PineTime
Frequently asked questions / Getting started
Read these first!
Default OS
The current default operating system on the PineTime is called InfiniTime, you can find more information about the firmware on its GitHub page. First devkits shipped with a proprietary custom firmware.
You can find a list of available firmware and other software here: PineTime Development
Companion Apps
PineTime/InfiniTime needs a companion app to e.g. upload a firmware, get notifications from a phone, or just get the date/time. Here are some companion apps:
  • Gadgetbridge (Android >= 4.4) - Companion mobile app, supports updating firmware/bootloader, send notifications, etc.
  • Amazfish (SailfishOS and Linux) - Companion mobile and desktop app, supports updating firmware/bootloader, send notifications, etc.
  • Siglo (Linux) - Companion desktop app.
  • PinetimeFlasher (Windows) - Companion desktop app, only supports flashing firmware.
  • nRFConnect (iOS) - Only supports flashing firmware.
  • [https://github.com/xan-m/Infini-iOS (iOS) - Companion mobile app in early development which will support updating firmware/bootloader, send notifications, etc.
Short overview / Specifications
Dimensions: 37.5 x 40 x 11mm
Weight: 38 grams
IP Rating: IP67 (waterproof to 1 meter (sealed edition!))
Display:
Size: 1.3 inches (33mm) diagonal
Type: IPS capacitive touchscreen, RGB 65K colors
Display Controller: ST7789
Resolution: 240x240 pixels
RAM: 64KB
Feedback: Vibration motor
Battery: 170-180mAh 3.8V LiPo
Community
Forum
Chat
Developers and coding
Development efforts
To read more about development on the PineTime, the projects available and more technical details, check out PineTime Development
Useful articles and blog posts
Hardware
Display
PineTime pin ST7789 pin
LCD_SCK (P0.02) SPI clock
LCD_SDI (P0.03) SPI MOSI
LCD_RS (P0.18) Command/Data pin (CD)
LCD_CS (P0.25) Chip select
Notes:
References:
Adafruit ST7789 driver in cpp
Battery measurement
Button
The button on the side of the PineTime is disabled by default. To enable it, drive the button out pin (P0.15) high.
While enabled, the button in pin (P0.13) will be high when the button is pressed, and low when it is not pressed.
Touch panel
Pins
  • P0.10 : Reset
  • P0.06 : I²C SDA
  • P0.07 : I²C SCL
I²C
  • Device address : 0x15
NOTE: The controller go to sleep when no event is detected. In sleep mode, the controller does not communicate on the I²C bus (it appears disconnected). So, for the communication to work, you need to tap on the screen so that the chip wakes-up.
NOTE: The I²C bus, also known as TWI bus has known issues, make sure to write your TWI driver with timeouts.
Touch events
Touch information is available from the 63 first registers of the controller. Remember: the device is in sleep mode when no touch event is detected. It means that you can read the register only when the touch controller detected an event. You can use the Interrupt pin to detect such event in the software.
0 ?
1 GestureID : (Gesture code ,
0x00: no gesture,
0x01: Slide down,
0x02: Slide up,
0x03: Slide left,
0x04: Slide right,
0x05: Single click,
0x0B: Double click,
0x0C: Long press)
2 ? Number of touch points
4 X (LSB) coordinate
6 Y (LSB) coordinate
7 Pressure (?)
8 Miscellaneous (?)
NOTES
Registers
Register Address Description
HYN_REG_INT_CNT 0x8F
HYN_REG_FLOW_WORK_CNT 0x91
HYN_REG_CHIP_ID 0xA3
HYN_REG_CHIP_ID2 0x9F
HYN_REG_POWER_MODE 0xA5 0x03 = SLEEP (reset the touchpanel using the reset pin before using this register : pin_low, delay 5ms, pin_high, delay 50ms then write 3 to register 0xA5)
HYN_REG_FW_VER 0xA6
HYN_REG_VENDOR_ID 0xA8
HYN_REG_LCD_BUSY_NUM 0xAB
HYN_REG_FACE_DEC_MODE_EN 0xB0
HYN_REG_GLOVE_MODE_EN 0xC0
HYN_REG_COVER_MODE_EN 0xC1
HYN_REG_CHARGER_MODE_EN 0x8B
HYN_REG_GESTURE_EN 0xD0
Accelerometer
The on board accelerometer is Bosch BMA421, connected to the I2C bus.
Pins
  • P0.06 : I²C SDA
  • P0.07 : I²C SCL
  • P0.08 : Interrupt
I2C Device address : 0x18
Datasheets and Schematics
Schematics
Note: The part number for the SPI FLASH in the schematic diagram is not correct, the PineTime features a larger external FLASH device, see below.
Chip Datasheets
Component Datasheets
Community case design
