PineTime
Revision as of 22:05, 28 January 2020 by Dbrgn (talk | contribs) (Fix typo: nrfjporg -> nrfjprog)
Frequently asked questions
Read this first!
Specifications
Dimensions: 37.5 x 40 x 11mm
Weight: 38 grams
IP Rating: IP67 (waterproof to 1 meter)
Display:
Size: 1.3 inches (33mm) diagonal
Type: IPS capacitive touchscreen, RGB 65K colors
Display Controller: ST7789
Resolution: 240x240 pixels
RAM: 64KB
Feedback: Vibration motor
Battery: 170-180mAh LiPo
SWD Pinout
The devkits have exposed SWD pins for flashing and debugging. The pinout is: PineTime SWD location.jpg
Driving the peripherals
Display
PineTime pin ST7789 pin
LCD_SCK (P0.02) SPI clock
LCD_SDI (P0.03) SPI MOSI
LCD_RS (P0.18) Clock/data pin (CD)
LCD_CS (P0.25) Chip select
Notes:
Battery measurement
How to write battery friendly software?
The key to save battery is to enable only what you need when you need it. NRF52832 has a lot of functionalities allowing you to draw as little current as possible. Here are some tips and tricks:
  • Disable / shutdown / put in sleep mode all devices around the MCU (display controller, touch controller, external memory,...).
  • Disable all peripheral inside the MCU when you don't need them (SPI, TWI(I²C),...). The power management of the NRF52832 is very smart and will completely shut down (power off and disable the clock) the peripheral when the software disables it.
  • Put the MCU to sleep as soon and as often as possible. If you are not using a RTOS, this is done by calling WFE (wait for event) instruction. Most of the time, RTOS implement this functionality. For example, FreeRTOS calls it the tickless mode : it puts the CPU in sleep mode when no task is planned for execution for more than a specified time, and wakes up as soon as an event is detected or when a task is ready to run.
  • Do not use logging (JLink RTT, SWO, semihosting,...), it uses a lot of power.
  • Ensure that the debug circuitry of the MCU is not enabled when you measuring the battery life. The debug peripheral is enabled as soon as you connect a debugger to the device, and is not automatically disabled, even if you disconnect the debugger. The software running in the NRF52832 cannot disable the debug peripheral. How to disable the debug circuitry:
 - using nrfjprog --reset
 - using JLinkExe : issue the command writeDP 1 0
Button
The button on the side of the PineTime is disabled by default. To enable it, drive the button out pin (P0.15) high.
While enabled, the button in pin (P0.13) will be high when the button is pressed, and low when it is not pressed.
Touch panel
Pins
  • P0.10 : Reset
  • P0.06 : I²C SDA
  • P0.07 : I²C SCL
I²C
  • Device address : 0x15
NOTE : The controller go to sleep when no event is detected. In sleep mode, the controller does not communicate on the I²C bus (it appears disconnected). So, for the communication to work, you need to tap on the screen so that the chip wakes-up.
Touch events
Touch informations are available in the 63 first registers of the controller. Remember : the device is in sleep mode when no touch event is detected. It means that you can read the register only when the touch controller detected an event. You can use the Interrupt pin to detect such event in the software.
0 ?
1 GestureID : (Gesture code ,
0x00: no gesture,
0x01: Slide down,
0x02: Slide up,
0x03: Slide left,
0x04: Slide right,
0x05: Single click,
0x0B: Double click,
0x0C: Long press)
2 ? Number of touch points
4 X (LSB) coordinate
6 Y (LSB) coordinate
7 Pressure (?)
8 Miscellaneous (?)
NOTES
Registers
Register Address Description
HYN_REG_INT_CNT 0x8F
HYN_REG_FLOW_WORK_CNT 0x91
HYN_REG_CHIP_ID 0xA3
HYN_REG_CHIP_ID2 0x9F
HYN_REG_POWER_MODE 0xA5 0x05 = SLEEP
HYN_REG_FW_VER 0xA6
HYN_REG_VENDOR_ID 0xA8
HYN_REG_LCD_BUSY_NUM 0xAB
HYN_REG_FACE_DEC_MODE_EN 0xB0
HYN_REG_GLOVE_MODE_EN 0xC0
HYN_REG_COVER_MODE_EN 0xC1
HYN_REG_CHARGER_MODE_EN 0x8B
HYN_REG_GESTURE_EN 0xD0
Programming firmware
Using JLink programmer and nrfjprog tools
The following steps have been tested with the Segger JLink embedded in the NRF52-DK development board.
1. Connect the Pinetime SWD pins to the debugger (P20 on NRF52-DK)
Pintime JLink
GND GND
SWDCLK SWDCLK
SWDIO SWDIO
VCC (3.3V) VTG (target detect)
2. Unlock the device and erase the memory. You need to execute this step only once, to remove the read protection on the memory. Note that it will erase the whole flash memory of the MCU! :
nrfjprog -f NRF52 --recover
3. Program the BLE softdevice (if needed by the firmware). Replace PATH_TO_NRF_SDK by the path where you unzipped the NRF52 SDK :
nrfjprog -f NRF52 --program /PATH_TO_NRF_SDK/components/softdevice/s132/hex/s132_nrf52_6.1.1_softdevice.hex --sectorerase
4. Program the firmware (replace firmware.hex by the actual filename of the firmware):
nrfjprog -f NRF52 --program firmware.hex --sectorerase
5. Reset and run the new firmware:
nrfjprog -f NRF52 --reset
Using OpenOCD and a Raspberry Pi
Instructions in Medium post, subsequently updated with a more reliable method under development, so may be a bit of a moving target.
Using STM32 bluepill as blackmagic probe
Instructions in forum post or gist (mac os)
Manual / Articles
Development efforts
Project Homepage Project Source PineTime Implementations
FreeRTOS https://www.freertos.org https://sourceforge.net/projects/freertos/ JF002/Pinetime
kaythe/pinetime-os
Zephyr https://www.zephyrproject.org https://github.com/zephyrproject-rtos/zephyr najnesnaj/pinetime-zephyr
SuperPrower/pinetime_zephyr_sample_fw
mynewt https://mynewt.apache.org/about/ https://github.com/apache/mynewt-core lupyuen/pinetime-rust-mynewt
MbedOS https://os.mbed.com https://github.com/ARMmbed/mbed-os sethitow/mbed-pinetime
RIOT http://riot-os.org/ https://github.com/RIOT-OS/RIOT/ bosmoment/PineTime-apps
TinyGo https://tinygo.org https://github.com/tinygo-org/tinygo aykevl/go-smartwatch
MicroPython https://micropython.org/ https://github.com/micropython/micropython daniel-thompson/wasp-os
AdaFruit bootloader https://github.com/adafruit/Adafruit_nRF52_Bootloader daniel-thompson/wasp-bootloader
UI concepts and drawings arteeh/pinetimeos
Datasheets and Schematics
Schematics
Component Datasheets
Community
