PineTime
Contents
Frequently asked questions
Click here to see frequently asked questions
Specifications
Dimensions: 37.5 x 40 x 11mm
Weight: 38 grams
IP Rating: IP67 (waterproof to 1 meter)
Display:
- Size: 1.3 inches (33mm) diagonal
- Type: IPS capacitive touchscreen, RGB 65K colors
- Display Controller: ST7789
- Resolution: 240x240 pixels
RAM: 64KB
Feedback: Vibration motor
Battery: 170-180mAh LiPo
SWD Pinout
The devkits have exposed SWD pins for flashing and debugging. The pinout is:
Driving the peripherals
Display
PineTime pin | ST7789 pin |
LCD_SCK (P0.02) | SPI clock |
LCD_SDI (P0.03) | SPI MOSI |
LCD_RS (P0.18) | Clock/data pin (CD) |
LCD_CS (P0.25) | Chip select |
LCD_RESET (P0.26) | Display reset |
LCD_BACKLIGHT_{LOW,MID,HIGH} | Backlight (active low) |
Notes:
- Chip select must be held low while driving the display. It must be high when using other SPI devices on the same bus (such as external flash storage) so that the display controller won't respond to the wrong commands.
- SPI must be used in mode 3. Mode 0 (the default) won't work.
- LCD_DISPLAY_* is used to enable the backlight. Set at least one to low to see anything on the screen.
- Use SPI at 8MHz (the fastest clock available on the nRF52832) because otherwise refreshing will be super slow.
Battery
batteryVoltage = adcValue * 2000 / (4095 / 3.3) batteryVoltage = adcValue * 2000 / 1241
Touch panel
Pins
- P0.10 : Reset
- P0.28 : Interrupt (signal to the CPU when a touch event is detected)
- P0.06 : I²C SDA
- P0.07 : I²C SCL
I²C
- Device address : 0x15
- Frequency : from 10Khz to 400Khz
NOTE : The controller go to sleep when no event is detected. In sleep mode, the controller does not communicate on the I²C bus (it appears disconnected). So, for the communication to work, you need to tap on the screen so that the chip wakes-up.
Touch events
Touch informations are available in the 63 first registers of the controller. Remember : the device is in sleep mode when no touch event is detected. It means that you can read the register only when the touch controller detected an event. You can use the Interrupt pin to detect such event in the software.
These 63 bytes contain up to 10 touch point (X, Y, event type, pressure,...) :
Byte | Bit7 | Bit6 | Bit5 | Bit4 | Bit3 | Bit2 | Bit1 | Bit0 |
0 | ? | |||||||
1 | GestureID : (Gesture code ,
0x00: no gesture, 0x01: on a slippery, 0x02: decline, 0x03: Left slip, 0x04: Right slide, 0x05: Click, 0x0B: Double-click, 0x0C: Press) | |||||||
2 | ? | Number of touch points | ||||||
3 | Event (0 = Down, 1 = Up, 2 = Contact) | ? | X (MSB) coordinate | |||||
4 | X (LSB) coordinate | |||||||
5 | ? | Touch ID | Y (MSB) coordinate | |||||
6 | Y (LSB) coordinate | |||||||
7 | Pressure (?) | |||||||
8 | Miscellaneous (?) |
NOTES
- The touch controller seems to report only 1 touch point
- Fields X, Y, Number of touch points and touch ID are updated. The others are always 0.
Registers
Register | Address | Description |
HYN_REG_INT_CNT | 0x8F | |
HYN_REG_FLOW_WORK_CNT | 0x91 | |
HYN_REG_WORKMODE | 0x00 | 0 = WORK, 0x40 = FACTORY |
HYN_REG_CHIP_ID | 0xA3 | |
HYN_REG_CHIP_ID2 | 0x9F | |
HYN_REG_POWER_MODE | 0xA5 | 0x05 = SLEEP |
HYN_REG_FW_VER | 0xA6 | |
HYN_REG_VENDOR_ID | 0xA8 | |
HYN_REG_LCD_BUSY_NUM | 0xAB | |
HYN_REG_FACE_DEC_MODE_EN | 0xB0 | |
HYN_REG_GLOVE_MODE_EN | 0xC0 | |
HYN_REG_COVER_MODE_EN | 0xC1 | |
HYN_REG_CHARGER_MODE_EN | 0x8B | |
HYN_REG_GESTURE_EN | 0xD0 | |
HYN_REG_GESTURE_OUTPUT_ADDRESS | 0xD3 | |
HYN_REG_ESD_SATURATE 0xED | 0xED |
WARNING : Writing the SLEEP command (write 0x05 in HYN_REG_POWER_MODE) seems to freeze the controller (it returns only static values) until the battery is totally drained and the whole system reset. Analysis and debugging is more than welcome!
Programming firmware
Using JLink programmer and nrfjprog tools
The following steps have been tested with the Segger JLink embedded in the NRF52-DK development board.
1. Connect the Pinetime SWD pins to the debugger (P20 on NRF52-DK)
Pintime | JLink |
GND | GND |
SWDCLK | SWDCLK |
SWDIO | SWDIO |
VCC (3.3V) | VTG (target detect) |
2. Unlock the device and erase the memory. You need to execute this step only once, to remove the read protection on the memory. Note that it will erase the whole flash memory of the MCU! :
nrfjporg -f NRF52 --recover
3. Program the BLE softdevice (if needed by the firmware). Replace PATH_TO_NRF_SDK by the path where you unzipped the NRF52 SDK :
nrfjprog -f NRF52 --program /PATH_TO_NRF_SDK/components/softdevice/s132/hex/s132_nrf52_6.1.1_softdevice.hex --sectorerase
4. Program the firmware (replace firmware.hex by the actual filename of the firmware):
nrfjprog -f NRF52 --program firmware.hex --sectorerase
5. Reset and run the new firmware:
nrfjprog -f NRF52 --reset
Manual / Articles
Development efforts
Datasheets and Schematics
Schematics
Component Datasheets
- NORDIC SoC information:
- PMU (Power Management Unit) information:
- SPI Flash information:
- LCD Panel:
- Touchpad information:
- Sensor:
