 (Zip file): 12362D0B63EBF29FC363A50A942346D5
- File Size: 12.17GB
Android Lollipop ver 5.1.1
- MD5 (Zip file): 26860B070C48CFDF36EBF87E76A232DB
- File Size: 18.00GB
