PineTime
Revision as of 00:43, 5 December 2019 by FlyingToast (talk | contribs)
Specifications
  • BODY:
    • Dimensions: 37.5mm x 40mm x 11mm
    • Weight: 38 grams
    • Build: Zinc Alloy and Plastic
    • IP Rating: IP67 (waterproof to 1 meter
  • DISPLAY:
    • Type: IPS capacitive touchscreen, RGB 65K colors
    • Size: 1.3 inches
    • Resolution: 240x240 pixels, 1:1 ratio
  • PLATFORM:
    • OS: Various open source RTOS such as Zephyr, FreeRTOS, Mbed, Mynewt, or NuttX. See PineTime RTOS Comparison.
    • SoC: NORDIC Semiconductor nRF52832
    • CPU: 64MHz ARM Cortex-M4F
  • MEMORY:
    • Internal: 512KB Flash, 64KB RAM
    • Additional: SPI NOR 4 MB Flash
  • COMMUNICATION:
    • Bluetooth 5 (including Low Energy)
  • FEATURES:
    • Sensors: Accelerometer, PPG Heart Rate Sensor
    • Actuator: Vibrator
  • BATTERY:
    • Built-in LiPo 170-180mAh battery
    • Charging: Proprietary 2pin 5V 500mA, USB type A plug
SWD Pinout
The devkits have exposed SWD pins for flashing and debugging. The pinout is: PineTime SWD location.jpg
Driving the peripherals
Display
PineTime pin ST7789 pin
LCD_SCK (P0.02) SPI clock
LCD_SDI (P0.03) SPI MOSI
LCD_RS (P0.18) Clock/data pin (CD)
LCD_CS (P0.25) Chip select
Notes:
Battery
Datasheets and Schematics
PineTime Schematics
Component Datasheets
Manual / Articles
