PineTime
Revision as of 22:22, 28 October 2019 by Ayke (talk | contribs) (→‎Display: SPI speed)
PINE64 SmartWatch "PineTime"
The PINE64 SmartWatch, dubbed "PineTime", is a product of a community effort for an open source smartwatch in collaboration with wearable RTOS and Linux app developers & communities.
PineTime development has been broken down into two distinct phases:
  • Phase One - PineTime Dev Kit Project on October 2019
  • Phase Two - Introducing the PineTime smartwatch around Q1 2020, depending on development results in Phase 1.
PineTime Concept Photo
PineTime Case and Charging Cradle Photos
PineTime on wrist Photo.jpg PineTime PPG Sensor Photo.jpg PineTime Charging Cradle Photo.jpg
PineTime DevKit internal Photos
Watch Information
  • LAUNCH:
    • Announced: Tweet on 13 September 2019
    • Devkit Release: October, 2019
    • Expected Release: Q1/Q2 2020, pending on development result
    • Availability: at least 5 years
  • BODY:
    • Dimensions: 37.5mm x 40mm x 11mm
    • Weight: 38 grams
    • Build: Zinc Alloy and Plastic
    • Environmental Rating: IP67 (waterproof to 1 meter of immersion; not applicable to devkits)
  • DISPLAY:
    • Type: IPS capacitive touchscreen, RGB 65K colors
    • Size: 1.3 inches
    • Resolution: 240x240 pixels, 1:1 ratio
  • PLATFORM:
    • OS: Various open source RTOS such as Zephyr, FreeRTOS, Mbed, Mynewt, or NuttX
    • SoC: NORDIC Semiconductor nRF52832 (final product may use nRF52840)
    • CPU: 64MHz ARM Cortex-M4F
  • MEMORY:
    • Internal: 512KB Flash, 64KB RAM (nRF52840: 1 MB flash, 256KB RAM)
    • Additional: SPI NOR 8 MB Flash
  • COMMUNICATION:
    • Bluetooth 5 (including Low Energy)
  • FEATURES:
    • Sensors: Accelerometer, PPG Heart Rate Sensor
    • Actuator: Vibrator
  • BATTERY:
    • Built-in LiPo 170-180mAh battery
    • Charging: Proprietary 2pin 5V 500mA, USB type A plug
  • PRICE:
    • USD $22.99 (PineTime pebble and charging cradle, based on phone on PineTime devkit hardware configuration)
    • USD $2 and up (20mm straight generic wrist band: silicone, NATO, Milanese steel, leather, and etc)
PineTime Schematic and Certifications
PineTime DevKit SWD Probe
  • PineTime SWD probe pinout definition:
PineTime SWD Probe Usage Method
Slightly bend or zig-zag the probe pins to the left and right to strengthen contact to the SWD pins on the dev kit.
Note: The color coding on the SWD probe wires is random and meaningless.
Driving the peripherals
Display
PineTime pin ST7789 pin
LCD_SCK (P0.02) SPI clock
LCD_SDI (P0.03) SPI MOSI
LCD_RS (P0.18) Clock/data pin (CD)
LCD_CS (P0.25) Chip select
Notes:
Datasheets for Components
