PineTab2 Releases
Revision as of 15:23, 21 June 2023 by Julian (talk | contribs) (→‎Mobian: Link to SPI flash instructions, and Mobian flashing instructions)
This page contains a list of all available releases and tools for the PineTab2 in alphabetical order.
The installation instructions can be found under PineTab2#Installation instructions.
Linux
Arch Linux ARM
(Unofficial) Arch Linux ARM maintained by the DanctNIX community (GitHub: danctnix, dreemurrs-embedded). This includes uboot.
Download:
Default credentials
Default user alarm/123456
Notes:
Mobian
An unofficial Debian build for ARM64 running with Phosh.
The current version of the base Debian system is Debian Bookworm.
The installation instructions are the same for the PineTab2 as they are for Mobian's other supported devices.
Download:
  • Images (until the weekly images are built, you can download the PineTab2 image from here)
Note: U-Boot is required to be able to boot the images, see here!
Follow the instructions to flash U-Boot for the PineTab2 (you need a GitHub account to download it) to the SPI of your PineTab2.
If you do not flash U-Boot to the SPI of your PineTab2, Mobian images will not boot on it.
Default credentials
Default user mobian/1234
Notes:
  • The development is work in progress. Mobian's support for the PineTab2 is maintained by Julian. The Mobian wiki can be found here.
  • In order to connect to the device using SSH/SCP, you need to install SSH on the device. You can do this by executing the following in a shell: "sudo apt-get install ssh", afterwards you can connect via SSH/SCP using the PineTab2's IP address on port 22.
  • When installing Mobian with full disk encryption and booting with the keyboard case connected, you will have to touch the screen or press a key to show the decryption screen. This is an upstream issue.
