PineTab2 Releases
Revision as of 19:26, 18 June 2023 by Fxc (talk | contribs) (Style fix)
This page contains a list of all available releases and tools for the PineTab2 in alphabetical order.
The installation instructions can be found under PineTab2#Installation instructions.
Linux
Arch Linux ARM
(Unofficial) Arch Linux ARM maintained by the DanctNIX community (GitHub: danctnix, dreemurrs-embedded). This includes uboot.
Download:
Default credentials
Default user alarm/123456
Notes:
Mobian
An unofficial Debian build for ARM64 running with Phosh.
The current version of the base Debian system is Debian Bookworm.
Download:
  • Images (until the weekly images are built, you can download the PineTab2 image from here)
Note: U-Boot is required to be able to boot the images, see here!
You can install U-Boot to the SPI, EMMC, or an SD card.
If you are booting Mobian from an SD card, the pre-installed U-Boot from the EMMC should boot it.
Default credentials
Default user mobian/1234
Notes:
  • The development is work in progress. Mobian's support for the PineTab2 is maintained by Julian. The Mobian wiki can be found here.
  • In order to connect to the device using SSH/SCP, you need to install SSH on the device. You can do this by executing the following in a shell: "sudo apt-get install ssh", afterwards you can connect via SSH/SCP using the PineTab2's IP address on port 22.
