PineTime
Contents
Frequently asked questions
Read these first!
Default OS
The current default operating system on the PineTime is called InfiniTime, you can find more information about the firmware on its GitHub page. First devkits shipped with a proprietary custom firmware.
You can find a list of available firmware and other software here: PineTime Development
Short overview
Dimensions: 37.5 x 40 x 11mm
Weight: 38 grams
IP Rating: IP67 (waterproof to 1 meter (sealed edition!))
Display:
- Size: 1.3 inches (33mm) diagonal
- Type: IPS capacitive touchscreen, RGB 65K colors
- Display Controller: ST7789
- Resolution: 240x240 pixels
RAM: 64KB
Feedback: Vibration motor
Battery: 170-180mAh LiPo
Community
Forum
Chat
- Matrix Channel (No login required to read)
- IRC Server: irc.pine64.org Channel: PineTime
- Telegram group
- Discord server invite link
Developers and coding
- Telegram group
Development efforts
To read more about development on the PineTime, the projects available and more technical details, check out PineTime Development
Useful articles and blog posts
Hardware
Display
PineTime pin | ST7789 pin |
LCD_SCK (P0.02) | SPI clock |
LCD_SDI (P0.03) | SPI MOSI |
LCD_RS (P0.18) | Command/Data pin (CD) |
LCD_CS (P0.25) | Chip select |
LCD_RESET (P0.26) | Display reset |
LCD_BACKLIGHT_{LOW,MID,HIGH} | Backlight (active low) |
Notes:
- Chip select must be held low while driving the display. It must be high when using other SPI devices on the same bus (such as external flash storage) so that the display controller won't respond to the wrong commands.
- SPI must be used in mode 3. Mode 0 (the default) won't work.
- LCD_DISPLAY_* is used to enable the backlight. Set at least one to low to see anything on the screen.
- Use SPI at 8MHz (the fastest clock available on the nRF52832) because otherwise refreshing will be super slow.
References:
Battery measurement
batteryVoltage = adcValue * 2000 / (4095 / 3.3) batteryVoltage = adcValue * 2000 / 1241
Button
The button on the side of the PineTime is disabled by default. To enable it, drive the button out pin (P0.15) high.
While enabled, the button in pin (P0.13) will be high when the button is pressed, and low when it is not pressed.
Touch panel
Pins
- P0.10 : Reset
- P0.28 : Interrupt (signal to the CPU when a touch event is detected)
- P0.06 : I²C SDA
- P0.07 : I²C SCL
I²C
- Device address : 0x15
- Frequency : from 10Khz to 400Khz
NOTE : The controller go to sleep when no event is detected. In sleep mode, the controller does not communicate on the I²C bus (it appears disconnected). So, for the communication to work, you need to tap on the screen so that the chip wakes-up.
Touch events
Touch information is available from the 63 first registers of the controller. Remember: the device is in sleep mode when no touch event is detected. It means that you can read the register only when the touch controller detected an event. You can use the Interrupt pin to detect such event in the software.
These 63 bytes contain up to 10 touch point (X, Y, event type, pressure,...) :
Byte | Bit7 | Bit6 | Bit5 | Bit4 | Bit3 | Bit2 | Bit1 | Bit0 |
0 | ? | |||||||
1 | GestureID : (Gesture code ,
0x00: no gesture, 0x01: Slide down, 0x02: Slide up, 0x03: Slide left, 0x04: Slide right, 0x05: Single click, 0x0B: Double click, 0x0C: Long press) | |||||||
2 | ? | Number of touch points | ||||||
3 | Event (0 = Down, 1 = Up, 2 = Contact) | ? | X (MSB) coordinate | |||||
4 | X (LSB) coordinate | |||||||
5 | ? | Touch ID | Y (MSB) coordinate | |||||
6 | Y (LSB) coordinate | |||||||
7 | Pressure (?) | |||||||
8 | Miscellaneous (?) |
NOTES
- The touch controller seems to report only 1 touch point
- Fields X, Y, Number of touch points and touch ID are updated. The others are always 0.
Registers
Register | Address | Description |
HYN_REG_INT_CNT | 0x8F | |
HYN_REG_FLOW_WORK_CNT | 0x91 | |
HYN_REG_WORKMODE | 0x00 | 0 = WORK, 0x40 = FACTORY |
HYN_REG_CHIP_ID | 0xA3 | |
HYN_REG_CHIP_ID2 | 0x9F | |
HYN_REG_POWER_MODE | 0xA5 | 0x03 = SLEEP (reset the touchpanel using the reset pin before using this register : pin_low, delay 5ms, pin_high, delay 50ms then write 3 to register 0xA5) |
HYN_REG_FW_VER | 0xA6 | |
HYN_REG_VENDOR_ID | 0xA8 | |
HYN_REG_LCD_BUSY_NUM | 0xAB | |
HYN_REG_FACE_DEC_MODE_EN | 0xB0 | |
HYN_REG_GLOVE_MODE_EN | 0xC0 | |
HYN_REG_COVER_MODE_EN | 0xC1 | |
HYN_REG_CHARGER_MODE_EN | 0x8B | |
HYN_REG_GESTURE_EN | 0xD0 | |
HYN_REG_GESTURE_OUTPUT_ADDRESS | 0xD3 | |
HYN_REG_ESD_SATURATE 0xED | 0xED |
WARNING : Writing the SLEEP command (write 0x05 in HYN_REG_POWER_MODE) seems to freeze the controller (it returns only static values) until the battery is totally drained and the whole system reset. Analysis and debugging is more than welcome!
Accelerometer
The on board accelerometer is Bosch BMA421, connected to the I2C bus.
Pins
- P0.06 : I²C SDA
- P0.07 : I²C SCL
- P0.08 : Interrupt
I2C Device address : 0x18
Datasheets and Schematics
Schematics
Note: The part number for the SPI FLASH in the schematic diagram is not correct, the PineTime features a larger external FLASH device, see below.
Chip Datasheets
- NORDIC nRF52832 information:
- ARMv7-M information:
Component Datasheets
- PMU (Power Management Unit) information:
- SPI Flash information:
- XTX XT25F32B 32Mb(4MB) SPI NOR Flash (data sheets for this part are hard to find but it acts similar to other QuadSPI SPI NOR Flash such as Macronix 32Mb(4MB) SPI NOR Flash)
- XTX XT25F32B
- IDs for XT25F32B are: manufacturer (0x0b), device (0x15), memory type (0x40), density (0x16)
- LCD Panel:
- Touchpad information:
- Sensor:
